What is this part in the engine bay?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TK7692, Apr 2, 2017.
  1. Apr 2, 2017 at 1:22 PM
    TK7692
    TK7692 [OP] Camo on Camo
    TK
    South Bay, CA
    2015 MGM DCLB TRD Sport 4x4
    Not an overbrander.
    I'm planning to mount my snorkel soon and also mount my air compressor in the engine, where another user has also mounted his.
    However, in the spot where he mounted his compressor, I have this component (circled in red below) in the way. Is this part of the stock intake system? Any insight would be appreciated.
  2. Apr 2, 2017 at 1:31 PM
    92PathSE
    92PathSE Well Known "member"
    GA
    Air Induction Pump. You'll need to keep that POS or the truck will not run very well.
    edit: Here's one that has been moved. You could try something like that. Air Pump loud after CAI mod
    Gunshot-6A, Norton and EDDO like this.
  3. Apr 2, 2017 at 1:46 PM
    TK7692
    TK
    South Bay, CA
    Not an overbrander.
    Is it in a different spot on Off Road models?
    GrandTheftAngel likes this.
  4. Apr 2, 2017 at 1:47 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    You can remove it, but you'll need one of the Hewitt-tech bypass kits and pump replacement packs. Its not cheap ($500), but cheaper than replacing it, when it goes bad.
    Norton likes this.
  5. Apr 2, 2017 at 1:47 PM
    92PathSE
    GA
    Some years have it and some don't.
    SR-71A likes this.
  6. Apr 2, 2017 at 1:48 PM
    RacecarGuy
    Houston, Texas
    '12 DCSB OR
    Its only on the 2012-15's I think.
  7. Apr 2, 2017 at 1:52 PM
    TK7692
    TK
    South Bay, CA
    Not an overbrander.
    Ah, that makes sense. Thanks for the insights.
  8. Apr 2, 2017 at 1:53 PM
    TK7692
    TK
    South Bay, CA
    Not an overbrander.
    Sounds like the general consensus is: don't touch it, mount my air compressor somewhere else.
  9. Apr 2, 2017 at 1:56 PM
    RacecarGuy
    Houston, Texas
    '12 DCSB OR
    Slee Offroad makes a mount for the ARB compressors up by the windshield fluid reservoir. http://www.sleeoffroad.com/products/products_air.htm
    Gunshot-6A likes this.
  10. Apr 2, 2017 at 1:57 PM
    TK7692
    TK
    South Bay, CA
    Not an overbrander.
    Thanks, I've seen that. I'll look into it.
  11. Apr 2, 2017 at 2:03 PM
    Bishop84
    Bishop84 Well-Known Member
    Those stupid air pumps are the only real draw back to the facelift models, they make the exhaust red hot too even after a short drive. Along with a frustrating code that is only solve with expensive repairs.
    They are the solution for heating the cats up without moving the cats any closer to the engine bay (and creating high underhood temps)
    I would do a delete rather than a relocation if you are past warranty. Save the parts and block off the exhaust ports with tin. Like the old EGR block off days.
    https://www.tacomaworld.com/threads...pass-kit-2012-4-0-updated-21-oct-2016.394629/
    Gerard6778 likes this.
  12. Apr 2, 2017 at 2:09 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    When I bought my '09 last Fall the air injection pump was the secondary reason '12 to '15 Tacomas were not on my shopping list--the primary reason was what it cost '12-'15s in AAA+ condition.
    I think the 4.0 became over the years a "dirty" engine per CAFE standards, Toyota added the air injection to get it to pass while they developed and retooled for the 3.5. Motorcycles have been bolting on air injection pumps for dome years to make their engines meet emission standards--both my '03 Burgman 400 and '06 Silver Wing 600 had them--I say "had" because they went away quite quickly after I bought the bikes...
  13. Apr 2, 2017 at 3:41 PM
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
    Sub for what you end up doing to install your snorkel and compressor :thumbsup:
  14. Apr 2, 2017 at 3:53 PM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    I moved mine in front of the washer fluid reservoir, near the radiator hose. Took some 1/4"x2" steel and bent up a bracket.
  15. Nov 19, 2019 at 7:09 PM
    Suicyco
    Suicyco Well-Known Member
    14 ac 4x4
    Is that why i have an empty spot there in my ‘11? Looks like something’s missing
  16. Nov 19, 2019 at 7:13 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    SLEE Offroad offers brackets to mount your compressor forward of the windshield washer reservoir.
    TK7692[QUOTED][OP] likes this.
  17. Jan 16, 2020 at 5:53 AM
    E-Paz 732NJ
    E-Paz 732NJ Well-Known Member
    Eric
    NJ
    2015 Tacoma TRD-OR
    Why does it have a knob? And what does it do if you turn it?
  18. Jan 16, 2020 at 7:28 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    It's not a knob, its part of the filter intake plenum for the secondary air injection pump. Some may have removed the plastic cover and removed the faulty sponge filter and replaced that plastic cover with an external breather filter like myself.
    Edit: https://www.amazon.com/Uni-Filter-U...ords=1inch+uni+breather&qid=1577385491&sr=8-1
    This breather filter, 14$ for piece of mind vrs a costly repair to a limp mode truck over a broken down sponge filter. It'll look like this when installed correctly: https://www.tacomaworld.com/threads/identify-this-part.644331/#post-22321560
    -J
  19. Jan 16, 2020 at 10:16 AM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    They extended the warranty on that part to 10 years, unlimited miles, so nobody is out of warranty on that system yet.
  20. Jan 16, 2020 at 12:19 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    I'm so glad that my 2012 doesn't have it!!!!
