What is a safe rpm range to cruise at?
Discussion in '1st Gen. Tacomas (1995-2004)' started by The guapo taco, Jul 2, 2022.
  1. Jul 2, 2022 at 11:08 PM
    The guapo taco
    The guapo taco [OP] Member
    Hey guys, I read some other threads on this but got some mixed answers. I have a 3.4l 02 Tacoma and I just made a 2 hour trip to the beach and it was all highway drive I am running 35’s and I was a little scared to go over 70mph because of the rpm’s, they were sitting at about 2500-2600 and I didn’t know how healthy it would be for it to go any higher. Felt a little annoyed considering I had to tell the person I was following to slow down a little for me.
    But anyways to the point, would I be okay to set cruise control at 3k rpm’s and just coast, or am I going to be shortening my engine life?
    Ps: I just broke 200k miles as well
  2. Jul 2, 2022 at 11:11 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    flat it should cruise at 2200-2500, but you shouldnt be scared of the engine going to 3500 if you need it to get to speed limit. My engine revs up to 4500 when getting on the hwy.
  3. Jul 2, 2022 at 11:15 PM
    The guapo taco
    I’m not scared to rev it when speeding up because I know I’m just going to shift out of the high rpm’s anyways. It’s more of just a cruising range I’m wondering but I couldn’t do 2200 on the freeway I would be going just over 60 and I already get blown by going 70.
  4. Jul 2, 2022 at 11:19 PM
    YotaGangYotaGang
    Covina
    well what gears do you have? 4.10’s im assuming. If they are I would imagine the rpms to be lower and you really need to keep it in the pedal to power those 35’s. 3000 is pretty high for cruising unless your going up a hill. Mines usually at 2200-2600
  5. Jul 2, 2022 at 11:24 PM
    The guapo taco
    I believe I might be at 4.56 gears. I did not put the lift and tires on the owner prior had done that. But with the power I have compared to other tacomas it’s pretty similar so I came to the assumption they are 4.56.
  6. Jul 2, 2022 at 11:28 PM
    YotaGangYotaGang
    Covina
    you can cruise at 3k but the trans is working too hard and youre waistinf more gas. Unless youre on a lil steep grade going up i dont think cruising is normal at 3k unless you are regeared but u have 35s so the rpms shouldve settled
  7. Jul 3, 2022 at 1:03 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Only thing I would be worrying about would be gas being close to $7 a gallon.
    Higher RPM and low MPG go hand in hand.
    Bivouac likes this.
  8. Jul 3, 2022 at 7:55 AM
    alarka
    alarka Well-Known Member
    WNC/SE GA
    2k X cab 3.4 5spd
    King ex travel, JBA UCA’s, All Pro Springs/shackles, Locked, all new poly bushings & rack, SS brake & clutch lines, ext bumps for starters.
    I try to not go over 2500-2600 RPM with the 3.4l after MPG drops off big time. I run 33’s with 4:30 gears and get about 18-19 MPG if I keep the RPM’s in that range ~ 70 MPH
  9. Jul 3, 2022 at 8:03 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    You're not hurting anything by cruising at higher RPM other than your wallet from the lower MPG. on the highway going 75-80 I probably cruise right at 3k - 3200 RPM.
    Redline is what, 5600 or so? Still well below that
  10. Jul 3, 2022 at 9:56 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    3000 rpm will not hurt your engine as long as your keeping after the maintenance .
    With fuel prices I avoid the interstates I have no need to drive to keep up with traffic at 80 mph traffic.
  11. Jul 4, 2022 at 7:12 AM
    Chugiak76
    Chugiak76 Well-Known Member
    Colorado Springs, Colorado
    2020 Tacoma SR 2.7 4x2, AXC
    It's a misconception that high rpm (sub redline) damages anything. If you drive in 4th gear your engine rotates the same number of times per mile whether you go 20 MPH or 100 MPH. The only thing that will suffer is fuel economy. As long as you have circulating oil and coolant that are in good condition and at the correct level, you can drive at whatever RPM you like.
  12. Jul 4, 2022 at 7:36 PM
    FlyingBuckeye3
    FlyingBuckeye3 Member
    2002 Toyota Tacoma 4x4
    My 02 3.4 5 speed runs about 2800rpm when running 70 on the interstate. I had the same concern but I figure as long as my MPG and maintenance are up to date, I should be fine. I averaged around 21mpg on my trip running exclusively interstate.
  13. Jul 5, 2022 at 8:35 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    With 5.29s and 35s I try and keep it under 3400 RPM on the highway
  14. Jul 5, 2022 at 9:55 AM
    Cyberfool
    Cyberfool Well-Known Member
    Jack
    Balto MD
    Sub-redline RPMs are fine. I remember crossing North Dakota while the driver kept the cruise control at 100mph. 1997, 5spM, V6, 2WD. +2 tires. Engine still fine. Give it what it needs and the engine does what you need.
    Wulf likes this.
  15. Jul 5, 2022 at 10:54 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    You know the cruise control sets the speed (not RPMs), right? lol
    But as others have said, you have absolutely nothing to worry about running much higher RPMs. Assuming you don't have oil pressure issues or other problems (that would cause issues no matter what RPM you run), you have zero to worry about except your fuel mileage.
  16. Jul 5, 2022 at 11:01 AM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    FYI for anyone new to nerding out over gears and tire sizes... the transmission is also a big part of that puzzle. The manual and auto have substantially different overdrive ratios. In other words, an auto with 5.29 gears isn't comparable to a manual with 5.29s--a manual with 4.56 is a closer comparison.
    Lots of gear ratio and tire size math to be done here for anyone sufficiently curious: http://www.grimmjeeper.com/gears.html
  17. Jul 5, 2022 at 11:06 AM
    Archaic2021
    Archaic2021 Well-Known Member
    I wish I knew what gears I have but my 5 speed I cruise with 30x9.5 around 70-75 mph and it's a touch over 2500rpms
  18. Jul 5, 2022 at 11:08 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    as long as it's under redline, you're fine
    Wulf likes this.
  19. Jul 7, 2022 at 11:32 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    I have a 2nd gen with 4.56s and 35s. I've been constantly cruising on the hwy at around 2800-2900rpm daily for the last several years. Besides wasting a lot of gas, 11pmgs, I have not noticed any ill affects.
  20. Jul 7, 2022 at 11:51 AM
    Clearwater Bill
    Billy
    Largo Florida
    Easy.
    Count the times a rear wheel goes around for one driveshaft turn.
    For example, if its 3 1/2 it’s a 3.50:1
