What offset do i need to equate to 1.5 inch spacer?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rydawg, Oct 18, 2018.
  1. Oct 18, 2018 at 2:05 PM
    rydawg
    rydawg [OP] New Member
    2018 Magnet Tacoma TRD Offroad
    2.25 in level
    So I put a set of 33s on my leveled TRDOR with stock rims and with a 1.5 inch spacer I fixed the rubbing problem, but I am a bit paranoid about wheel spacers. With the +25 factory offset would 0 mm wheels still work or what negative offset would I need to keep from rubbing? Thanks!!
  2. Oct 18, 2018 at 2:07 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    1.5 inches =38mm in offset
    Rockefelluh and Doggman like this.
  3. Oct 18, 2018 at 2:15 PM
    beergeek
    beergeek Well-Known Member
    RI
    2017 Black Tacoma Limited
    Which would equate to a wheel with -13mm offset.
  4. Oct 18, 2018 at 2:16 PM
    coopcooper
    alberta canada
    so go with a wheel with a -12 offset. /thread
    doorsidedown and beergeek like this.
  5. Oct 18, 2018 at 2:37 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    :rofl:
    jerryb1984 likes this.
  6. Oct 18, 2018 at 2:38 PM
    jerryb1984
    jerryb1984 Well-Known Member
    Jerry
    2018 DCLB TRD OFF ROAD
    16x8 FUEL BEAST 265 75 16 FALKEN WILDPEAK AT3 Tyger step sides 20% tint front to match factory tint bilstein 5100s on third notch PRO grill
    Not exactly correct. Rim width affects this as well. Here’s a calculator for you. My aftermarket 8 inch wide wheels with +1 offset extend 37mm from stock wheel or 1.45 inches.
    If you get a 9 inch wide wheel with -12 offset it extends 62mm or 2.44 inches further.
    8 inch wide with -12 is 50mm or 2 inches further.
    Point is to be careful with your rim width. Don’t go solely off of offset difference.
    JoeRacer302 and Gunshot-6A like this.
  7. Oct 19, 2018 at 7:26 AM
    coopcooper
    alberta canada
    I know math is hard for you guys down there
    Rockefelluh likes this.
  8. Oct 19, 2018 at 7:30 AM
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    On a wheel that is same width as factory. Change the width, change the offset.
  9. Oct 19, 2018 at 7:32 AM
    coopcooper
    alberta canada
    he didn't ask anything about changing rim sizes, he simply asked what offset would equate a 1.5 inch spacer. so a 16x7 at -12 works, yeah obviously when you start upping rim widths the dimensions change.
  10. Oct 19, 2018 at 7:35 AM
    JoeRacer302
    Joe
    Pasadena, CA
    Sure, but plenty of people don’t understand this, read the first comment and go “well these are -12” and miss the importance that they are also 16x8. It’s best that if there is a discussion about offset that the importance of width/backspacing is discussed too. All it does is add information to the discussion and further clarifies for anyone who comes along to read the thread later.
  11. Oct 19, 2018 at 8:12 AM
    jerryb1984
    Jerry
    They may be out there, but not very common. Can you find me a wheel that’s 7 inches wide with a -12 offset? I’m betting there will be few if any. Width is a huge factor in this so if you just tell someone that doesn’t know to get a -12 offset wheel, it won’t be a 7 inch wide one.
    JoeRacer302 and beergeek like this.
  12. Oct 19, 2018 at 8:25 AM
    chucklefunkk
    chucklefunkk Well-Known Member
    So. AZ
    2016 TRD OR
