what is clutch fluid?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by woodchip, Jul 13, 2016.
  1. Jul 13, 2016 at 9:36 PM
    woodchip
    woodchip [OP] Well-Known Member
    calgary,ab
    2013 taco 4x4 v6 manual
    firestone ride-rites
    The dealer keeps telling me I need work beyond the stuff that is in the maintenance schedule,I think?today they are telling me I need extra service including checkint the clutch fluid .what is that?
  2. Jul 13, 2016 at 11:19 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    He is talking about the clutch Master Cylinder and slave cylinder for the hydraulic actuated clutch. It uses the same fluid as the brakes. Your brakes and hydraulic clutch probably shares the same supply reservoir.
    With a 2013 I highly doubt you need any maintenance yet unless you are having an issue.
    The dealer be wanting your money!
  3. Jul 13, 2016 at 11:22 PM
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    otoh, checking the clutch fluid is exactly like checking the brake fluid, you look in the reservoir and verify its at the proper level. this should be a courtesy check not a extra charge.
    17TRD6MT and Norton like this.
  4. Jul 15, 2016 at 3:01 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    In the world of dealer profit, a distant relative of blinker fluid.
  5. Jul 15, 2016 at 3:03 PM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    Something the 2106's are low on from the factory
    shakerhood likes this.
  6. Jul 15, 2016 at 3:13 PM
    Clearwater Bill
    Billy
    Largo Florida
    That's visionary!
    Alexely999, vrod671, Pigpen and 2 others like this.
  7. Jul 15, 2016 at 3:15 PM
    Wolftaco0503
    Adam
    Chicago
  8. Jul 15, 2016 at 3:15 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I remember my 2009 having a separate reservoir for clutch and brake. Did that change over the years?
  9. Jul 15, 2016 at 3:48 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My 2008 shared the same reservoir with the brakes but my 2015 has separate ones, I think it may be cause of the Atrac System.
  10. Jul 15, 2016 at 4:26 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I would have to find some pics of my 2009. It was an OR 4x4 so it had the A-trac and I'm pretty sure the reservoirs were not shared.
  11. Jul 15, 2016 at 4:27 PM
    Shibbyjeep
    Shibbyjeep Well-Known Member
    Trent
    Greenville SC
    2014 Tacoma DCSB TRD OR
    It's brake fluid
  12. Jul 15, 2016 at 4:29 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I think it's a good idea to flush the brake/clutch fluids every 2-3 years along with coolant.
    Bamo and Norton like this.
  13. Jul 15, 2016 at 4:53 PM
    shakerhood
    Southern Ohio
    My 08 OR had a traditional style booster and master cylinder, my 2015 OR has some sort of hydro electric unit.
  14. Jul 15, 2016 at 5:09 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I know one of the models have a shared clutch and brake supply reservoir. I think it is the Off Road, but don't quote me on that...
  15. Jul 15, 2016 at 8:35 PM
    edm3rd
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    Single reservoir on 2009 V6 PreRunner 6sp.
  16. Jul 15, 2016 at 9:58 PM
    marinetaco
    marinetaco Well-Known Member
    Bobby
    2005 Tacoma TRD
    It may or may not be part of your brake fluid reservoir. If it isn't, you should service it everything few years along with your brake fluid. Most brake fluids are known as being hygroscopic. They collect moisture in the air. You and anyone that drives a vehicle tend to use the brakes.....a lot. People with manuals use the clutch....a lot as well. There is heat being created. Heat and cold create moisture. Moisture is also trapped in the brake/clutch lines. That's why they recommend flushes. Can you do it at home? Absolutely. It's pretty much a glorified brake bleeder session. Hope this bit of info helps.
    Bamo likes this.
  17. Jul 15, 2016 at 10:03 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Separate reservoirs on my 2013. Brake reservoir is large. Clutch reservoir is tiny.
    +1.
    +1.
    Negative. My (2013) TRD OR has separate reservoirs.
  18. Jul 16, 2016 at 1:58 AM
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    (goes out to the driveway at night, pops the hood, and studies it with a flashlight)
    dayum, my 2008 4x4 OR 6 sp. has shared reservoir.
    big brake reservoir, there's a 1cm or so hose that goes from the reservoir through the firewall to the clutch master cylinder behind the pedal, and a skinny clutch line comes back through the firewall down to the clutch slave.... so you should bleed the clutch when you bleed the brakes, I guess ?
    dunno, there used to be a time I did all that stuff myself, now I just take it to a good wrench, and he does as needed. I do still kinda like to know how it all works, and toyota is new to me, my last umpteen cars have been early 90s mercedes & volvos, and 80s VWs before that.
  19. Jul 16, 2016 at 3:34 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    My 2008 is the same, shared reservoir, huge vacuum booster, ABS controller way over on the passenger fender. My truck does not have TRAC or VSC and I think that's the reason. Trucks with VSC have a separate clutch master reservoir because the booster/brake master is the electronic gizmo.
    I'm collecting parts for my suspension swap, part of which is longer stainless flexible brake hoses. I'm debating having a local shop swap them and bleed the brake and clutch because I'm not sure what's going to happen with my power bleeder. When I pressurize the reservoir are the two fluids going to mix. Not that bleeding both at the same time is a bad idea, just not sure what's going to happen and what the levels will be after. I don't want to end up with a mess.
  20. Jul 16, 2016 at 4:42 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    It must be model specific if they share the same reservoir or not. My '13 SR5 shares the clutch and brake.
