What oil and filter to use on 1998 2.4L
Discussion in '1st Gen. Tacomas (1995-2004)' started by hats009, Nov 12, 2011.
  1. Nov 12, 2011 at 8:38 AM
    hats009
    hats009 [OP] Well-Known Member
    09 4x4 TACOMA TRD
    Hey all, this will be my first oil change with my new used 1998 2.4L..
    I have been reading about Royal Purple; is that an option and would it make much of a difference? Also, what filter should I get? :eek:
  2. Nov 12, 2011 at 8:47 AM
    hats009
    09 4x4 TACOMA TRD
    What about K&N filters I have been reading about?
    What makes the Toyota filter better to go with or the K&N less so?
  3. Nov 12, 2011 at 8:50 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    I use Rotella T6 its a synthetic 5-40 oil designated for diesels, that is all I use in my vehicles (yes they are non diesel) and I change it at 5K miles, filters, I just use WIX filters and change them every oil change.
    The reason I use diesel oil is that it is designed to hold up to the pressures and heat associated with Ultra High compression turbocharged vehicles, so it does VERY WELL in everything else, I have pulled motors apart after using this oil only and it showed absloutely no wear! Even the rod bearings looked reusable..
    I used to help pit with a race crew that was running a TT BBC motor making 25psi and we used nothing but the T6 oil and since we tore the motor down a lot we measured wear and foud that oil to reduce the wear considerably even compared to other Sythetic oils like Mobil 1.
    Everyone has opinions, but I wiill only use this oil in my vehicles.
  4. Nov 12, 2011 at 8:52 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Royal Purple is one of many good options, as are Mobil 1 and Amsoil. Use an OEM Toyota oil filter. (See below.)
    http://www.tacomaworld.com/forum/te...-oil-filter-made-thailand-vs-competition.html
  5. Nov 12, 2011 at 9:16 AM
    Speed Freek
    Royal Purple is overpriced, but hey it looks cool...but for 8$ a quart or therabouts I will pass...
    treyus30 likes this.
  6. Nov 12, 2011 at 5:34 PM
    hats009
    09 4x4 TACOMA TRD
    thanks for the advice and references; I ended up running to the dealer to pick up the OEM oil filter and it was only $5.86 with tax!
    Now, I am still a bit confused with reading some posts in the forum elsewhere about 4bangers only using 5-20 oil or 0-20.. And the science of it is even more confusing.
    If it helps, my taco has 182,000 on it and pushing.
    It seems no one has one set answer.
    And that oil filter comparison was awesome.
  7. Nov 12, 2011 at 6:12 PM
    Norton
    One of the best references you can consult is your Owner's Manual. It includes Toyota's recommendations for your truck's maintenance, including oil specifications.
    If you don't have a hard copy, check out the Toyota Owners' Web Site, where they're available for download. According to pg 229 (attached), the recommended oil viscosity for your truck is 5W30.
  8. Nov 12, 2011 at 6:18 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    That is only for 2nd gens I believe.
  9. Jul 5, 2018 at 12:00 PM
    Tacoma Cutout
    Tacoma Cutout Well-Known Member
    Need HELP on oil filter! I just bought the Toyota oil filter per this very informed forum. $6.99 Counter guy was really useless... The one he sold me has this number,90915-YZZG2. It's short. He said this is the part number for a 98 Tacoma 2.4. Couldn't even tell me if it had a anti drain back valve.. I don't know how to post pics here or I would.. Any Ideas? I am ready at the moment to change the oil...[​IMG]
  10. Jul 5, 2018 at 12:45 PM
    Topic Thunder
    Topic Thunder Active Member
    Hamner Head
    03 Tacoma Sr5 2wd 2.4 5spd
    Currently taking off decals. New wiper blades and vent visors
    I'd take the old filter off and compare the size to the oem one.If its close i'd use the toyota one. I'll never use a fram filter again. I had a problem with one on an old jetta. The fulter collapsed inside and restricted oil flow. For the record I use Castrol 5w30 magnetec, don't know if its any better but at least my stuff is magnetic now! Mt filter choice is motorcraft fl910s, I beleive. Good luck
  11. Jul 5, 2018 at 1:44 PM
    Tacoma Cutout
    I compared it and they were the same size, it was a NAPA 21348 Pro Select. I can't find a cross reference for it to any of the OEM Toyota Filters. I went ahead and used the Toyota 90915-YZZG2
  12. Jul 5, 2018 at 2:30 PM
    ROCKIN RICHIE
    ROCKIN RICHIE Well-Known Member
    BEAN TOWN
    02'TACO
    The TOYOTA YZZD3 is all filter element. The ADV is not silicone but works better because when I remove it for an oil change the filter is still full of oil after 6 months whereas others except for Mobil1 are empty half the time. Can't beat the price either. Check out a cut-away of that WIX 51348 and the canister is only 1/2 of a filter and smaller canister at that. You get over 200 square inches of element with the Toyota.
