What is this button for?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SSCHUU, Aug 29, 2017.
  1. Aug 29, 2017 at 6:02 PM
    SSCHUU
    SSCHUU [OP] Well-Known Member
    Eric
    Southern California
    2017 Tacoma 4x4
    I accidentally found this button today as I was reaching for the hood release.
    Is this for tire pressure?
  2. Aug 29, 2017 at 6:04 PM
    SSCHUU
    Eric
    Southern California
    2017 Tacoma 4x4
    When would you need to set it?
  3. Aug 29, 2017 at 6:04 PM
    Rackness
    Rackness Well-Known Member
    Maryland
    17' Tacoma
    Working on it.
    Ejector seat. Manuel told me.:anonymous:
    Wheresmytaco and Gen1FTMFW like this.
  4. Aug 29, 2017 at 6:09 PM
    20RustyTaco06
    20RustyTaco06 Well-Known Member
    Allen
    Dublin, GA
    2006 sr5 Tacoma DBL cab auto/4wd
    Complete Pioneer audio Supreme Suspension 3" spacer lift 255/75-17 Kuhmos/Sport wheels 1.25" wheel spacers Tint
    Naw, man. That's auto-deflate for the Desert Runners. Pre-set to 15 psi. :burp:
    mtip likes this.
  5. Aug 29, 2017 at 6:15 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    When you set a new pressure, rotate tires or change tire size.
  6. Aug 29, 2017 at 8:29 PM
    SSCHUU
    Eric
    Southern California
    2017 Tacoma 4x4
    Makes sense
  7. Aug 29, 2017 at 9:13 PM
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    ....is it a simple process or do you just press the button and thats all......sorry for dumb question, but i am stumped
  8. Aug 29, 2017 at 9:15 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Pretty sure there's a sequence;
    1)Tap 3 times
    2)push once
    3)tap 3 more times but in a slower frequency
    4)wiggle for 5 seconds BUT NO LONGER than 7 seconds
    5) finally, tap 1 time to finish
    But really.. it's in your manual
  9. Aug 29, 2017 at 9:17 PM
    r1200gs4ok
    O. K.
    Irvine, Ca
    :rofl: i have moved and misplaced my manual...dont keep it in truck
  10. Aug 29, 2017 at 9:25 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    I thought it was up, up, down, down, left, right, left, right, B, A?
  11. Aug 29, 2017 at 9:25 PM
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    ■ How to initialize the tire pressure warning system Vehicles without a smart key system: Park the vehicle in a safe place and turn the engine switch to the “LOCK” position. Vehicles with a smart key system: Park the vehicle in a safe place and turn the engine switch off. Initialization cannot be performed while the vehicle is moving. Adjust the tire inflation pressure to the specified cold tire inflation pressure level. (P. 577) Make sure to adjust the tire pressure to the specified cold tire inflation pressure level. The tire pressure warning system will operate based on this pressure level. Vehicles without a smart key system: Turn the engine switch to the “ON” position. Vehicles with a smart key system: Turn the engine switch to IGNITION ON mode. Press and hold the tire pressure warning reset switch until the tire pressure warning light blinks slowly 3 times. Vehicles with a multi-information display: “- -” will be displayed for inflation pressure of each tire on the multi-information display while the tire pressure warning system determines the position of each tire. When position of each tire is determined, the inflation pressure of each tire will be displayed on the multi-information display. 1 2 3 4 7-3. Do-it-yourself maintenance 465 7Maintenance and care  Vehicles without a multi-information display Vehicles without a smart key system: Wait for a few minutes with the engine switch in the “ON” position and then turn the engine switch to the “LOCK” position. Vehicles with a smart key system: Wait for a few minutes with the engine switch in IGNITION ON mode and then turn the engine switch off.  Vehicles with a multi-information display Drive the vehicle at approximately 25 mph (40 km/h) or more for approximately 10 minutes. When initialization is complete, the inflation pressure of each tire will be displayed on the multi-information display. Initialization will take longer than approximately 10 minutes if the vehicle is stopped for a long time, such as at traffic signals.
    Tire size P245/75R16 109S Tire inflation pressure (Recommended cold tire inflation pressure) Front tires: 32 psi (220 kPa, 2.2 kgf/cm2 or bar) Rear tires: 32 psi (220 kPa, 2.2 kgf/cm2 or bar) Spare tire: 32 psi (220 kPa, 2.2 kgf/cm2 or bar) Wheel size 16  7 J, 16  7 JJ Wheel nut torque 83 ft·lbf (113 N·m, 11.5 kgf·m) Tire size 265/70R16 112T Tire inflation pressure (Recommended cold tire inflation pressure) Front tires: 30 psi (210 kPa, 2.1 kgf/cm2 or bar) Rear tires: 30 psi (210 kPa, 2.1 kgf/cm2 or bar) Spare tire: 30 psi (210 kPa, 2.1 kgf/cm2 or bar) Wheel size 16  7 J, 16  7 JJ Wheel nut torque 83 ft·lbf (113 N·m, 11.5 kgf·m) Tire size P265/65R17 110S, P265/60R18 109H Tire inflation pressure (Recommended cold tire inflation pressure) Front tires: 29 psi (200 kPa, 2.0 kgf/cm2 or bar) Rear tires: 29 psi (200 kPa, 2.0 kgf/cm2 or bar) Spare tire: 29 psi (200 kPa, 2.0 kgf/cm2 or bar) Wheel size 17  7 1/2 J, 17  7 1/2 JJ, 18  7 1/2 J Wheel nut torque 83 ft·lbf (113 N·m, 11.5 kgf·m)
    20RustyTaco06 and shakerhood like this.
  12. Aug 29, 2017 at 9:33 PM
    MESO
    State of Jefferson
    Ahhh memories of my old game shark hacker box
    Mi2CaMatt likes this.
  13. Aug 29, 2017 at 9:34 PM
    SSCHUU
    Eric
    Southern California
    2017 Tacoma 4x4
    Super useful thanks!
  14. Aug 29, 2017 at 9:35 PM
    ajmogen
    Aaron
    Wisconsin
  15. Aug 29, 2017 at 10:32 PM
    Oldman808
    Oldman808 Well-Known Member
    Planet Earth
    2023 Taco TRD Sport
    And by all means be sure to check your spare tire pressure now and then. It also has the tpms I believe...
    Haven't checked my 16 yet but from experience with my 06 I couldn't reset the tpms because the spare was low.. :anonymous:
  16. Aug 29, 2017 at 10:34 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think 2008 or 2009 was the last year a Tacoma had TPMS in the Spare.
  17. Aug 29, 2017 at 10:35 PM
    Oldman808
    Planet Earth
    2023 Taco TRD Sport
    Whew thanks no need to check then !
    Thanks Shakerhood
    shakerhood[QUOTED] likes this.
  18. Aug 29, 2017 at 10:37 PM
    shakerhood
    Southern Ohio
    No problem, I usually pull the Spare down twice a year to check, last thing you want is for that to be flat
    Oldman808[QUOTED] likes this.
  19. Aug 29, 2017 at 11:14 PM
    r1200gs4ok
    O. K.
    Irvine, Ca
    which left.......you military left...right :rofl:
  20. Aug 29, 2017 at 11:22 PM
    r1200gs4ok
    O. K.
    Irvine, Ca
