What level lift should I do on my 2021 Tacoma SR5
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoLoverR, Apr 8, 2024.
  1. Apr 8, 2024 at 1:19 PM
    TacoLoverR
    TacoLoverR [OP] Member
    Scott
    2021 Tacoma SR5
    32" summit A/T
    I currently have 265/75/16 Summit A/T. I wanted to see if level lift is good or sus lift.
    Thanks!
  2. Apr 8, 2024 at 1:26 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I'm not clear on the question, but those tires should be fine without any lift (I ran the same size on stock suspension).
    Lots of options on lift types. The best one is the one that fits your needs (what you are trying to accomplish) and your budget.
    Welcome to TW.
    Stevie17 likes this.
  3. Apr 8, 2024 at 2:32 PM
    TacoLoverR
    Scott
    2021 Tacoma SR5
    32" summit A/T
    I was looking to do a level lift even out the truck.
  4. Apr 8, 2024 at 2:36 PM
    Clearwater Bill
    Billy
    Largo Florida
    You know the rake is engineered in for function, right?
    No hauling or towing in your future?
    Experiment. Put a couple hundred lbs over the rear axle. I bet it sits close to level. And you might like the ride change too
  5. Apr 8, 2024 at 2:53 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    Sounds like Bilstein 5100s in the front and reuse your coil springs would work for you. You can adjust ride height easily with them.
    boston23 likes this.
  6. Apr 8, 2024 at 2:58 PM
    boston23
    boston23 Well-Known Member
    Adam
    Bend, OR
    2019 SR5 DCSB 4x4
    By level lift you mean pucks aka spacers?
    Yeah that’s a sus lift. Gonna ride like harsh and put your front suspension at a more stressful geometry.
    my advice would be keep doing research on this forum until you can make an informed decision. The above post about billy 5100’s is a good route
    https://www.tacomaworld.com/threads/tacoma-lift-faq-guide-read-this.11282/
    Welcome to TW!
  7. Apr 8, 2024 at 3:20 PM
    TacoLoverR
    Scott
    2021 Tacoma SR5
    32" summit A/T
  8. Apr 8, 2024 at 4:12 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    IMO No Level look. Also Tacomabeast :bananadead:
  9. Apr 8, 2024 at 4:16 PM
    TacoLoverR
    Scott
    2021 Tacoma SR5
    32" summit A/T
    Ofc thanks!
  10. Apr 8, 2024 at 4:39 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Yeah, Tacomabeast isn't a popular TW choice and is not a listed vendor here. For reasons.
    Check the vendors listed here on TW. They are all solid choices, and if they prove not to be, they are severely violated by the TW community and de-listed.
    As Clearwater Bill mentioned, experiment a bit without spending too much. You still have not been super clear about your intentions other than leveling it, and appears you want to stick to a small budget. Here are my recommendations for leveling, and some additional ones for added lift front to back (note that none include spacer blocks).
    1. Add some weight to the bed as mentioned. It will ride better and level it out some. Nearly free depending on what you choose to put in the bed. If that is not what you are looking for . . .
    2. Bilstein 5100's front coilovers with stock springs set on one clip up from stock (0.85" I think). Any more than that and you may get a rough ride unless you have added weight to the front. If that doesn't do it for you . . .
    3. Now you get into more $, some decisions to be made, and many options out there. Kits with an add-a-leaf and full front coilover replacement that stick to 2" of lift or under and don't require a new UCA are the next economical choice that still maintains performance.
    Beyond that gets pricey, especially if you don't do the work yourself. Full leaf packs, UCA's, and complete coilover/shock replacement are next, which sometimes leads to needing an ECGS bushing on the front diff and figuring out your driveline angles to eliminate vibration. Requires $ and patience.
    Or, if all you care about is the look of a lift and just occasionally drive on a gravel road, just throw in some spacers and blocks and be done with it.
  11. Apr 8, 2024 at 5:21 PM
    boston23
    Adam
    Bend, OR
    2019 SR5 DCSB 4x4
    71tattooguy likes this.
  12. Apr 9, 2024 at 9:10 AM
    TacoLoverR
    Scott
    2021 Tacoma SR5
    32" summit A/T
    LOL! ok no Tacoma Beast..
  13. Apr 9, 2024 at 9:42 AM
    kaljam
    kaljam Well-Known Member
    Bill
    New Hampshire
    2023 TRD Sport wind chill pearl
    If you just want to level and are not off-roading then a spacer lift is fine. It WILL NOT change ride quality. Yes, it is not the best, but a 2" max front lift is fine. I've ran one for years without ANY issues, and they are the cheapest - about $50 on Amazon. Don't spend more - they are all the same. When I bought my current Tacoma I spent a little more and went with Bilstein 5100's. Better lift and more $$. By the way, I don't ever off-road so my ride quality comment is the way I use MY truck. I went with the top setting on the shock which gives 2" of lift and used a 1.5" block (yes a block - oh my) on the rear. The stance (in my opinion) is perfect.
  14. Apr 9, 2024 at 10:44 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
