What idler pulleys should I get?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by paskanaama, Mar 5, 2017.
  1. Mar 5, 2017 at 10:31 PM
    paskanaama
    paskanaama [OP] Well-Known Member
    2006 SR5 Tacoma Manual
    I want to swap out my idler pulleys on my truck, and am seeing if there is a specific brand I should get. Thanks
  2. Mar 5, 2017 at 10:51 PM
    marinetaco
    marinetaco Well-Known Member
    Bobby
    2005 Tacoma TRD
    I replaced mine with Gates. No issues at all.
  3. Mar 6, 2017 at 5:29 AM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Gates all the way, rock auto has them for good cheap prices. Also might as well change your serp belt if you havent recently. I didn't, then it shredded a week later :rolleyes:
  4. Mar 6, 2017 at 6:52 PM
    paskanaama
    Thanks! Ordered them up, but I replaced my belt in June, so im sure it will still be new enough!
  5. Mar 7, 2017 at 1:40 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Then yah you will be okay
  6. May 3, 2017 at 3:58 PM
    grave
    grave Member
    bump... does anyone have the part numbers for the tacoma 1GR-FE OEM upper and lower pulleys? I have a 2006 4runner with the same motor and since tacomas are made in the US/mexico, the OEM tacoma serpentine belt was about half the price of the OEM 4runner belt and i am wondering if it may be the same case with the pulleys.
    thanks!
  7. May 4, 2017 at 6:02 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Search for the word "pulley".
  8. May 4, 2017 at 8:18 AM
    grave
    grave Member
    thanks! just what i was looking for. still can't figure out whether the #1 pulley will work with the tensioner. i don't feel like buying the entire assembly just for the pulley.
  9. May 4, 2017 at 8:52 AM
    Lester Lugnut
  10. May 4, 2017 at 10:15 AM
    grave
    grave Member
    thanks, TW!
