What rear disc brake upgrade to go with front Tundra brake upgrade?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Lil'John, Sep 27, 2023.
  1. Sep 27, 2023 at 6:19 PM
    Lil'John
    Lil'John [OP] Active Member
    2002 Tacoma TRD 4wd
    I have a 2002 extra cab Tacoma 4wd TRD that I drive sporty and needs new brakes. I'm giving serious thoughts to doing the Tundra brake upgrade up front.
    My question is what rear disc brake upgrade should I look into? It MUST have integrated emergency brake. Line locks are NOT an option.
    Is there a factory bolt in solution? Newer Tacoma axle?
    I was a bit shocked that it was drum in the rear whereas my 2000 S10 is rear disc.:confused:
  2. Sep 27, 2023 at 6:46 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    turbodb and Lil'John[OP] like this.
  3. Sep 27, 2023 at 7:27 PM
    Lil'John
    2002 Tacoma TRD 4wd
    Sadly, it doesn't appear to work on first gen Tacomas.
    I'm somewhat trying to avoid 'one off' custom type solutions requiring 'hard to find' parts for consumables.
  4. Sep 27, 2023 at 9:04 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    It does work and if anyone knows it fits it’s Jon.
    There is nothing on the market like what you’re looking for. If there were you’d find it here.
    Funny you think drums on a 2000 is strange. Its drums up to 2023. Toyota doesn’t make things to push tech, they build things to be reliable.
    ToyoTaco25 likes this.
  5. Sep 27, 2023 at 10:11 PM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    I love Toyota as much as the next guy but my 06 sienna mini van has "reliable" 4 wheel disc. I've always wondered how the Tacoma had drums for so long? But see I (we) still bought it.
    Its about where and which vehicle can they get away with shaving cost and still selling it. Not about hammer and anvil tech = reliable.
    AusBerg likes this.
  6. Sep 28, 2023 at 12:15 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    I put it on my truck.
    Lil'John[QUOTED][OP] likes this.
  7. Sep 28, 2023 at 5:30 AM
    Lil'John
    2002 Tacoma TRD 4wd
    On the first, ad says 2005+ Tacoma. I'm new here so I don't know mechanicjon and what mods he's done.:confused:
    I now know there is something on the market but I was also curious if there was a "factory" option. Something like take axle out of FJ80 or 4 runner, cut link mounts off, weld spring pads on, and bolt it in.:confused: I may look at FJ80 option since I've played with one in the past... aside from two days of grinding brackets, fairly straight forward. Added bonus of full float. Back to research on WMSs.
    Nothing unreliable about discs. And discs aren't "pushing tech"... my 68 Mustang came factory with front discs:eek:
    Given that most trucks on the road don't carry much more than groceries in the bed if anything ever, I would think putting discs would ensure no brake fad for the soccer moms who ride the brakes:rofl:
    treyus30 likes this.
  8. Sep 28, 2023 at 8:33 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Sounds like you wanna make this a whole lot more difficult than it can be, for something that really isn't going to make a massive difference. Most of the folks (and I say this having been involved with Tacoma communities since 2001) who go down this road end up seeing very little if any brake improvement. The back end of these trucks are just sooooo light that disc brakes aren't necessary. If you're still dead set on it, the kit that is linked above is retrofitting FJ parts onto your existing axle, and the least intrusive approach. Swapping a whole axle from something other than an equivalent 4 Runner is going to put you into differing width territory - everything is wider these days.
    Making comparisons to what other vehicles have rear discs in whatever year they did is pretty pointless, as pointed out already, it's not enough of an improvement to justify it.
    Lil'John[OP] and ToyoTaco25 like this.
  9. Sep 28, 2023 at 8:41 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    That’s a great question about going to discs in the rear... Before I get into that though, I think it’s important to understand why the brakes get upgraded at all. On a stock 1st gen Tacoma, or even one like mine that’s 5500lbs (about 1700lbs heavier than stock), properly adjusted stock brakes - both front and rear - have no trouble locking up the wheels (or engaging ABS if you have it) when you press on the brake pedal. You can’t stop any faster than a skid (or ABS), so you don’t need bigger brakes for more “stopping power.”
