What is the best 2023 tacoma for off-roading?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by IsaacTheSkier, Jun 26, 2023.
  1. Jun 26, 2023 at 8:40 AM
    IsaacTheSkier
    IsaacTheSkier [OP] New Member
    Isaac
    To be determined
    What is the best 2023 Tacoma for off-roading (right "out of the box")?
    Also, what makes the Tacoma superior for offroading (compared to other trucks like the F-150, Jeep Gladiator, and Chevy Silverado)?
  2. Jun 26, 2023 at 8:43 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    One with a salvage title.
    WAFTLR, Kolohe07, ToyoTaco25 and 18 others like this.
  3. Jun 26, 2023 at 8:45 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    1) None.
    2) There is nothing.
    Stevie17 and Road_Warrior like this.
  4. Jun 26, 2023 at 8:58 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    1. Gonna have to define offroading first; do you mean rock crawling, plowing through mudholes, driving gravel roads, or 99% on road with 1% want to go camping somewhere.
    2. You're comparing a midsized truck to full-sized trucks, and a tacoma being superior is still debatable.
    Taco22trdor, Chew, tcjacado and 5 others like this.
  5. Jun 26, 2023 at 9:23 AM
    Xtremsiege2
    Xtremsiege2 Well-Known Member
    Norwalk CT
    21' LR Pro. Lots of fast bikes
    The driver with the biggest balls and largest wallet.
    Kolohe07, Taco22trdor, Chew and 3 others like this.
  6. Jun 26, 2023 at 9:29 AM
    Firn
    Firn Well-Known Member
    White OR
    1) Pro. Everything the OR has plus better shocks
    2) Hard to argue the Tacoma is better than the Jeep, aside from reliability. Compared to a Full Size its a smaller physical size.
    You should probably ask where its worse too...
    OZ TRD, Stevie17, oconnor and 2 others like this.
  7. Jun 26, 2023 at 9:41 AM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    SR-5 ......proven to be the best of the best. :anonymous:
  8. Jun 26, 2023 at 10:02 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Definitely TRD sport.;)
    ShinyTaco and Road_Warrior like this.
  9. Jun 26, 2023 at 10:08 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    No one can answer your first question unless you tell us what kind of “off roading” you plan on doing.
    Really the only benefit the Tacoma has over some other trucks (full size trucks) is that it can fit better on tighter trails.
    Taco22trdor, Stevie17 and Junkhead like this.
  10. Jun 26, 2023 at 10:10 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Jokes aside, TRD PRO/OFF ROAD are the most capable “right out of the box”.
    Tacoma is superior to full size trucks off-road due to its smaller size, weight and tucked in frame.
    A jeep is the best for off-roading.
  11. Jun 26, 2023 at 11:48 AM
    Firn
    White OR
    Is there really any off road situation where one version of the Tacoma is better than the other though, stock vs stock? I cannot really see the Pro being worse at say mud than a SR5. Its cheaper, that is for sure, but is there any off road situation that a lower trim is "better" at doing? Stock to stock and when cost isn't a consideration.
    tcjacado likes this.
  12. Jun 26, 2023 at 11:52 AM
    Off Topic Guy
    Each trims have different suspensions. Some settings favor certain ride characteristics, like shocks that are more firm, or less firm, for example. Now is it really that noticable of a difference between trims, for crappy stock shocks? I'd say probably not, but an entire suspension forum on this site would prove otherwise. There are some sensitives asses around here. (in more than one aspect :anonymous:)
  13. Jun 26, 2023 at 12:09 PM
    Firn
    White OR
    As an owner of Bilstein 6112's I get that. Playing devils advocate, would that make it more capable off road though? Or just more comfortable? I would have to imagine that in all off road situations the Pro's Fox shocks would be "better" performance wise.
    (not that I'm a pro advocate in general)
  14. Jun 26, 2023 at 12:15 PM
    Off Topic Guy
    yeah, its kinda just a giant rabbit hole to go down to ultimately come to the same conclusion (that it doesn't really matter if you're not gonna be offroading in the first place). I think capability is gonna be the same across any of the 4x4 offerings. And its just another debate to discuss the nanny features, to figure out which is most capable or reliable. My vote is for the PRO as well, for an out of the box truck. Reality is OP will probably see nothing more than a gravel road though.
    MR E30 and Firn[QUOTED] like this.
  15. Jun 26, 2023 at 12:19 PM
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    The best Taco for off roading is the one that the person answering the question has.
    ShinyTaco, Stevie17 and Junkhead like this.
  16. Jun 26, 2023 at 12:43 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Locker sir.
    Although TC works amazing on my taco, 100 times better then having open diffs.
  17. Jun 26, 2023 at 2:49 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    You spelled Wrangler wrong.
    Taco22trdor likes this.
  18. Jun 26, 2023 at 3:05 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
  19. Jun 26, 2023 at 3:39 PM
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga STRONG Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    :evil:
    Junkhead[QUOTED] likes this.
  20. Jun 26, 2023 at 3:45 PM
    islandhiker
    islandhiker Well-Known Member
    Calgary, AB
    2021 TRD Off Road AC
    Really depends on alot mate, a RAV4 with the right tires and good driver will do better in alot of places than a tacoma with shit tires and a bad driver. Comparing to the others isnt really helpfull either. Jeeps are great, the F150s are good to, but full sized.
    Taco22trdor and Firn like this.
