What is this air hose?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JustADriver, Aug 27, 2021.
  1. Aug 27, 2021 at 4:15 PM
    JustADriver
    JustADriver [OP] Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    IMG_0598.jpg 1996 Tacoma.
    Very flexible, large air hose of some kind at the back of the engine compartment. For cabin vent? Just gotta find out what it's called.
    It looks ok but there's electrical tape on the narrow portion in the middle you see, some peeling off, and I'd like to replace the part if someone had taped it up for some reason, while I'm ordering other parts. I'm not gonna pull the rest of the tape off yet.
    On one end of the hose it says EPDM. On the steel plate on the back of the engine bay it connects to it says 7157-7705 Y1 .
  2. Aug 27, 2021 at 4:31 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    It is not an air hose. It is the wire harness from the ecu to the engine. Don't cut or mess with any of the wires, if you do your truck will not work properly.
    Wulf likes this.
  3. Aug 27, 2021 at 4:41 PM
    JustADriver
    Ah ok, so no need to worry about the electrical tape on it since it doesn't need to be sealed perfect and just needs to protect the wires?
    Wulf likes this.
  4. Aug 27, 2021 at 4:44 PM
    Tour991
    James
    South Reno/Tahoe
    You can pull the old tape off and retape it but I wouldn't put a knife near it.
    Wulf likes this.
  5. Aug 27, 2021 at 5:32 PM
    Monkeyman
    Monkeyman Member
    Does anyone know the part number for the black clamp on this wire harness? My old one is busted but has a 28 imprinted on it.
  6. Aug 27, 2021 at 7:57 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    That’s the main artery of your truck. It has all the wiring from the ECU, which is directly behind it.
    Tour991 and Wulf like this.