    The reason larger brakes come into play is because a lot of us carry weight (hence the 5500lb trucks) or brake for long periods of time (going downhill), and that can cause a lot of heat/friction build up. That can end up overheating the stock front rotors and cause them to warp. So, really, the main reason for the Tundra upgrade is to get the *much larger* rotors in the front, since they can absorb a lot more heat before warping. Also related - if everything gets *way* too hot, you also risk boiling the brake fluid, so technically the larger 13WL/13WE calipers (which have more fluid volume) reduce that risk as well, but it’s a distant second to the rotor heat.
    So, with all that, for the rear, sticking with the stock drum brakes is really the best bet IMO, for a few reasons...
    1. First, on our trucks, we have the LSPV (load sensing proportioning valve). If you’re not familiar with it, it’s mounted to the frame on the driver side above the rear axle, with an arm that connects to the axle near the rear diff. Anyway, that controls how much braking the rear end does compared to the front, and when it’s properly adjusted, it can supply up to 30% of the overall braking action. That means, that even in the best (most balanced) case, the front is doing 70% of the braking. Usually, it’s doing more. That makes the Tundra upgrade (primarily larger rotors) in the front a great option to absorb the heat from braking, but also means that there’s no real reason to add anything “more beefy” in the rear.
    2. Also important is the fact that by swapping to a caliper/rotor in the rear, you’d lose your ability to use the e-brake - at least, the current incarnation that you have in the truck. There are options - like a hydraulic line lock - but they add complexity that just isn’t necessary IMO.
    3. Lastly is maintenance. One of the great things about the drums is that they are almost no maintenance. They rarely need to be replaced, and you don’t (usually) have to worry about them overheating and warping like you might with rotors.
    Anyway, that’s my opinion on why there's not really any good reason to do the rears; stick with drums back there for almost no maintenance and just do the Tundras up front. Of course, some folks (like @mechanicjon) do convert to discs in the rear - mostly because they enjoy figuring out how to do it, and having a setup that's unique in the Tacoma world. Which is a totally fine reason to do it!
    For the Tundra upgrade on the front - this page has a great step-by-step guide (with pics) on the Tundra upgrade, as well as links to all the parts needed (at varying price points). OEM is best for the pads, but for the calipers you shouldn't pay the premium. Get them from your local parts store (ideally) or Amazon, which will give a lifetime warranty in case you ever need to replace them.
    And don't forget the upgraded lines, they make a big difference with the larger calipers.
    Step by Step Tundra Brake Upgrade on a Tacoma (or 4Runner)
    Hope that helps!
  10. Sep 28, 2023 at 10:13 AM
    Laxtoy
    Maltby, WA
    That’s a better clarification than what I said. It’s not about tech, I should’ve stated it’s about simplicity and that drum brakes are good enough. In a vehicle that’s light in the ass end and usually has the front end doing 70% of the braking, they decided it wasn’t cost effective or necessary to reinvent the wheel. Like many other parts in their vehicles, Toyota’s rear drums fit a wide range of their trucks across the years. That certainly ads to the reliability factor.
    A minivan with rear discs makes sense where it has a more distributed load and are very heavy vehicles that need the extra braking, especially when loaded with 7 people and a bunch of gear.
    These trucks aren’t sports cars. I don’t see many soccers moms driving trucks, far more frequent it’s and suv or minivan.
    A full size truck definitely makes more sense just based on usage, but around here, Tacomas aren’t often used to tow or haul, at most they’re outfitted with off-road gear, which can add weight, but I’m sure Toyota just said keep it simple since most people simply don’t need the extra braking.
