What is this compartment in my overhead console
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NathanG223, Sep 22, 2020.
  1. Sep 22, 2020 at 1:38 PM
    NathanG223
    NathanG223 [OP] Well-Known Member
    Nathan
    TX
    2007 Black Tacoma SR5 PreRunner
    Bruh Horn - Redneck Bed Drawers - Custom Rock Sliders - Head Unit Swap - DD Ditch Lights - Blacked Out
  2. Sep 22, 2020 at 1:40 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Someone probably had a garage door opener behind that push button on velcro
    NathanG223[OP] likes this.
  3. Sep 22, 2020 at 1:42 PM
    NathanG223
    Nathan
    TX
    Thats what I was thinking, but what is it’s reason from the factory?
  4. Sep 22, 2020 at 1:44 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Not sure as both of mine are sunglasses holders in my 15, but I believe in 2005 to 2009 or 2008 it had a compass temperature gauge there.
  5. Sep 22, 2020 at 1:45 PM
    Muddinfun
    Muddinfun Well-Known Member
    Condom dispenser.
  6. Sep 22, 2020 at 1:45 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    His idea is better
  7. Sep 22, 2020 at 1:54 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Yep that’s
    for a garage door opener. You can set up your opener in that compartment and then just push the button to open/close the door.
  8. Sep 22, 2020 at 2:17 PM
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    Only if that truck doesn't get to hot inside... or if they are replaced or used (correctly) regularly.
  9. Sep 22, 2020 at 2:25 PM
    Lucifer1
    Lucifer1 Well-Known Member
    Lucifer
    Plano TX
    2023 Silver TRD Sport Access cab V6 automatic
    Toyota Bed divider
    Yup, its just that simple, a mounting place for your garage opener,and as not all openers are the same they give you the extra spacer blocks for adjustments.
  10. Apr 5, 2021 at 9:17 PM
    NathanG223
    Nathan
    TX
    I hope you know that this is the post that auto fills when I search for this website so I see it every single day lmao
    Slimjim19 likes this.
