What is the upper limit of transmission fluid temperature?
Discussion in 'Towing' started by J Gibson, Oct 21, 2012.
  1. Oct 21, 2012 at 3:34 PM
    J Gibson
    J Gibson [OP] Well-Known Member
    J
    Knoxville, TN
    '12 DCSB,4wd,TRD Sport, tow pkg, MGM
    katzkin leather, toyota step bars, pro grill, advent overhead DVD player, cargo extender, bed mat, husky liners, impulse digital brake controller, avs bugflector, tinted windows, Firestone ride-rite air bags, ARE camper top with tool doors, ScangaugeII, ProEFX tow mirrors, ImMrYo rearview mirror lift bracket, Salex glove box and console organizers, 2020 Tacoma Pro styled wheels, 265/70 r17 Michelin MS2 tires, LED map lights, drivers seat extended and raised, ram ball tech deck installed, blacked out badges, tinted taillights, upgraded climate control knobs, ultimate headlight upgrade with Osram superbrights and wiring harness along wit OEM pro headlight housings.
    Does anyone know at what temperature the transmission fluid becomes dangerously hot? How long can it remain at that temperture before damage occurs?
  2. Oct 21, 2012 at 3:36 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    If I saw 250F I would pull over and let it cool.
  3. Oct 21, 2012 at 3:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Normal can run between 180* and 200*. Over 300* can be bad, with parts beginning to break at 350*
  4. Oct 21, 2012 at 3:46 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    and if your checking it and its not bright red, that could indicate that its gotten too hot, and maybe you should look into changing it.
    I am not a expert with auto trans, but this is what I have always been told.
    a good synthetic brand of fluid has a higher heat point but, but its best to never test any fluid on their heat range, for your trans sake.
  5. Oct 21, 2012 at 3:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The fluid breaking down due to heat is not as much the problem, as the parts breaking due to heat. Most all fluids wont break down until over 500*. many parts in the valve body can break at a much lower temps.
  6. Oct 21, 2012 at 7:00 PM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    actually that is the problem, when it gets too hot it looses its viscosity, and the damage can happen very fast.
  7. Oct 21, 2012 at 7:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    if it changes from Red to brown, it could mean it was over heated, but in most cases, in a propperly operating vehicle, it means its getting time to change it. just like engine oil, part of the tranny fluids job is to keep suspended particles that could cause damage/wear.
  8. Oct 21, 2012 at 7:09 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    210-220* being the maximum you should probably ever want it at. At about 260* Is when the fluid begins to break down and you should probably let it cool down as poster #2 suggested.
  9. Oct 21, 2012 at 7:16 PM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    that's right, but with towing, (and the fact the op seems to have a 2012 truck) you would check the fluids before towing on a trip, and if you stop and there is now discoloring that would be a cause for alarm.
    and if she does run warm, try to pull over, and let it rest, if possible let her idle, and keep the coolant flowing.
  10. Oct 21, 2012 at 7:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The second gens dont have a dip stick to check the tranny fluid with. However, the fluid also runs thru the lower part of the radiator, so if the Engine temp is in the good range, all should be fine with the tranny. There is an tranny over heat light (Ive heard) on the newer trucks, but I have also heard that if it iluminates, the damage has already been done.
  11. Oct 21, 2012 at 7:28 PM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    well that's strange. how is a owner supposed to check the fluid level?
    and I am aware of that also, esp since Nissan owners are finding out the hard way that this might not be a good setup.
  12. Oct 21, 2012 at 7:34 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah, truthfully as long as you are not overheating all should be good because the fastest way to cool down fluid is by water (hence the reason why it flows through the radiator) but also all TRD off road and sport packages come with an additional tranny cooler aside from the radiator cooler support to promote further cooling of the transmission especially during those extensive towing sessions.
    In all reality I wouldn't even worry about it as long as you perform your routine maintenance and keep all items in good working order.
    PS: No tranny dipstick is bullshit 'Yota.. That is all. Anytime I hear "lifetime fluid" from any manufacturer which is becoming increasingly common in some sort of attempt to make them look more impressive, I put my finger in the air and feel which way the bullshits blowing.
  13. Nov 24, 2012 at 4:30 AM
    J Gibson
    J
    Knoxville, TN
    You're right, I do have a 2012, but the fact that it has a "sealed" transmission and no dipstick for it, watching fluid color is not an option. I would also be concerned that if I got the fluid so hot that it truly broke down, lost viscosity, changed colors, or whatever, it would be too late and damage to transmission will already have occurred. Thus, I have a scangauge which tells me the fluid temp, just need to know what point I need to get concerned.
    I guess I will try to use the poster aboves guideline of 210-220 and ohh shit at 260, but those temps seem pretty low. I haven't towed since getting the gauge, but I got the temp up close to the 200 range going across the "mountains" in NC on I-40 with no trailer.
  14. Mar 22, 2013 at 11:23 AM
    jdavis92
    jdavis92 Well-Known Member
    Boise, ID
    2010 Regular Cab, 2.7L, 5spd
    Stock
    How is everyone keeping an eye on their tranny temps?
    I am thinking of putting some gauges on the pillar to monitor it.
    Is there an overriding assumption that the tranny temps are close to the coolant/engine temps if you have the factory tow package and supplemental tranny cooler?
  15. Mar 22, 2013 at 11:41 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    I don't believe the manual transmissions have the sensor to monitor the temps, but the autos can use a scangauge, ultragauge, etc...
  16. Mar 22, 2013 at 11:55 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    I thought the tow package, which is where the tranny cooler comes from, is a stand alone add not automatically included with every TRD.
  17. Mar 22, 2013 at 12:36 PM
    jdavis92
    Boise, ID
    Stock
    Nope. At least not on a 2005 SR5 w/towing package.
    I have an Ultraguage and tranny temp is not an option on my truck. So I was looking at some aftermarket gauges that folks are mounting on pillars and I was wondering where they are getting the temp feed from.
  18. Mar 22, 2013 at 3:26 PM
    S.B.
    Sean
    San Diego
    15 Taco
    This is the write-up I followed: works very well. I have an auto meter sport comp 3357 gauge. I just put in a piller pod by Lotek.
  19. Mar 22, 2013 at 3:29 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Typical ATF has a flash point of 315-325 Degrees.
  20. Mar 22, 2013 at 3:45 PM
    jdavis92
    Boise, ID
    Stock
    How much time and money invested in that setup?
    Nicely done I think. Could be a good project before the temps get up here.
    I guess I just wonder why Toyota doesn't have stock sensors. Or I guess I wonder what would trip the tranny temp dummy light....why not send that to an SG or Ultragauge?