    I’ve had my truck for almost 20 years, and I would carry a lot of weight regularly, often times well over a half ton of lumber, and even in Seattle where we have a lot of hills and winding tight streets I didn’t see the need for extra braking, probably because i wasn’t going that fast. Much of that was with 33” tires. I did the Tundra swap pretty early on because with larger tires the stock brakes couldn’t keep up.
    I researched the rear system Jon suggested a while back and decided it simply wasn’t cost effective for a truck I don’t drive like a sports car.
    I think if it’s worth it to you, you should go for it, but the tundra swap will make a huge, huge difference, so maybe start there.
  11. Sep 28, 2023 at 10:22 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Call SOS brakes. That's the kit i put on my truck. Bolt on setup. Parking brake cable length is the only thing in the kit that has to be mocified for length. SOS will do that for you once you know the correct length. Hell I think I have the length written down somewhere.
    The only reason I put them one my truck was because I bought the kit off another TW member for half the price.
  12. Sep 28, 2023 at 10:27 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    1. I retained the LSPV valve and e-brake.
    Lil'John[OP] and turbodb[QUOTED] like this.
  13. Sep 28, 2023 at 10:36 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Nice. Most who do this, don't, and start looking at other solutions like manual proportioning valves in the engine bay and line locks, as @Lil'John mentioned in his first post. The kit you've got seems pretty nice - certainly the nicest I've seen. Still not worth it (for me), given the weight and braking profiles of our little beasts, but certainly a cool (and relatively rare) mod!
    mechanicjon[QUOTED] likes this.
  14. Sep 28, 2023 at 11:02 AM
    Laxtoy
    Maltby, WA
    It does look like the 2nd gens require an upgraded master cylinder, 1st gens have the 1” bore and the smaller bore, I’d imagine that makes some difference. @mechanicjon, can you clarify that?
  15. Sep 28, 2023 at 1:24 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    It works fine with the stock 1st gen master cylinder. The pedal is about 1/4" lower then with drum brakes, but it's good and solid like it should be.
    Laxtoy[QUOTED] likes this.
  16. Sep 28, 2023 at 2:34 PM
    Lil'John
    2002 Tacoma TRD 4wd
    I'm running a bit of extra weight over the back; camper shell plus a little bit. So it isn't complete light butt light.
    And I actually do drive fast within my limits. I live a 'quick' drive from the Rubicon and daily drive Wentworth Springs. I push it HARD.
    Part of the reason for my desire for an upgrade isn't for "increased" braking force but brake fade mitigation. I don't ride the brakes but I feel a bit of an issue.
    FWIW, I don't have that "brake fade" issue on the S10 truck with both trucks being about equal: V6, manual trans, 4wd, and ~31s. The butt on the S10 gets a bit loose since it doesn't have any extra weight in the rear.
  17. Sep 28, 2023 at 6:07 PM
    Laxtoy
    Maltby, WA
    The SOS kit is the only rear disc with an e-brake option that’s off the shelf I know of.
    I feel you in wanting better brakes and certainly retaining the ebrake. Years and years ago there was a transfer case brake kit in testing, I think from Sky Fabrication, but it never went anywhere. Sucks because I’m pretty sure they made/still make it for pre-Tacoma trucks.
    If you’re okay with pushing some wms and can do some fab to set up for leafs you could run a 03+ 4Runner or 07-09 FJ Cruiser axle and get discs and an ebrake.
    There’s just no easy/cheap/off the shelf way, at least none I’ve found and I’ve been looking for a long time.
  18. Sep 28, 2023 at 6:11 PM
    Laxtoy
    Maltby, WA
    IMG_1783.jpg My rig, loaded, but fat and heavy to begin with lol
    mechanicjon and turbodb like this.
  19. Sep 28, 2023 at 10:23 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Now thats a ladder!
    Andy01DblCabTacoma likes this.
  20. Sep 29, 2023 at 12:08 AM
    Laxtoy
    Maltby, WA
    Well, pump jacks, kinda like a ladder only 5x the pain in the ass to set upIMG_0892.jpg
    not me but I’m sure you get the gist
