What is the Tacoma lug nut style called?
Discussion in '1st Gen. Tacomas (1995-2004)' started by treyus30, Mar 10, 2022.
  1. Mar 10, 2022 at 1:16 PM
    treyus30
    treyus30 [OP] 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Want to use my old 15" wheels and tires on a different hub using an adapter, but all I'm seeing are "acorn" lug nuts, which I know are not what Toyota uses on their trucks. So what's the right search term?
  2. Mar 10, 2022 at 1:20 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Toyota Stock Aluminum Wheels use Short Shank mag wheel Lug Nuts M12x1.5
    Steel wheels use a different type I would need to look to be sure.
    Nessal and treyus30[QUOTED][OP] like this.
  3. Mar 10, 2022 at 1:25 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Steel wheels will be the classic Acorn style seat. Same thread pattern and size
  4. Mar 10, 2022 at 1:26 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Hmm, still not finding much. Problem might be I would need 1/2"-20 in that style
  5. Mar 10, 2022 at 1:27 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    just look up Toyota tacoma lug nut or M12x1.5 mag lug nuts. they are less common so less out there.
  6. Mar 10, 2022 at 1:28 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Thread would be different, edited comment ^
  7. Mar 10, 2022 at 1:30 PM
    treyus30
    Trey
    Mesa / AJ, AZ
  8. Mar 10, 2022 at 1:30 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  9. Mar 10, 2022 at 1:31 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Those are still M12, and too much dolla
  10. Mar 10, 2022 at 1:33 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    what type of hub are you using then?
  11. Mar 10, 2022 at 1:33 PM
    treyus30
    Trey
    Mesa / AJ, AZ
  12. Mar 10, 2022 at 1:34 PM
    Digiratus
    Roaming the PNW
    The RedHead
    M12x1.5 is the correct size. You said you weren't able to find any. Well, there they are. How much did you expect to pay for new ones?
  13. Mar 10, 2022 at 1:34 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    then you need a 1/2 20 mag seat lug nut
  14. Mar 10, 2022 at 1:35 PM
    Digiratus
    Roaming the PNW
    The RedHead
  15. Mar 10, 2022 at 1:35 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    He's using 5 to 6 lug adapters and I guess the new studs are 1/2 x 20... idk why but yeah
    treyus30[OP] likes this.
  16. Mar 10, 2022 at 1:35 PM
    treyus30
    Trey
    Mesa / AJ, AZ
  17. Mar 11, 2022 at 6:34 AM
    Bivouac
  18. Mar 11, 2022 at 9:39 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    The hub adapters only come in 1/2-20 looks like
    Bivouac[QUOTED] likes this.
  19. Mar 22, 2022 at 2:20 PM
    treyus30
    Trey
    Mesa / AJ, AZ
