What Parts do I need to do a Front Rotor and Brake Pad Change?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CenterKnurl, Jul 27, 2023.
  1. Jul 27, 2023 at 11:05 AM
    CenterKnurl
    CenterKnurl [OP] Well-Known Member
    Typically do all my own maintenance but I'm not interested in doing my own brakes and have a shop that will do them for free for me, so long as I get the parts.
    Pads
    I believe the pads are part # 04465-04090 here: https://parts.frontiertoyota.com/oem-parts/toyota-oem-front-brake-pad-set-2016-2021-tacoma-446504090
    Rotors
    I believe the rotors are part # 4351204052 here: https://toyotaparts.bochtoyotasouth...rotor-fits-2005-2019-toyota-tacoma-4351204052
    Are these the correct and only parts I need? I literally need to just show up with the parts, but I want to make sure I didn't miss anything. Thanks guys!
  2. Jul 27, 2023 at 11:05 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    New shims.
  3. Jul 27, 2023 at 11:09 AM
    CenterKnurl
  4. Jul 27, 2023 at 11:14 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I normally stick with OEM, but I had warped OEM rotors and went with PowerStop. Very happy with them. I am all on pavement so drilled and slotted is not an issue for me. Here is a link to the kit I used on my 2016.
    https://www.amazon.com/gp/product/B005FKS28C?ie=UTF8
    EGBTER likes this.
  5. Jul 27, 2023 at 11:18 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  6. Jul 27, 2023 at 12:01 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Front brakes. Rotors and pads are simple, clean guide pins, check boots, brake grease, shims. And your done,
    Chasgreen55 and zoo truck like this.
  7. Jul 27, 2023 at 1:40 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
  8. Jul 27, 2023 at 1:44 PM
    zoo truck
    None
    I tried ebc pads with my ebc rotors on my tundra. I liked the toyota oem ceramic pads better.
    Kwikvette[QUOTED] likes this.
  9. Jul 27, 2023 at 5:01 PM
    CenterKnurl
    Does anyone have the part number for the shims I need to bring in?
  10. Jul 27, 2023 at 6:13 PM
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    Please post the shop that does free brake work I’d like to get in on that deal
    petethemeat and Holling like this.
  11. Jul 27, 2023 at 7:19 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Works for some, not for others.
    Could just be the vehicle itself too; I've had many different cars and liked the EBC's on them including some of my Corvettes.
    Just bought EBC greens about a day ago for my GX470.
  12. Jul 27, 2023 at 7:31 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Akebono brake pads. Put them on my 07. Used AC Delco rotors quiet.
    Kwikvette likes this.
  13. Jul 27, 2023 at 7:41 PM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
  14. Jul 28, 2023 at 4:07 AM
    zoo truck
    None
    The ebc green pads left a lot of black brake dust on my tundra's aluminum wheels when I tried them. The stock toyota pads never did. As far as the operation, it seemed I needed more pedal pressure when braking with a trailer than with the stock pads, otherwise they were fairly similar.
  15. Jul 28, 2023 at 4:28 AM
    petethemeat
    petethemeat Well-Known Member
    Pete
    Ontario
    2023 TRD OR AC MT
    If you have the brakes serviced regularly, all you should need is pads and rotors, the brand is your choice. If you don't get the brakes serviced regularly, you might need pads, rotors, and calipers as the slide pins will seize up. Once that happens you might get them to free up again but you really need calipers at that point. And that just might ruin your free labor deal.
  16. Jul 28, 2023 at 8:57 AM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    +1 on EBC green stuff pads being dust monsters. Not happy with mine but they work well and the wheels clean up easy.
    don’t forget to get some dot 3/4 brake fluid and replace that old dirty fluid while they are doing your brakes.
    zoo truck likes this.
  17. Jul 28, 2023 at 10:12 AM
    zoo truck
    None
    Yeah, it's almost impossible not loose some brake fluid unless you open the reservoir to remove some, before starting the brake job. I've remedied this by taking a turkey baster, and sucking a fair amount out of the reservoir before spreading the calipers.
  18. Jul 28, 2023 at 3:59 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    +1 on brake fluid, even clean looking fluid may have a decent amount of water in it.
  19. Jul 28, 2023 at 9:03 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Nothing is free. Lol...probably charging him $150 for an "oil change"
  20. Jul 28, 2023 at 9:08 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Instead of pushing that dirty brake fluid back up into the lines, line-lock the flex hose, open the bleeder and let it come out while compressing the pistons..