    Robnik likes this.
  13. Jul 5, 2018 at 8:09 PM
    Tacoma Cutout
    The Toyota Parts counter guy said this was the Toyota Filter for my truck as well as new vehicles. I asked about a longer one and he looked at me with a blank stare...
  14. Jul 6, 2018 at 3:41 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    I use Castrol GTX 5w-30 and a Napa gold/wix or OEM filter. Dont really think it matters as long as you buy a decent filter (not fram, stp, microguard, etc) and change every 3-5k.
  15. Jul 6, 2018 at 2:09 PM
    Pervy
    Pervy Well-Known Member
    East Texas
    2.4 Tacoma, 3.4 4Runners
    I always get the oem toyota filters for my 2.4 in bulk on ebay (the YZZD1) that cost $3.50 a filter including a new drain bolt gasket for each filter. You can go higher to like the YZZD3, but isnt necessary for the small 2.4 engine (heck even the 3.4). G2 toyota filter works as well.
    As for oil honestly any oil is fine. Whats more important is choosing conventional or synthetic. Im cheap so I use supertech oil from walmart and both the conventional and full synthetic versions seem fine.
    My advice though is if you do choose to try synthetic, theres a chance your truck based on the previous wear of the engine may not work well with it. So if anything acts up on the synthetic be ready to switch it right back to conventional oil. For me when I switch a vehicle to synthetic the first time I buy both sets of oil and just return the conventional ones if I find the truck does fine with the synthetic.
    Have had two 2.4L tacos (both under 150k miles) one didnt like the synthetic, the other (my current) does work with it. Have two 3.4L 4runners of which both dont like the synthetic but they were both passed 250k miles.
    Bad signs of not liking the synthetic was a lot of smoke from the tail pipe and a heavy ammount of burnt smelling oil at just idle. The vehicle's engine also sounds inconsistent and seems to have more exaggerated engine shake. My previous 2.4 had all thse issues :(, but luckily my latest 2.4 purred pefectly fine after the switch.
    Underdog73 likes this.
  16. Jul 6, 2018 at 5:04 PM
    TacoHank1998
    TacoHank1998 Well-Known Member
    Will
    Panama City, FL
    1998 Green Tacoma Base
    Supertech and a fram filter work just fine in my 2.4...
    Robnik likes this.
  17. Jul 6, 2018 at 7:53 PM
    Tacoma Cutout
    I used 5W30 full Synthetic High Mileage (139,000) Super Tech (Walmart). I have used the Supertech for years in my Camry and Lexus, Camry has 312K and the Lexus had 188K. Thanks for the replys!
    Robnik likes this.
  18. Mar 12, 2022 at 7:22 PM
    Abused03
    Abused03 Member
    Clapped out 03 2wd 2.4
    I just use a OE filter, and Mobil1 Synthetic 5w30
    Robnik likes this.
  19. Mar 12, 2022 at 9:29 PM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    or
    Both should be available at your local Wally World. Any synthetic oil should will do, Mobil 1, Castrol, Valvoline, etc. Royal Purple is way overrated. Maybe in a Lamborghini to give you that warm, fuzzy feeling, lol :)
  20. Mar 12, 2022 at 9:40 PM
    Robnik
    Rob
    Greenacres, Florida
    Oh & that's correct, 5W-30 is the correct viscosity for your application.
