What kind of tailgate lock do you recommend?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YankeeInfantry9, Jul 26, 2016.
  1. Jul 26, 2016 at 6:43 AM
    YankeeInfantry9
    YankeeInfantry9 [OP] Member
    Colton
    South of Pittsburgh, Pa
    13 TRD Sport
    i have a 13 dclb and I am looking to be able to lock my tailgate. What ones do you recommend without breaking the bank?
  2. Jul 26, 2016 at 7:57 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Countless discussions on this issue.
    Wrap two(2) #20 hose clamps around the lift point on right rear - passenger side. This will stop most parking lot thefts. If you live in a bad area, nothing is going to save your gate as they'll have all night to work on it.
  3. Jul 26, 2016 at 8:03 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Really only option is a pop and lock.
    Those things are hit or miss, some have luck others say they junk.
  4. Jul 26, 2016 at 8:06 AM
    YankeeInfantry9
    Colton
    13 TRD Sport
    Really my main thing is wanting to lock the gate so people can't get in it. I have a Tono and want the lock to be a deterrent if I want to have tools and stuff back there
    idahbro likes this.
  5. Jul 26, 2016 at 9:00 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I like My Pop N Lock.
    It was my first mod. Other than my fuzzy dice ;)
    Pop&LockLLC likes this.
  6. Jul 26, 2016 at 2:59 PM
    glock24
    glock24 Well-Known Member
    Bought a Pop-n-Lock. It managed to quit working after two months.
    I sure wish there were better options
    idahbro likes this.
  7. Jul 26, 2016 at 5:38 PM
    nobescare
    nobescare Well-Known Member
    Mark
    43.5448° N, 80.2482° W
    2019 Highlander SE
    My 2005 prerunner had frame failure Aug 2024
    Same here along with the hose clamps (no fuzzy dice )
  8. Jul 26, 2016 at 5:40 PM
    big_jarv
    big_jarv Well-Known Member
    2020 TRD Pro
    EDDO likes this.
  9. Jul 27, 2016 at 12:19 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    I have a Pop n lock
    It's the model that uses a key (not electric) and when you install it you can use your normal ignition key.
    Not real robust but if you'er gentle it works.
  10. Jul 27, 2016 at 12:35 PM
    seoulja99
    seoulja99 Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
    I also have a tonneau cover and added a tailgate lock to secure my gear in the bed of my taco.
    At first, I went with the Pop & Lock PL5400 Black Manual Tailgate Lock with BOLT Codeable Technology for Toyota Tacoma
    <https://www.amazon.com/Pop-Lock-PL5...69647531&sr=8-1&keywords=pop+and+lock+tacoma>
    And then I got annoyed with having to turn off my engine to open up the tailgate, so I added the Pop & Lock PL8525 Power Tailgate Lock for Toyota Tacoma (Power Lock Add-on Kit)
    <https://www.amazon.com/Pop-Lock-PL8...s=pop+and+lock+for+toyota+tacoma+-+2005-2015>
    If I had known better, I would have gone straight with this:
    Pop & Lock PL8521 Power Tailgate Lock for 05-12 Toyota Tacoma
    <https://www.amazon.com/Pop-Lock-PL8...p+and+lock+for+toyota+tacoma+2005-2015+elect>
    or better yet this one:
    Pop & Lock PL8540 Tailgate Lock
    <https://smile.amazon.com/Pop-Lock-P...p+and+lock+for+toyota+tacoma+2005-2015+elect>
    crackils likes this.
  11. Jul 27, 2016 at 12:43 PM
    hogfatherBBQ
    hogfatherBBQ Member
    2015 DCSB TRD Off Road Prerunner
    "Bob" Rear view Mirror Roll-X bed cover Pop n Lock tailgate lock w/Bolt Tech
    I also recommend the Pop & Lock PL8540. The mechanism behind the handle broke on my first installation but P&L stood by the product and overnighted a new one to me without a lot of questions. No problems since then (over a year) and the way it works with my factory FOB and ignition key make it worth the price (IMHO). The handle is not as solid as the OEM handle but otherwise it is a good mod as I often store valuable stuff in my bed under a BAK Roll-X tonneau cover.
  12. Jul 28, 2016 at 2:15 PM
    UBYBC
    UBYBC Well-Known Member
    2014 Tacoma TRD OR
    Pop n lock with keyed lock and electronic accuater. One year still works well.
  13. Jul 28, 2016 at 9:01 PM
    Reddwarf
    Reddwarf Member
    2015 Blue Tacoma V-6, 4x4 , TRD Tow package, 6 Speed Standard Trans....
    I've had my Pop & Lock PL8540 Tailgate Lock in for a year...had it installed when they put on the canopy after buying it new. Other than being noisy and having to unlock the Passenger door to get it unlocked I am very happy with it. I have also used the key a few times and have no problems. Only wish it had come standard equip along with Heated Mirrors.
  14. Jul 28, 2016 at 9:07 PM
    Shibbyjeep
    Shibbyjeep Well-Known Member
    Trent
    Greenville SC
    2014 Tacoma DCSB TRD OR
  15. Jul 29, 2016 at 8:55 AM
    Jagfan904
    Jagfan904 Well-Known Member
    Brandon
    Silver double cab 07
    Painted rims, Stero, speakers, truck box, k and n cabin and engine air filter
  16. Jul 29, 2016 at 9:24 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
  17. Jul 29, 2016 at 9:28 PM
    YankeeInfantry9
    Colton
    13 TRD Sport
    What's the difference from the 8521 and the 8540?
  18. Jul 29, 2016 at 9:44 PM
    moondeath
    Pa, Gardners
    8521 is the lock actuator with wiring that goes inside the tailgate. It keeps the oem tailgate handle from opening. The 8540, I think, also comes with a tailgate handle with key lock. Ive had the 8521 for years without issue. Plus you use the factory tailgate handle, which is much nicer than aftermarket handles.
    OldManTacoFeels and seoulja99 like this.
  19. Aug 1, 2016 at 10:26 AM
    YankeeInfantry9
    Colton
    13 TRD Sport
    But the only thing I would be worried about is not being able to get it unlocked if there was a malfunction. If it messes up with the aftermarket handle you can use the key lock
    2ndGenOffRoad likes this.
  20. Aug 1, 2016 at 10:34 AM
    moondeath
    Pa, Gardners
    I dont worry about this because I know how to open my tonneau even if the tailgate is closed. The tailgate access panel can be removed in the closed position.
    BG_Sea likes this.
