What method do you use to tighten the axle nut?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TnShooter, May 20, 2020.
  1. Loved in 4WD
    14.3%
  2. Pry bar in the lug studs
    21.4%
  3. Screwdriver in the rotor against the caliper
    25.0%
  4. Other
    28.6%
  5. Some one pressing the brakes
    10.7%
  1. May 20, 2020 at 8:43 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    yep, Milwaukee on a full charge with red loctite for extra measure. Between that and the cotter pin it isn’t going anywhere. Then use the same gun the next time you need it off. No problems and I’ve had them off and on more than a handful of times.
  2. May 20, 2020 at 8:54 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I skip the loctite brother.
    Loctite to me is like a swear word, I don't mess with it and neither do I mess with GM or Nissan. Those are swear words also. :D
    snowsk8air2[QUOTED] likes this.
  3. May 20, 2020 at 10:37 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    On small passenger cars i put a prybar between the studs.
    On bigger stuff I'll put the wheel on and torque it with the vehicle on the ground, or mostly on the ground
    Crom likes this.
  4. May 20, 2020 at 11:00 PM
    TnShooter
    TnShooter [OP] The TacomaWorld Stray
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes, Sir.
    Then you can just chuck the dust covers and the center caps in trash.
    Job complete.
    Just kidding. I have thought of that, but it makes us lazy guys have to do more work.
    After all, the lug nuts are the hardest nuts to remove. Just ask the people that never rotate tires.
    That’s has to be the reason, right?
    I try to get Lifetime Free Rotation when I buy new tires.
    That way I have no excuse.
    Crom and b_r_o[QUOTED] like this.
  5. May 20, 2020 at 11:21 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Completely fucking agree!! I bought one for 300 thinking I'd return it after the job I was doing. 3 years later still have it and its cut down most jobs by at least half the time. Best tool purchase ever
  6. May 20, 2020 at 11:28 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I just use my 350 ft-lb electric impact and give it a few ugga-duggas. With this design, the axle nut torque doesn't set bearing preload, so some torque variation won't hurt things.
    Another way is to put the wheel on, lower the truck onto the ground, then torque the axle nut through the center hole. Keep in mind the FSM torque value would be too high if you grease the threads.
    Crom likes this.
  7. May 21, 2020 at 3:54 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Then it will be your turn for the surprise when she shows you her "impact gun"
    TnShooter[QUOTED][OP] likes this.
  8. May 21, 2020 at 8:10 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    a long alignment punch in the brake rotor cooling vents
    Crom likes this.
  9. May 21, 2020 at 8:15 AM
    Micatom33
    Micatom33 Under the Truck with Beer!
    Santa Cruz,CA
    2008 BSP DCSB
    This one should be 35mm 173ftlbs?! Careful with the impact guns to tight is no bueno for the hubs.
    Crom likes this.
  10. Jun 18, 2020 at 4:38 PM
    L. I. Taco
    L. I. Taco Member
    2008 Double Cab, Long Bed, TRD
    So the torque spec is 173 ft/lbs for the axle nut. But I, and probably most gearheads out there, have torque wrenches that only go to 150.
    Any good way to fudge the difference and get closer to 173?
  11. Jun 18, 2020 at 4:53 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Yeah mine only guess to 150. I basically get it to 150 with the torque wrench and then hit it with my impact for a second until the axle nut turns another 1/4 turn. Always worked for me
    Crom likes this.
  12. Jun 18, 2020 at 9:44 PM
    Muddinfun
    Muddinfun Well-Known Member
    Orileys has a loaner torque wrench that goes to 200.
  13. Jun 19, 2020 at 2:40 AM
    Delta09
    Delta09 OSHA Violator
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Get it to the 150 ft/lbs and then tighten it a little bit more with a breaker bar, exactly what I did. With the castle cap nut and cotter pin it ain't going anywhere.
  14. Jun 19, 2020 at 6:37 AM
    Blue Truck
    Blue Truck Well-Known Member
    what if the cotter pin doesnt line up at 173, looser or tighter?
  15. Jun 19, 2020 at 7:59 AM
    #35
    Muddinfun
    It’s not a castle nut. It’s a regular nut with a stamped sheet metal thing that goes over it that has a mismatched number of slots and flats. After you torque the nut, you try the thingy different ways til the slot lines up with the hole.
  16. Jun 19, 2020 at 8:01 AM
    #36
    Blue Truck
    The part store brands have a castellated nut
  17. Jun 19, 2020 at 8:05 AM
    #37
    eon_blue
    Azusa, CA
    Always go tighter to get the cotter pin to line up, never looser
  18. Jun 19, 2020 at 8:09 AM
    #38
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    The spelling is not strong with this one :rofl:
    A jack stand under one of the lugs works ok too, to get that elusive 173 ft*lbs
    eon_blue likes this.
  19. Jun 19, 2020 at 9:32 AM
    #39
    eon_blue
    Azusa, CA
    son of a bitch...all this time I've been walking around my yard trying to find rocks big enough to stack on my brake pedal lol. Why didn't I think of that
    SR-71A[QUOTED] likes this.
