What is the best modifications for a first gen tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Camo taco, Dec 30, 2019.
  1. Dec 30, 2019 at 2:51 PM
    Camo taco
    Camo taco [OP] Member
    Mason
    1998 toyota tacoma with camo paint job
    I have a 1998 toyota tacoma single cab, Ive been wondering what are some of the best products/modifications for my truck hear is what ive been thinking so far:
    allpro baja series front bumper
    trail gear rock defence rear bumper
    light bars
    winch
    alot of recovery gear (collapsable shovel,maxtracts, ect.)
    arb safari snorkel
    feel free to leave sugestions of gear/modifications
  2. Dec 30, 2019 at 3:00 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Is it a 4X4?
  3. Dec 30, 2019 at 3:16 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    That really all depends on the type of driving you do, your driving/adventure style, and the conditions you drive in. Also your budget, lol...
    First on your list is simply more seat time, maybe a decent set of tires, and a first aid kit.
    Half that stuff on your list honestly isn't "necessary" for the vast majority of people unless you're looking for instagram clicks.
    I see plenty of people with a shiny new hi-lift mounted prominently on their overlander bed rack, but no sliders or aftermarket bumpers to use it on. The thought of someone using a hi-lift on their stock plastic bumper entertains me a lot, lol.
    I would focus more on recovery/safety gear, then amor (sliders and skids) before all the cool looking stuff. Probably skids first, especially something that covers the transmission.
    Don't just go buy "alot of recovery gear" when you probably don't really know what it is or how to use it safely. A tow strap and some D rings are cool, but useless if you're on your own. A hi-lift can be extremely dangerous if misused. Synthetic winch lines and shaft shackles are cool, but equally as dangerous as their steel counterparts when misused.
    Hamer95USA likes this.
  4. Dec 30, 2019 at 3:18 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Area51Runner likes this.
  5. Dec 30, 2019 at 3:19 PM
    GrindingRock
    GrindingRock Member
    Kurt
    2000 Lifted Tacoma
    Straight Front Axle 6" Lift Rock Sliders 2nd Gen TRD Supercharger Warn Winch Custom SS Front Bumper and Rear Bed Lifted W/no wheel wells Custom Aluminum Canopy
    On a 1st Gen Tacoma I had an extra leaf added to the back springs to stiffen it up for carrying camping gear for long trips. We have done at least 3, 10 night trips in the Maze District of Canyonlands NP where you need 18 gallons of extra gas and at least 20 gallons of water and typically dry ice and regular coolers. This was an excellent mod to keep the rear axles off of the rubber bumpers when fully loaded.
    Wheels & larger diameter tires might be a good modification depending on what you want to do with the truck.
    A mild lift (say 2") might be a nice modification but I have not done research around this and you would want to proceed carefully.
    My current Tacoma has an ARB compressor mounted which makes it a lot more convenient to deflate and pump up tires which helps a bunch on trails. Any good quality compressor would be a nice addition and there is nothing wrong with just carrying it loose to use when required.
    If you are going to ford any deep water you might consider routing all of your gear box breathers to a high point above high water. ARB makes a kit for this but you can build it out of parts.
    If you ever need it a roll bar or cage would probably be greatly appreciated.
    Real rock sliders (structurally connected to the frame) do offer excellent points to use a high lift jack but you still need to be very cautious in working around a suspended vehicle. I also use the high lift jack on the sliders to level the vehicle side to side for sleeping in the bed in the back country.
    Recovery points are also critical. They may come with your bumpers but if not it is something to think about.
  6. Dec 30, 2019 at 4:01 PM
    Camo taco
    Mason
    ok so... i forgot to list what i inherited with the truck and what i have bought in the 5 months that i have owned it. I have first aid kits and the truck has a 2 inch lift with bigger tires. and yes it is 4x4. i also have put a CB radio in it as well. I intend it to be a capable offroader/touring rig.
    Questions:
    if a high lift jack is dangerous is a bottle jack a better option?
    what type of recovery gear do you recomend that is safe and will get the job done safly?
    is this cheeper snorkel reliable?
  7. Dec 30, 2019 at 4:04 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Driver mod is the best mod.
  8. Dec 30, 2019 at 4:10 PM
    jbrandt
    Justin
    The safest recovery gear is the stuff you know how to use.
    A hi-lift is only dangerous if not used properly. It's an extremely versatile tool that can be used for a lot of different things, not just changing a tire. Bottle jacks are great for changing tires in many situations, but you can't always use one, and if you need to jack the frame/body up for whatever reason, they're useless. There are some accessories you can get for a hi-lift, that attach to the wheel which help, or attach to your sliders or a bumper to make it safer (in many cases). There are lots of threads where people insist that one or the other (or a hydro floor jack) is THE jack to have. They're all wrong, lol. There is no ONE jack that is universal or the "safest".
    As for the snorkel, I was honestly skeptical at first (there's a whole thread about it), but several of those guys have had them a while now, and they seem to be holding up just fine.
  9. Dec 30, 2019 at 4:18 PM
    Camo taco
    Mason
    alright i will look into it.....how about in cab modifications like
    is this snorkel able to fit 2.4L as well
  10. Dec 30, 2019 at 4:50 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    For in cab modifications, I always like getting a new head unit and door speakers if you're still rocking the OEM. Add an amp and a sub if you're a basshead. Put some sound deadening material in the door cavities while you have the panels off. Replacing the map lights with LEDs was a nice upgrade because I was finally able to unload my truck in the dark. The seats in these trucks are kind of rough IMO, so new seats is the ultimate in cab upgrade.
  11. Dec 30, 2019 at 4:55 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    I recently saw someone pound the rod of the hilift into the ground and use it as a land anchor for his winch in muuuud.
    Was impressed
    And to answer the OP. V8 swap or tuuuurbo
  12. Dec 30, 2019 at 5:05 PM
    02hilux
    Planet: EARTH
    FR & RR lockers and tacobox
    theesotericone likes this.
  13. Dec 30, 2019 at 5:15 PM
    jbrandt
    Justin
    That's a good one, hadn't seen that before!
  14. Dec 30, 2019 at 5:44 PM
    joe25rs
    joe25rs Well-Known Member
    Joe
    Mrr’land
    2004 Black TRD
    Get caught up on your maintenance. Nothing worse than blowing the budget on fun stuff only to be downed with a break down. I would cover the basics and go from there.
  15. Dec 30, 2019 at 5:45 PM
    JKO1998
    Utah
    Surely you mean 2.7, and yes
  16. Dec 30, 2019 at 5:50 PM
    Camo taco
    Mason
    Well thats the other thing.....im currently trying to solve a misfire on cylinder four (my truck is a 2.4L) ive replaced the plugs and that helped alot,but it did not fix the problem. it still misfires every so often and after idling for about 1 min it start to misfire again...But yes im not buying any modifications until all the maitnence has been done to it
  17. Dec 30, 2019 at 5:52 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Add 35's and you got a winning combo.
    Running Board Man likes this.
  18. Dec 30, 2019 at 5:52 PM
    Camo taco
    Mason
  19. Dec 30, 2019 at 5:53 PM
    jbrandt
    Justin
    coil packs?
  20. Dec 30, 2019 at 5:57 PM
    jbrandt
    Justin
    No one in the history of anything has anyone ever swapped a 2.4L into a 6 lug. If they have, they should be beaten with a hose.
    He likely just misspoke and didn't realize there are 2 different 4cyls for the 5 and 6 lugs. Simple mistake for the non-initiated.
