What kind of headers should I get for my Tacoma
Discussion in '4 Cylinder' started by Ismael_Navarro, Jul 3, 2020.
  1. Jul 3, 2020 at 7:39 PM
    Ismael_Navarro
    Ismael_Navarro [OP] Member
    Ismael
    1997 Black Tacoma RWD
    Magnaflow muffler, cold air intake, LCE headers, throttle body spacer, short shifter, cat deleted.
    Hello I have a 97 4cyl Tacoma 5 spd. I have no mods on my truck but would like to start my build with some headers but I have no idea what to look for or what to get. All I know is that a buddy of mine suggested that stainless steel is the way to go. please help!thanks!
    i believe it’s a 2.4 L
  2. Jul 3, 2020 at 7:58 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You have a 4 cylinder, so you will only get 1 header.
    With that said, our 4 cylinders have great torque running factory exhaust.
    The headache of trying to get the computer to accept the header is really not worth it.
    The extra power of a header won't be noticed until you are above 4000 rpm. I can't remember the last time I saw 4000 rpm.
    Our trucks are pretty well engineered from the factory. Give it some thought before you start working with the emission system (the exhaust is part of the emission system).
    If you are in a state that requires emission testing, you are most likely not gonna pass.
    Give it some thought and don't be afraid to ask questions. We got some pretty bright peeps on this site.
    whatstcp likes this.
  3. Jul 3, 2020 at 7:59 PM
    koditten
    Kirk
    Central Michigan
    In addition, welcome!
  4. Jul 3, 2020 at 8:02 PM
    Ismael_Navarro
    Ismael
    Thanks a lot for the information! Do you know where I could start to possibly push out any more power out of my truck or what I could get ?
  5. Jul 16, 2020 at 9:25 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    I put an ebay long tube. It was about $100, I noticed a substantial increase in power all the way across the board. I am on 33x12.5 and 4.10 gears. There is also a high flow cat, so I have a constant check engine light. The exhaust note is much better and has a deep growl.
  6. Jul 16, 2020 at 9:31 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I'm running a Doug's Headers ceramic coated nickle finish header on my Supercharged 4cyl
    iamroddy likes this.
  7. Jul 16, 2020 at 9:35 PM
    Old green toyota
    Sacramento,CA
    Oil leaks
    That looks really nice! How does it perform.
  8. Jul 16, 2020 at 9:39 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Woke up my motor as it is a Tri Y design with merge collectors
  9. Jul 16, 2020 at 9:41 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    The newer stock manifolds (01-04) are also a known upgrade. Won’t be as drastic as a nice set of tri y headers though
  10. Jul 17, 2020 at 9:39 PM
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    I have Doug Thorley long tube header and there was a tiny bit of increase in acceleration, nothing worth paying a few hundred for. I got a K&N intake and there was a noticeable increase in acceleration in the butt dyno.
    Check LC Engineering out, they have everything you're looking for.
  11. Jul 17, 2020 at 9:42 PM
    BikerinBlak909
    SoCal
    96 LT 5 lug
    Have you tried the o2 simulator? Supposed to give a false reading to keep the CEL off
    https://www.urdusa.com/urd-rear-o2-simulator-2rz-fe-2-4l-3rz-fe-2-7l/
  12. Jul 18, 2020 at 1:21 AM
    Old green toyota
    Sacramento,CA
    Oil leaks
    I need to look into that. I tried an o2 extension for the and it only prolonged the light coming on.
    The header I bought was from DNA motoring and was only $100 but it fit perfectly and doesnt leak
    Speshuled619 likes this.
