What hoses are used on the fuel filler neck?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bhocutt97, Feb 15, 2021.
  1. Feb 15, 2021 at 8:39 PM
    bhocutt97
    bhocutt97 [OP] Member
    Ben
    2002 Tacoma SR5
    6" Lift
    So I'm replacing the fuel neck after it leak from a smoke test. I'm looking to replace the hoses that come off it also while I'm there. What kind of hoses can I use for this? Thanks!
    Also I'm not talking about the main rigid hose. I'm talking about the flexible hoses that come off the breather ports and stuff.
  2. Feb 15, 2021 at 9:14 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    I used fuel line from the local parts store. Most of it was 3/8" ID hose, with a couple feet worth of 1/4" ID hose. If you want to replace all of the gas tank rubber, these are the hoses that are molded, the bottom one has two different sized ends.
    Might consider new gaskets as well while you have the bed removed:
  3. Feb 15, 2021 at 9:25 PM
    bhocutt97
    Ben
    2002 Tacoma SR5
    6" Lift
    thanks for the info, it helps a lot
