What offset a 17x9 running a 33's should be?
Discussion in 'Wheels & Tires' started by Mod fan, Feb 13, 2018.
  1. Feb 13, 2018 at 2:54 PM
    Mod fan
    Mod fan [OP] Well-Known Member
    can someone post up what offset a 17x9 running a 33 should be? Hate seeing those rigs where the wheels stick waay out. Truck is 2017 Tacoma trd off road
    Thanks
  2. Feb 13, 2018 at 3:35 PM
    Dave Mullins
    Dave Mullins Well-Known Member
    Dave
    Salt rock W.V.
    2017 Tacoma SR Silver
    Tinted windows 15%
    IMG_0412.jpg 17x9 -12 offset with 265 70 17.
    flush with flares
  3. Feb 13, 2018 at 3:38 PM
    Dave Mullins
    Dave
    Salt rock W.V.
    Tinted windows 15%
    You also can youtube it. Lot of tacomas with different set ups on there
  4. Feb 13, 2018 at 3:38 PM
    Mod fan
    You think offset would be the same with 33x 12.50 x 17 tire ?
  5. Feb 13, 2018 at 3:39 PM
    Mod fan
    Nice truck Dave !
  6. Feb 13, 2018 at 3:41 PM
    Dave Mullins
    Dave
    Salt rock W.V.
    Tinted windows 15%
    Not sure about that.
    He sold the truck and I bought the wheels.
    Your in the same dilemma as me.
    Im got my wheels and 3/2 lift now im researching tires. 265 70 17 or 285 70 17.
  7. Feb 13, 2018 at 3:42 PM
    Dave Mullins
    Dave
    Salt rock W.V.
    Tinted windows 15%
    Not my truck. But wish it was
  8. Feb 13, 2018 at 3:48 PM
    Mod fan
  9. Feb 13, 2018 at 4:26 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    A stock Offroad wheel has a 5" backspace.
    On a 9" wide wheel, you would need 0 offset to achieve the same backspace.
    This would provide the least amount of tire poke at about 1.5", assuming you're using at 285/70/17 tire. A 285 is the minimum width tire you should be running on a 9" width wheel.
    Keep in mind though, a 285 will move 1/2" closer to the suspension. If you moved the offset to -12mm, the tire will have the same suspension clearance as stock, but also increase tire poke to 2". If you plan on lifting, you'll need more inside clearance; meaning more negative offset, more tire poke and clearance issue on the cab mount.
    It's a cascading effect...
    If you don't like a bunch of poke, I suggest considering an 8" width wheel instead. Even then, you might not avoid a lot of the same pitfalls I mentioned above.
    xola3que and Mod fan[OP] like this.
  10. Feb 13, 2018 at 4:33 PM
    Mod fan
    Tac11 and Darkoperator like this.
  11. Feb 13, 2018 at 4:34 PM
    Mod fan
  12. Feb 13, 2018 at 4:44 PM
    splitbolt
    NW Arkansas
    If you like it, I love it. Personally, it's not my speed.
    You'll definitely have to lift and do some clearance mods.
  13. Feb 13, 2018 at 4:47 PM
    Mod fan
    Lift was ordered from headstrong today
  14. Feb 13, 2018 at 4:54 PM
    splitbolt
    NW Arkansas
    17"x9" ET-6 is 5.25" backspace; 1/4" close to the suspension. Mounting a 285 would put the tire 1/2" close to the suspension. When you lift, you lose inside clearance.
  15. Feb 13, 2018 at 7:40 PM
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
  16. Feb 13, 2018 at 7:53 PM
    splitbolt
    NW Arkansas
    The rim will stick out 1.5" further than stock.
    If you stick with 265s, the tire will stick out 1".
    If you go to 285s, the tire will stick out 1.5".
    This assumes you have a SR, SR5, Offroad or Sport
    Here's a calculator you can compare with: Here is a link you can find your stock wheel specs(it doesn't list a Pro, it's a 16"x7" ET+13)
  17. Feb 13, 2018 at 8:02 PM
    Drunken Chewbacca
    Josh
    3rd Gen Taco
    Not enough to list
    Hmm. Don't know the measurements on the left. Don't have a slot for back spacing. I am thinking of running 255/85/16. Skinny Tires and 2" lift.
  18. Feb 13, 2018 at 8:09 PM
    splitbolt
    NW Arkansas
    You don't need to for the purpose of figuring out poke.
    The backspacing is calculated on the graph when you enter the wheel specs. However, it is off by 1/2", because it is calculating rim width, instead of wheel width. Just add 1/2" to any backspace measurement it calculates for the true backspacing measurement.
    Which wheel do you have now?
  19. Feb 13, 2018 at 8:10 PM
    Drunken Chewbacca
    Josh
    3rd Gen Taco
    Not enough to list
    Stock OR wheels. Seen these on 2nd Gens. Thought the 3rd Gens are a little wider, body wise.
  20. Feb 13, 2018 at 8:31 PM
    splitbolt
    NW Arkansas
    Did one for you...
    I pulled numbers out my ass for the column on the left; but for comparison's sake, it doesn't matter. You can measure and get those if you need to know.
    Notice the graphed wheel on the left has a 4-1/2" backspace and one on the right has a backspace of 3-17/32"; like I said they're short 1/2". You can confirm this on the link you posted or any offset chart.
    Here you can compare spec and clearance differences.
