  1. Jul 1, 2024 at 12:36 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Looks great. Mine came with the factory rack but I prefer what you did. By the way I could tell from your photos that you were in Calgary before even looking at your info. The trash containers and the look of the neighborhood is typical Calgary. Some towns have a personality of their own.
    Tacosha[QUOTED] likes this.
  2. Jul 1, 2024 at 2:47 PM
    azhiaziam
    azhiaziam Well-Known Member
    The reef ca
    White 2023 trd off-road
    Man I was really into into this as I have it in my camper shell. Looks slick are you going with a fairing? I would of gone with it also but was the same price as a bolt on
  3. Jul 1, 2024 at 2:50 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    2021 Black SR5 4x4
    Goose Gear’d my back seat…
  4. Jul 1, 2024 at 4:36 PM
    lupercal
    lupercal Well-Known Member
    Portland, OR
    2020 OR DCSB
    I'm trying to see if I can cut down on the dust that makes it into my bed. I 3d printed some little caps for the bed cubby, super glued them on, then put a bead/glob of silicone around them.
    Caps
    Bottom
    Top
    andthen, RCrumb, spin180 and 5 others like this.
  5. Jul 1, 2024 at 6:00 PM
    Late Camaro
    Late Camaro Well-Known Member
    Central Ohio
    22 TRD Sport Barcelona Red Access Cab MT
    Brought it home 3-16-22
    The photo appears to have melted, did it? Did the engine oil get hot enough to melt it, or did something else get close and hot enough? Can you elaborate on how it failed? (What caused the hole?)
    musicisevil likes this.
  6. Jul 1, 2024 at 6:09 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    What springs did you go with? Stock height or lift?
  7. Jul 1, 2024 at 6:13 PM
    VirusCage
    VirusCage Well in the secondary immune response
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 1995 Landcruiser 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    It looked as if it was cracking at my last oil change, so I went ahead and ordered the metal housing. Although it looks melted, that's just the point where it finally failed. I noticed a small oil drip onto my skid plate, and at that point it had cracked. Upon removal the tab cracked the rest of the way.
  8. Jul 1, 2024 at 6:14 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Measured right after install, they were 2.5" above stock, probably settle to about 2".
  9. Jul 1, 2024 at 6:16 PM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    OldSchlPunk likes this.
  10. Jul 1, 2024 at 6:26 PM
    TN1000
    TN1000 Well-Known Member
    2018 metallic silver TRD OR
    Work in progress
    @Shmellmopwho set me up with some 20° top plated rock sliders. Stoked on them. Ironryno fabrication.IMG20240701181603.jpg
    17taconut, Fireme, andthen and 10 others like this.
  11. Jul 1, 2024 at 6:28 PM
    CB350G
    Western PA
  12. Jul 1, 2024 at 6:31 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    The best tools grip the housing at the full-base, where strongest (but where the crack occurred anyway). Some use a tool on the sides where the stresses can exceed the design of the plastic.
    I am not sure what you or others used, but if not something like the Motivx tool, it might have been damaged.
    RIX TUX likes this.
  13. Jul 1, 2024 at 6:35 PM
    OldSchlPunk
    Rich
    East Central Wisco
  14. Jul 1, 2024 at 6:45 PM
    Tacosha
    Tacosha Well-Known Member
    Andy
    Calgary, AB, Canada
    2019 Black Tacoma TRD OR ACLB 6MT
    minor, TRD skid plate, front recovery points, Regken mud flaps, rear diff breather, AC drain pipe extended. Upgraded sound with active sub woofer, tonneau cover, CB radio.
    Thanks, Don't really need fairing piece, because of not a lot of use day by day;
    Yes, it's pricey, but I also have purchased different set of hardware and can use it also on
    my wife's Mazda. ;)
    azhiaziam[QUOTED] likes this.
  15. Jul 1, 2024 at 6:52 PM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    Threw on a set of 265/75r16 KO2s. They feel great on the road, I like the change from the OEM Kevlars so far.
  16. Jul 1, 2024 at 6:56 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    OTT Tune, LED HLs&Fogs,TRDSkid, TalonCAT
    Mine had been over-torqued from the dealership's 2 oil changes included in Toyota Care.
    I do my own oil changes now and find the OEM Aluminum Housing a sturdier choice.
  17. Jul 1, 2024 at 7:21 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    you use an impact?
  18. Jul 1, 2024 at 7:23 PM
    RIX TUX
    you are a wild man
  19. Jul 1, 2024 at 7:25 PM
    wcoffman
    wcoffman Well-Known Member
    '18 TRD Sport DCLB 4x4 SuperWhite
    Fr pass door handle replace, Tyger step rails and soft bed cover, DDSS3 fogs, TRD skid, OR front tow hook, SokieTech hood struts, fr seat covers (neoprene), metal oil filter housing, magnetic oil plug, Cyclone under hood lights, Blue Sea Systems 5025 Fuse Block ST Blade 6 Circuit with Ground and Cover, Blue Sea Systems 60A DC Panel Mount circuit breaker.
    Toyota Oil Filter Cap - 15620-31060
    Ordered from Amazon and installed in Sep 2018 on my 2018 Taco. When I went to my purchases just now to look up/confirm, the page indeed now says, “This does not fit 2018 Tacoma”. Well, somebody needs to tell that to the part that’s been on there for almost 6 years…..
    Cement_wheels[QUOTED] likes this.
  20. Jul 1, 2024 at 7:29 PM
    VirusCage
    Bruce
    Allison Park, PA
    Not me. I'm thinking the dealership
    RIX TUX[QUOTED] likes this.
