What seats fit in a 2000 Tacoma 1.5 cab prerunner ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2000taco man, Aug 22, 2020.
  1. Aug 22, 2020 at 6:45 PM
    2000taco man
    2000taco man [OP] Member
    2000 2.7l 3rz taco
    Long travel suspension and 31s
    Good evening I just wanted to ask if anyone has ever heard of Durafit seats as I’m looking in taking out the aftermarket bucket seats in the Tacoma I just bought and putting in a factory bench seat as I like them more. If anyone can recommend where I can get a bench seat that’s oils fit my 2000 Tacoma that would be great I can link the seat I’m looking at if requested
  2. Aug 22, 2020 at 8:00 PM
    tortoise_taco
    tortoise_taco Well-Known Member
    battle born
    1996 2.7L 4x4 / 2013 SR5 V6 4x4
    the good ones
    Look for 95-04 Tacomas at your local salvage yards, you'll find a bench seat eventually although it may take a while to find a clean one.
  3. Sep 8, 2020 at 6:51 PM
    BNG_PA
    BNG_PA Member
    Eastern PA
    2002 Tacoma Double Cab, V6, 4x4 (320,000+), 2020 TRD Sport Double Cab MT
    2.5’ Rancho Quick Lift & OME
    I welded non Toyota seats from a GM car or truck. They are far more comfortable than my original ones.
    I reused the riveted brackets so all I did was bolt down the brackets place the seat next to the other (original) for reference, tack, let cool and seam weld outside of the truck.
    I lucked out as they were only $40 Craigslist find.
    Seats
  4. Sep 11, 2020 at 3:13 PM
    christsay
    christsay Well-Known Member
    chris
    Austin, TX / Santa Fe, NM
    2021 Army Green DCLB TRD 4x4
    JB Grand Raid Evo XXL mounted on an Alu-Cab. 5.29 gears.
    Wedge lists two fitments for 95-04 Tacoma seats: "Bench" and "60/40 Bench / Buckets". I think the "Bench" is for regular cabs and the "60/40 Bench / Buckets" is for extended and double cab?
    https://wedgebrackets.com/master-bracket-guide/
  5. Sep 12, 2020 at 2:34 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If you can fabricate your only limited by what seats you can stuff in the cab
    If anyone close wants Bucket seats you maybe could swap if they have a bench seat .
    I can think of one reason for a bench seat I have not needed that since I left home
    CrustyTaco likes this.
  6. Sep 13, 2020 at 2:46 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    60/40 seats aren’t comfortable fwiw
    Tanden and Wyoming09 like this.
  7. Sep 13, 2020 at 5:58 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    I looked at your link (Seats) but you didn't specify what seats you used, Let us know, I'm curious.
  8. Sep 13, 2020 at 11:06 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    Not to hijack your thread, but I'd like to know if the Sequoia bucket seats are the same as the Tacoma bucket seats, or are they more padded and comfortable. Will they bolt right up without any modifications required.
  9. Sep 14, 2020 at 2:49 PM
    BNG_PA
    BNG_PA Member
    Eastern PA
    CrippledOldMan,
    Not sure about what the seats came out of? I bought them off a guy through CL that had a body shop. He seemed to have a ton of GM stuff laying around.
    so, I’m guessing, but reusing the OEM brackets means you have more options. They do sit a little higher, but the drivers seat cushion did squat down from my butt sitting on it for the last two years.
    sorry that really doesn’t help ‍♂️
