  1. Jul 25, 2024 at 10:32 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Awesome, thanks for the info. I'll likely do something similar :thumbsup:
  2. Jul 25, 2024 at 2:05 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I just do it visually, it's pretty hard to see anything less than a mm with how I check them with a prybar. You should be able to use a dial indicator though. Been meaning to do another side by side comparison and keep better track of things.
  3. Jul 26, 2024 at 7:42 PM
    YotaBro
    YotaBro Well-Known Member
    98 Tacoma
    It'll be hard to go back to handwashing with this new electric pressure washer
    22A98529-E140-41C2-9DBF-FC9D49908DF6_1_105_c.jpg 038195C1-09F8-48BA-98CD-96EB1F386A2C_1_105_c.jpg
  4. Jul 27, 2024 at 4:58 PM
    smyles1632
    smyles1632 Active Member
    2003 Tacoma
    Bi-LED retrofit. Finally can drive in the dark.
  5. Jul 27, 2024 at 7:00 PM
    Toyota Dude
    Toyota Dude Well-Known Member
    2004 Tacoma 4WD 6-CYL DC
    Colight?
  6. Jul 27, 2024 at 7:05 PM
    smyles1632
    2003 Tacoma
    Projectors from aliexpress, headlights from rock auto.
  7. Jul 27, 2024 at 7:40 PM
    Toyota Dude
    Ali? Wow. Link to the projectors? How's the cutoff?
  8. Jul 28, 2024 at 5:40 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Replaced my harmonic balancer and oil pump housing seal
    This was major key for removing the oil pump Philips bolts without pulling the radiator
  9. Jul 28, 2024 at 5:56 PM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Dang what an attachment. Did you replace with allen head screws?
  10. Jul 28, 2024 at 8:54 PM
    betterbuckleup
    Ian
    Concord, CA
    No I did not. I wish LCE had told me of their upgrade kit when I ordered the other parts.
  11. Jul 28, 2024 at 8:57 PM
    smyles1632
    2003 Tacoma
    Toyota Dude[QUOTED] likes this.
  12. Jul 29, 2024 at 7:48 PM
    Toyota Dude
  13. Jul 30, 2024 at 10:06 AM
    smyles1632
    2003 Tacoma
  14. Jul 30, 2024 at 10:31 AM
    Stiney84
    Stiney84 Member
    Edward
    Georgia
    1999 Tacoma
    Got my new grille in
  15. Jul 30, 2024 at 11:01 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Looks very similar ;)
    Stiney84[QUOTED] likes this.
  16. Aug 1, 2024 at 9:21 AM
    TheCaleb06
    TheCaleb06 New Member
    Caleb
    2003 Xtra Cab prerunner
    Today I blacked out all the chrome and installed some black headlights. I will do the rear bumper next weekIMG_1309.HEIC.jpg
  17. Aug 1, 2024 at 5:23 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    Anybody in the market for 4.30 diffs? 8.4"/open rear. Looked at a truck in the junkyard that had some. Might go back for 'em, just because.
    The truck also had the carpeted back wall. Wrong color for my truck, but I snagged it to see if I can retrofit anyway. That might end up for sale soon. The donor truck is a 2000 with the blue/gray interior, trim code FG10 in case anyone's interested.
    Tour991 likes this.
  18. Aug 1, 2024 at 8:05 PM
    Tour991
    Tour991 Supplier of used parts
    James
    Zephyr Cove NV Lake Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    The last back wall carpet I sold went for $350 with the top plastic trim for the bottom of the window. You scored on that. If you decide to use it you can always grab a bottle of black rit and die it black.
  19. Aug 1, 2024 at 8:11 PM
    6P4
    Colorado Springs
    So bigger issue than the color is that my cab (1998, bare back wall) doesn't have all the holes and slots needed for the trim pieces around the carpet. I'd have to either drill/cut or use adhesive. Have you done that retrofit before?
    Tour991[QUOTED] likes this.
  20. Aug 1, 2024 at 9:02 PM
    Tour991
    James
    I did do it. I just marked the location of the clips on the back wall and than just drilled 2 holes for each and Dremeled out the in-between. I can take Pic tomorrow. Did you grab the side panels the go up the wall behind the seatbelts?
