What Sealant Do You Guys Use For Roof Rack Bolts?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jboudreaux1965, Mar 9, 2024.
  1. Mar 9, 2024 at 11:59 AM
    jboudreaux1965
    jboudreaux1965 [OP] Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    I'm putting an OEM roof rack on my 3rd Gen today. What type of sealant do you guys use for the bolts that screw in threw the roof?
    On my 2nd gen I put a few different roof racks on it over the years and alway used threadlock on those bolts. The last time I installed a roof rack I found that one of the bolts was letting water seep in, so I pulled the bolts and put them back in with some Toyota black FIPG because that is what I had on hand.
    Is that overkill? What do you guys use?
  2. Mar 9, 2024 at 12:09 PM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    I use a poly-based marine sealant (loctite brand available at home depot) typically. Silicone will shrink over time and pull away and the desert heat doesn't help that. Done a dozen racks over the years and not a single leak.
  3. Mar 9, 2024 at 12:14 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Thanks! I'll go pick some up.
  4. Mar 9, 2024 at 12:16 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
  5. Mar 9, 2024 at 12:56 PM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
  6. Mar 9, 2024 at 12:59 PM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
  7. Mar 9, 2024 at 1:03 PM
    Sparkle_Tooth
    Sparkle_Tooth Well-Known Member
    East TN
    2020 TRD PRO (Magnetic Gray)
    ICON Stage 9 BFG KO2 285/75R/16
    I use GE Advanced silicone (100% waterproof, Shrink and Crack Proof). You can get it at lowes or home depot and if you squirt some down the holes and around them you'll be fine. It rains like hell here in East TN, and no leaks (knock on wood)
    eurowner likes this.
  8. Mar 9, 2024 at 1:29 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I used OSI quad max. Been good to go for years. It’s also a poly based sealant, with a little urethane I think. Most of the formula is proprietary.
    this stuff was made for like siding and what not. It’s literally made to be outside and exposed to UV.
    eurowner and na8rboy like this.
  9. Mar 9, 2024 at 1:55 PM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    Butyl, doesn't get hard and is waterproof.
  10. Mar 10, 2024 at 3:19 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Automotive grade silicone sealant in clear.
  11. Mar 11, 2024 at 3:33 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    None but my 2017 has the sherpa grand teton roofrack :D:D:D
