What Motor oil are y'all using
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dblj70, Nov 6, 2017.
  1. Nov 6, 2017 at 6:18 AM
    dblj70
    dblj70 [OP] Well-Known Member
    Jeff
    2013 DCSB TRD Offroad SpruceMica
    I'm thinking of switching to full synthetic but not sure which brand to go with. I'm hearing Mobil 1 and Royal Purple. Thoughts?
  2. Nov 6, 2017 at 6:20 AM
    la0d0g
    running for the hills
    For crawling not hauling
    Mobile 1. Costco case. Cheap.
  3. Nov 6, 2017 at 6:21 AM
    omgwtfbbq!
    omgwtfbbq! Well-known Idiot
    Ohio
    2013 X-Runner
    I've currently got whatever Toyota puts in it, will probably switch it over to the oil I use for everything else (bike, last car, guns, etc).
    Good ole Rotella T6.
    dblj70[OP] likes this.
  4. Nov 6, 2017 at 6:54 AM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    Right now... Valvoline Maxlife synthetic.
    Next change will likely be Pennzoil Platinum high mileage, simply because I normally use Pennzoil.
  5. Nov 6, 2017 at 7:06 AM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    Pennzoil 5-30 plat.
    Front and rear diff ,transfer face Mobil 1 syn 75-90 syn 45k
    TOMB
    Rambo54 likes this.
  6. Nov 6, 2017 at 7:14 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
  7. Nov 6, 2017 at 7:17 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    No
    No
    No
    No
    Not another oil thread!
    :annoyed:
  8. Nov 6, 2017 at 7:21 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Personally i use T6 in all my motorcycles, but you wont find it in my truck. No energy conserving additives, and 40w is too thick for the 1GR.
    Mobil 1 0w-30 from walmart and the MIR's from Mobil 1 make a 5 quart jug right around 12-13 bucks.
  9. Nov 6, 2017 at 7:33 AM
    Sand Shark
    Sand Shark I dont pub crawl.when I do,I use pub crawl control
    Erich
    Phoenix, AZ
    2017 Blazing Blue DCSB Off-Road (yes I get dirty)
    REI VIP Parking Pass,Pavement Avoidance System
    5W-20 Pennzoil. Good for 10,000 miles with no degradation and no metal flakes. I checked it at 5k and changed it at every 10K. Looking at my third oil change here in 2 or 3 months.
    The Girls at Madam Camae's Filipino Palace use Great Value Baby oil...
    Alex:You've been spending our rent money on Filipino hookers?
    Josh: They're not hookers, they're massage therapists.
    Mover #2: Yeah, that'll massage your _______ for money.
    Mover #1: There is a word for that... I think it's hooker!
    Josh: You're a hooker!
    Grandmas Boy will change the world...
    Nateclimb and Hartford like this.
  10. Nov 6, 2017 at 8:38 AM
    Justyn98
    Justyn98 Well-Known Member
    Justyn
    West Virginia and Kentucky
    09 barcelona red tacoma trd sport DCSB
    Led pod fog light inserts, kn cold air intake, Bilstein 5100 with 2 inch coil combo and progressive AAL. Touchscreen pioneer stereo and infinity components with 2 kicker comp r10's and jones turbine exhaust
    Rambo54 likes this.
  11. Nov 6, 2017 at 8:43 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    I switch around time to time. I did free changes up to 25k, then switched to synthetic with Mobile 1, then switched to Pennzoil Platinum (not ultra platinum since couldn't find locally), then did Royal Purple for 2 changes. Back to the Pennzoil now. Probably will stick with that or Mobile 1. RP is not worth the extra cost to me.
  12. Nov 6, 2017 at 8:44 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Rotella 10w-40
    Hoff likes this.
  13. Nov 6, 2017 at 8:52 AM
    Pigpen
    Northwest Montana
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Backcountrry MT 3 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 24F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, OME 90021 front shocks with 885 coils, SPC LR UCAs, Up2NoGood 2wd low range mod, 4 Wheel Campers Grandby slide in camper
    Mobil 1 0W-30
    Great cold weather characteristics. Cold is harder on your oil then heat. They're all engineered for running at engine temps. Cold starts are what you need to be protecting your truck from, whether its 75 out or -20. No way in hell would I put a xW-40 in my truck. You're just making the engine function without oil longer at startup.
  14. Nov 6, 2017 at 8:57 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    I've been using Mobil1 Synthetic exclusively now in all my vehicles for 15+ years - I never have had an engine problem, even when pushing the mileage up to 8000 or 9000. I now pay the extra and just get the Extended Performance, which supposedly is good for 15k miles. I never push it that far, I just change the oil when I get around to it, before 10k miles.
  15. Nov 6, 2017 at 9:03 AM
    Pigpen
    Northwest Montana
    You're absolutely correct
  16. Nov 6, 2017 at 9:05 AM
    anthony250f
    Anthony
    San Diego, CA
    My truck runs better on 10w-40 then It ever did on 5w-30
  17. Nov 6, 2017 at 9:59 AM
    prux56
    prux56 Well-Known Member
    2012 White Tacoma TRD
    I've been using whatever synthetic is on sale and changing at every 6000 km but I have really been waiting for a good time to use the royal purple brand. Anyone have any luck with that?
  18. Nov 6, 2017 at 1:02 PM
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    Just switched from 5w20 M1 to 0w20 M1 for the winter.
  19. Nov 6, 2017 at 1:04 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    5-30 dino oil for past 180k miles
    Hoff likes this.
  20. Nov 6, 2017 at 1:07 PM
    Naumoff42
    Naumoff42 Well-Known Member
    Ohio
    2015 TRD Offroad
    5w30 signature series Amsoil. I'm going to send some samples off for analysis to see just how hard I can push this stuff.
    Buckwheat893 and PapaBear like this.
