What leaf pack/3 leaf progressive did you go with??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FlyFisherCJ, Feb 1, 2019.
  1. Feb 1, 2019 at 7:24 AM
    FlyFisherCJ
    FlyFisherCJ [OP] Well-Known Member
    Cameron
    Twin Falls ID
    2017 TRD OR DCLB
    Good morning and happy Friday TW group!
    Quick questions...but first some details. I have a 2017 TRD OR LB. Still stock suspension. I have a camper shell and a Decked toolbox installed. I also carry around some fuel, water, and basic "get myself out of trouble" tools.
    I am shopping around for suspension lifts and I want to know what you guys (that carry around a lot of bed weight) have gone with in terms of leaf packs, or AAL, or 3 leaf progressive packs like the one from Headstrong...
    Truck below for reference! Thanks for the help guys.
  2. Feb 1, 2019 at 9:45 AM
    FlyFisherCJ
    Cameron
    Twin Falls ID
    2017 TRD OR DCLB
  3. Feb 1, 2019 at 10:02 AM
    JS760
    JS760 Well-Known Member
    San Diego
    2017 DC Sport
    I don’t mud, crawl, off-road, overland or any of that stuff. The only thing i always carry are my golf clubs. But I still had a custom pack built by Alcan. It was well worth the extra $
    FlyFisherCJ[OP] likes this.
  4. Feb 1, 2019 at 10:12 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Regarding AALs whether single or 3 leaf progressive are all about the same quality so the difference in price is usually name branding.
    I went with Wheelers as it came with all new hardware and was the cheaper option. Not sure what you mean by alot of weight but if it's a fiberglass shell or loaded bedrack I'd consider a full leafpack replacement.
  5. Feb 1, 2019 at 10:44 AM
    FlyFisherCJ
    Cameron
    Twin Falls ID
    2017 TRD OR DCLB
    Thanks for the help guys! sounds like a full leaf pack replacement is the way to go.
  6. Feb 1, 2019 at 10:47 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Check out icon rxt, this what I'm going to use.
  7. Feb 1, 2019 at 11:21 AM
    Taco_Craig
    Taco_Craig Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    I usually have around 200 lbs in the bed under normal daily driving, and then I add gear (another 100+ pounds, probably) for the occasional camping/fishing/offroad trip. I have the Icon 3-leaf AAL, just because it was convenient and cheaper to go with it as part of the suspension kit, but all the AALs are probably the same. Anyhow, it's a little stiff in the rear (ugh, "stiff in the rear"... don't laugh) but it's not to bad and it maintains the factory rake.
  8. Feb 1, 2019 at 11:25 AM
    squeaky
    squeaky Well-Known Member
    Wisconsin
    2014 MGM DCSB Sport 4x4
    I went with a single Deaver AAL, but I'm kind of kicking myself now wishing I'd have just spent the extra $ and went with the heavy duty Dakar pack. Like you, I have a shell and I also tow a lot.
  9. Feb 1, 2019 at 12:11 PM
    FlyFisherCJ
    Cameron
    Twin Falls ID
    2017 TRD OR DCLB
    Thanks for the input!
    I don't tow much, but i keep a constant amount of weight back there, the Decked tool box isn't light, and i will also be adding a Prinsu bed rack shortly after the suspension upgrade. So i think the full heavy duty pack is the way to go.
  10. Feb 1, 2019 at 1:48 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    HD Dakar here. I have a cap, full prinsu and usually between 3-500# of gear and work stuff in the bed. I also tow weekly.
    The Dakars are fine, but I promise you they will squeak. If that is no big deal to you they are pretty good. Ride is fine, firm, but not jarring. Full HD pack with 3 degree shim gave me about 2.5"-3" of lift.
  11. Feb 1, 2019 at 1:50 PM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    I have the HS AAL which is great but long term I want a full pack. I have a shell, Decked and slowly adding more stuff. lol
  12. Feb 1, 2019 at 1:54 PM
    Dr. Emmett Brown
    Dr. Emmett Brown Well-Known Member
    Ordered my Dakar HD pack last week. Should be here in a few days. I'm ordering the leaf pack liners as well to put on each leaf prior to installing pack to prevent any squeaking like mentioned above. I have roughly 200 pounds daily in the bed and push that number closer to 450 every few weeks when I go fishing/camping
    Will give updates once installed.
  13. Feb 1, 2019 at 2:01 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Deaver U402 Expedition Stage 3 on my truck. It's a second gen, but 3rd gen uses the same pack. I think the Deavers have been great, nice progressive pack, so not a harsh ride when not loaded down. Obviously Stage 3 would be too much for you (2.5inch lift at 700-1000lbs constant bed weight), but stage 1 is 0-300+, and stage 2 is 400-600lbs constant. I believe lift is a bit less on the 3rd gen.
  14. Feb 1, 2019 at 2:07 PM
    Falldownhard
    Falldownhard @tacomavanzandt
    Evan
    San Diego
    2015 Toyota Tacoma TRD Off Road 4x4
    Things and Stuff.
    I went with the heavy duty Dakars, I have not had any squeaking at all, I hope I didn't just jinx myself. I had a rack and tent on when I went with the heavy duty leaf pack, Now I just have a shell so it was rough until I pulled one of the overload springs. Rides much smoother now. I imagine when I load it down with gear or throw another roof top tent onto my shell I may need to put the overload back in.
  15. Feb 1, 2019 at 2:26 PM
    FlyFisherCJ
    Cameron
    Twin Falls ID
    2017 TRD OR DCLB
    Sounds just like my setup! how much lift did the HS progressive AAL give you over stock?
    And by chance, what shocks did you go with on the back? and what did you do up front to match the rear?
  16. Feb 1, 2019 at 2:26 PM
    FlyFisherCJ
    Cameron
    Twin Falls ID
    2017 TRD OR DCLB
    thanks for all the help guys. It really helps to get first hand knowledge vs. just research and hope for the best.
    YF_Ryan likes this.
  17. Feb 1, 2019 at 2:31 PM
    Rob Daman
    Rob
    So Cal
    17 OR 6MT
    a lot
    2 inches with OL. TRD Pro bilsteins... i did a video
    https://youtu.be/9mdo-GnoVhY
