What is this loud popping noise when I turn my front wheels out of a parking spot?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fore, Mar 22, 2011.
  1. Mar 22, 2011 at 5:10 PM
    Fore
    Fore [OP] Well-Known Member
    07 PreRunner
    Help, I still don't know what this loud popping sound is when I turn my front wheels out of a parking spot it's starting to get worse and happens all the time now? It's very loud and sounds like something is going to bust, it's becoming sooo annoying!:confused:
  2. Mar 22, 2011 at 5:11 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    its uhh it happened to my friend... shit. rubber bushings i think it was. ill try to findout for you.
  3. Mar 22, 2011 at 5:37 PM
    sloppyjoe
    sloppyjoe They are more like guide lines.
    All Over
    Silver and simple
    Non
    Sounds to me like a CV shaft in the front end is going. When they crap out they make that kind of noise, especially bad when turning. Check the rubber boots on each of the front shafts to see if there is a visable tear or crack, as that is usually a good sign that the failure is there. Good luck
  4. Mar 22, 2011 at 5:37 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    I would have to guess at wheel bearings. Jack the front of the truck up and grab the wheel at top and bottom and push/pull if you feel any play at all the wheel bearings are bad. I've seen quite a few threads on here about wheel bearings going out.
  5. Mar 22, 2011 at 5:54 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    i have been having this exact problem for well over a year now....
    and lets just say alot of miles driven and i wheel the piss out of it and nothing has broken ...."yet":eek:
    i gave up:rolleyes:
  6. Mar 22, 2011 at 6:04 PM
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
    Just tint and ppl for now.
    Is it only when the steering wheel is at full lock?
    Pap
  7. Mar 22, 2011 at 6:45 PM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    tie rod ends. grease em
  8. Mar 23, 2011 at 12:56 AM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    Could be your ball joints, I have some sort of clunk when I turn the wheel and I know my upper ball joints are out its just a matter of getting time to fix them
  9. Mar 23, 2011 at 1:04 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    I would say your axle seals, but you don't have them so most likely your tie rod ends... I had the same problem...
  10. Mar 23, 2011 at 1:05 AM
    dep3091
    dep3091 Well-Known Member
    Southern Inland Empire
    White 05 Tacoma 4x4 LongBed
    2.5" Donahoe/Icon Front Coilovers, Icon Rear Reservoirs, K&N Filtercharger, Magnaflow Cat-Back, Bajarack Mule mounted over Bed on Thule Xsporter, Bajarack Dual Fuel/H20 Can holder, All-Pro front bumper w/PIAA Fogs, KC Rallye 800 Pencils, Custom Windshield Crack
    Have you replaced your stock tires with larger tires?
  11. Mar 23, 2011 at 6:00 AM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    Most likely it's your lower control arm bushings. Happens on mine too.
  12. Mar 23, 2011 at 7:54 AM
    sloppyjoe
    All Over
    Silver and simple
    Non
    Ahh, Thanks. that would not be his issue then. Sry ;)
    I always assume every one has the 4x4 for some reason...
  13. Mar 23, 2011 at 7:59 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    mee too.....well that elimates his cv's and mine too....:D
  14. Mar 23, 2011 at 8:10 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    cv joints
  15. Mar 23, 2011 at 8:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    More info:
    Are you lifted?
    Have you gone off roading recently (dirt roads, gravel, etc.)?
  16. Mar 23, 2011 at 8:16 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Has OP had alignment recently? I noticed this too but not at full right on steering stops. Looked under truck and another feature of the dealership alignment that robbed me of caster when they rebuilt my leaky steering rack was that whoever attempted to align it had the outer tie rod end on the passenger side angled up where it looked to be hitting on the spindle where it connects to tie rod. Metal on metal squawk and not at full lock on the steering. Making them try again and give me back 2.5 caster while they are at it. Lame half ass bullshit..................
  17. Mar 23, 2011 at 8:52 AM
    Syncros
    Syncros Well-Known Member
    If its happening with the steering at full lock, it's the little nylon cap on the steering stop. It's most likely missing, what you are hearing is the steel parts rubbing together and creaking. Common problem on Toyota's, putting the steering to full lock and letting it rub the stop isn't really good for the vehicle anyway.
    Don't go replacing a bunch of parts without checking these first, dead simple fix.
    dk_crew likes this.
  18. Mar 23, 2011 at 6:51 PM
    Fore
    07 PreRunner
    Thanks everyone, a lot of good suggestions. To reply to a couple of you, no the truck is not lifted, it's never goes off roading, that's why I bought a prerunner. The tires are one step up from stock. It doesn't happen when I hit a bump or anything, just when I'm turn slowly out of a parking spot, left, right it doesn't matter same loud metal pop. Really don't want to go to the stealership to troubleshoot this, we have the worst Toyota Dealership in the state of Virginia. (Berglund Toyota) bunch of scam rip off artist. I guess I'll just live with it till something breaks.
  19. Mar 23, 2011 at 6:52 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    :rofl::thumbsup:
  20. Mar 23, 2011 at 7:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You may want to check the lower control arm bolts, and make sure they are tight. Also, check the springs to see if a rock got in them.
