  1. Feb 6, 2021 at 5:29 PM
    slodoug
    slodoug Well-Known Member
    added a small on/off switch to the temp display, hooked it all up to a quick disconnect that was part of the USB port i took out.
  2. Feb 6, 2021 at 5:43 PM
    AppStateTaco
    AppStateTaco I love Ice cream
    North Carolina
    16 Toyota Tacoma
    I’ve always loved those 4Runner wheels
  3. Feb 6, 2021 at 6:07 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    They’re lovely.
    This one will be back on the road again this year all fixed up and restored
  4. Feb 6, 2021 at 6:07 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    What did you do to delete the upper cat? Gut it? Also the 420 code has nothing to do with 4low according to @Speedytech7 :duh::p
    I wasn't sure if the first sensor was before the first cat or between the two.
    Roger. I also am in an internal battle of cheap vs shiny new and not worrying about it for another 20 years. The cracked in half muffler has me wanting to fix shit and have clean new fasteners and pipe.
    Nice muffler like big stockish style or borla/gibson etc? I want maintenance free, leak free, etc. I see a cat back style exhaust on rock auto for like 150 that I can cut up and still exit out the bed. I'll poke around the cats and see what's up. When I tackle shit on this truck I want to do it once and right at this point.
  5. Feb 6, 2021 at 6:29 PM
    jmferg
    jmferg Well-Known Member
    Same, I’ve never had a slush/salt spray this bad
    Tour991 and nagorb like this.
  6. Feb 6, 2021 at 6:31 PM
    Speedytech7
    ゼイン
    5520 E Sprague Ave, Spokane Valley, WA 99212
    93 80 Series LC & 96 Turbo V6 Taco 4WD
    I've done a mod or two
    It's true, I can take a picture of what a Toyota drive cycle consists of per their engine control logic manual. Not my fault you guys can only seem to satisfy the conditions when your vehicle is in its least efficient gearset. :p
  7. Feb 6, 2021 at 6:38 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I dunno if you’re on the front or not but every car wash I passed this afternoon had a line
    vonellis likes this.
  8. Feb 6, 2021 at 6:47 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Problem with my pic is the snow was from the sky not the road.7374BACD-3CF4-4295-B3F5-CC1BEE47C970.jpg
    ontarioyota and jmferg[QUOTED] like this.
  9. Feb 6, 2021 at 6:48 PM
    JKO1998
    Utah
    You guys got it bad, Logan got purish white
    vonellis[QUOTED] likes this.
  10. Feb 6, 2021 at 6:48 PM
    Speedytech7
    ゼイン
    @cynicalrider
    Straight from the big book itself...
    The drive cycles are slightly different depending on the year of the tacoma since they changed sensor types in 01 so here are both of them. If you follow them to the tee you'll set off your CEL each time if your CAT is truely bad, if it doesn't go off every time the CAT condition is marginal but on its way out
    Silver02Taco, turbodb and 0xDEADBEEF like this.
  11. Feb 6, 2021 at 6:54 PM
    vonellis
    Some and some more
    Valley life. Inversion acid snow crystals .
    JKO1998[QUOTED] likes this.
  12. Feb 6, 2021 at 10:30 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2000 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Totally removed it.
    Installed DT headers and found the location of the A/F sensor and the collector flange forced a modification of the exhaust before the upstream cat. So we deleted the cat and built a interim pipe to fill the space. It also helps that Wa State rules changed about the same time and eliminated the need to pass emissions testing. :p
  13. Feb 6, 2021 at 11:17 PM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
  14. Feb 7, 2021 at 3:00 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Went with Magnaflow, then chopped it right before the axle bend. Nice and tight out of the way for rocks. Stainless steel tubing to last east coast rusty winter.
    I do recommend if you get the sensor, hollow both cats out, get a brand new oe upstream sensor and get a new maf sensor all at the same time and let the computer learn and it will run great.
    No problems with the URD sim and I've had it about 6-7yrs nows.
  15. Feb 7, 2021 at 4:17 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Hoping so bc I've driven such low miles otherwise since moving and getting the new job 5 min from me. Only put ~ 6k miles from September
  16. Feb 7, 2021 at 8:12 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yeah not sure I ever can make it do that lol. Not enough road here to drive those speeds for that time consistently.
    Ah so custom built, nothing I can just buy?
    Atlas case right?
    I do have a brand new Denso sensor up front. Honestly might just replace them, they are cheap enough. I'll look under there later today and check their conditions.
  17. Feb 7, 2021 at 8:17 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    Anyone install upgraded halogens and upgraded headlamp wiring? I may try this today so I’m wondering where you installed the relay block. Pics would be nice.
    detrio007 likes this.
  18. Feb 7, 2021 at 8:37 AM
    Tour991
    Tour991 Supplier of used parts
    James
    Zephyr Cove NV Lake Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    The very next day!
    jmferg[QUOTED] and SwampYota like this.
  19. Feb 7, 2021 at 8:44 AM
    rctoy
    konstantenos
    Pocatello Idaho
    Atlas 4 speed behind a black box (triple cases) behind a 4l65e behind a LS2. Making a few changes
  20. Feb 7, 2021 at 9:42 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    You can get pre-bent pipe sections in whatever diameter you want from summit racing, a couple of flanges to match, and just piece it together on the truck and weld it up. You may have to add a bung for the A/F sensor if you replace that section, which is also pretty simple.
    In racing they call it a test pipe, and no exhaust shop will make one for you unless they install it on a track only vehicle.
