What headlight bulbs? Non HID
Discussion in 'Lighting' started by ABA180, Aug 8, 2013.
  1. Aug 8, 2013 at 10:37 AM
    ABA180
    ABA180 [OP] It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I wouldn't mind getting a little more light out of my 2010's headlights without going the HID route. Just don't have the $$ right now to do it plus I seem to read quite a bit about issues people have even with the "good ones".
    So, what bulbs should I replace the stock ones with?
  2. Aug 8, 2013 at 10:39 AM
    TailDrag
    TailDrag Well-Known Member
    I've always used Sylvania's. People here say that high dollar bulbs don't make a difference and then suggest PIAA bulbs. They also say Sylvania's don't last long (this hasn't been my experience).
    I've never used PIAA, but my Sylvania's I've been using on every vehicle since 2002 and I've never had any issues with premature failure. They definitely produced more visibility than the stock bulbs they replaced. In fact, the set I had in my Chevy lasted from 2002 when I put them in until I sold it last year. It had DTRLs, also. That is more life than I ever had in any other brand of bulb.
    I plan on Sylvania's in my Tacoma.
  3. Aug 8, 2013 at 6:21 PM
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    Sylvania extra visions.
  4. Aug 8, 2013 at 6:25 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
  5. Aug 8, 2013 at 6:26 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    I bought Vision X brand bulbs from Amazon....this was a year ago and they are still going strong. I bought the bibeam bulbs and the fog bulbs....they are noticeably whiter than stock and they have a faint blue hue at the bottom of the headlight....they come with a lifetime warranty, so if that helps
  6. Aug 8, 2013 at 6:30 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Philips Extreme Power or PIAA Xtreme White bulbs. I like the PIAA ones a bit better but I thought both were an improvement over stock. I went back to PIAA bulbs after yanking my projectors out.
  7. Aug 9, 2013 at 8:55 AM
    bueller
    bueller Well-Known Member
    AZ
    Just last week I emailed Daniel Stern Lighting and he recommended the Osram Ralleye 70/65w as the best stock replacement bulb available. They aren't technically legal but will not be a problem with properly adjusted headlights. He also suggested Phillips X-Treme Vision H11's for the fogs (which he does not sell, so is an unbiased suggestion). Mine are on the way.
  8. Aug 12, 2013 at 10:15 PM
    joes06tacoma
    Joe
    Central Coast, CA
    About ten years ago I purchased a pair of Sylvania Xtravision sealed beams (whole light replacement) for my 1986 Toyota truck. I ran them for awhile, then decided to try something else. I bought a pair of GE High Output sealed beams for around $20 at Walmart. I don't know if they still carry them, or if the separate bulbs that our trucks use will give such a dramatic increase compared to the whole sealed beam housing, but those GEs were the best value I've ever seen. HUGE improvement. Eventually I will try some new bulbs, the GE offering will probably be my first choice, hoping for the same excellent value.
    Funny enough, I'm an appliance repair tech by trade, and I won't allow GE appliances in my house, but their jet engines and light bulbs seem to be pretty good!
  9. Aug 12, 2013 at 10:16 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I can only say don't waste your money on the Silverstars. I've bought multiple sets and they all fail at almost exactly 6 months. Went through two sets and both always failed within 2 days of each other.... even the fogs.
  10. Aug 12, 2013 at 10:26 PM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    I'am running the reg. silver stars in my fogs and the silver star ultras in my tacomas headlights since 2009. Havent had a single issue and the light output is great. I also have silver star ultras in my camaro and sonoma and have yet to replace them as well.
  11. Aug 14, 2013 at 5:43 PM
    three west
    three west Well-Known Member
    JD
    UP MI
    09 DC SB TRD Sport
    obviously your experience may vary based upon the responses.
    I ran original Silverstars in my old Dodge, they were 4 years old when I sold the truck and going strong.
    I put Silverstar Ultra's into my 09 Tacoma when I bought it two years ago, and they are also still going strong.
    both a great improvement over the stock bulb.
  12. Aug 15, 2013 at 8:54 AM
    bueller
    AZ
    I installed my Osram 65/70's and I'm liking them. The 2013 has bright headlights already so I wasn't expecting much change but there is a very noticeable difference in spread and throw. No they aren't fancy blue lights but for anyone just looking for good light, these are great.
  13. Aug 15, 2013 at 9:27 AM
    64Wildcat
    64Wildcat Black Jeep of the family
    Denis
    New Hampshire
    2015 Rubicon
    Hey Chris,
    I put these over a year ago,PIAA 10904 H4 Intense White - H4 60/55W=135/125W Xtra Intense White Bulb, i like them.:)
