  1. Jan 22, 2020 at 3:15 AM
    DG92071
    DG92071 Well-Known Member
    I removed the plastic trim/storage boxes off of that back wall and I thought the same thing as you did. I checked twice to make sure a window wasn't down. The amount of noise coming through was insane.
    GonzoQuick likes this.
  2. Jan 22, 2020 at 5:08 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    I need this in my life! Though I thought about just putting a bead of silicon (or similar) in a circle around the hole to at least contain it so that whatever oil gets on the skid doesn't run to a corner and then onto my driveway. Others say to just use a futomoto valve, but I can't bring myself to go that route.
  3. Jan 22, 2020 at 7:46 AM
    Millerfish
    Millerfish Well-Known Member
    Southern Ca
    14 DC SB OR
    I considered that. The material is good to 350f it being under the oil pan i dont think it will see anything hot.
  4. Jan 22, 2020 at 8:01 AM
    Carter
    Carter Well-Known Member
    Carter
    Calgary AB
    14' Tacoma TRD Sport
    Toyotec Boss 3", Ridged Industries grill/light bar combo, TRD exhaust, Fender flares, 16" wheels with 33" Duratracs, Parrot Android Smart Deck, Custom Black Leather with red stitching.
    Right?? All that's on the back of those plastic bins is a slice of carpet looking foam too. It's amazing how much noise that little piece of fabric stops.
    GonzoQuick and DG92071[QUOTED] like this.
  5. Jan 22, 2020 at 8:04 AM
    schecter517
    schecter517 MX4LYFE
    Richard
    San Diego
    2014 DCSB TRD Sport 4x4
    TRD Pro Wheels Falken WildPeak AT3W 265/70-17 Black Spyder Projector HL w/LED Bar Morimoto XB LED Fog Lights Spec-D Black Tail Lights Truxedo Deuce 2 Tonneau Cover Tinted Windows Bed Mat Debadged Blue LED Interior Lights LED Switchback Turn Signals Led Reverse Lights and License Plate Lights DDM Ultra HID 55W 55K Kit
    Picked up this bad boy last night for $400. Going to invest a little money into it to color match it and do some minor repairs on it. Should look like new once I'm done!
  6. Jan 22, 2020 at 8:14 AM
    SilverJack
    SilverJack no one
    You have to remember that sheet metal is like a drum skin. Any sound waves are actually amplified as they hit the outside wall of the cab. Those waves come inside unless blocked by something designed to absorb the waves. A loose foam fabric will absorb sound and not allow it to pass thru like metal will. Dynamat (and others) attach a thick polymer to sheet metal which dampens the waves or stops them as they try to resonate. Ideally, you want to stop the metal from resonating and then kill any waves that make it through the metal.
  7. Jan 22, 2020 at 8:40 AM
    TacoDia
    TacoDia Well-Known Member
    St. Louis
    11 DCSB SR5 V6 OME Kit H-Dakars
    Late to see your question but...
    I haven't used that specific tent but over the 2019 year I used my Kodiak version of it. Overall I was pretty happy with it. I have since bought a RTT over the holidays but have yet to take it out. The Bed style tents aren't too bad if not interested in a RTT and don't want to sleep on the ground. The kind of camping you do or are interested in doing will determine the kind of setup for you. If you're not looking to move around much once camp is set up, the bed tents will work just fine. If you want to be more mobile RTTs and trailers will probably be better but cost more. For the Kodiak system I have a write up over in the Products Review forum (https://www.tacomaworld.com/threads/kodiak-canvas-truck-tent.611911/). I bought a 4x6 foam floor pad from the hardware store, cut it to shape on the bed like it was a bed mat. On top of that I have used moving blankets and a full size mattress topper. Wasn't too bad but definitely a hard surface still. Also used a full size air mattress which ended up being much better. A standard full is ever so slightly too wide for the wheel wells so I just slightly under inflated it and body weight will keep it tight.
  8. Jan 22, 2020 at 9:02 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS3 Pro (Yellow) Driving lights Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut
    How much did they charge you to install it if you dont mind me asking?
  9. Jan 22, 2020 at 9:03 AM
    20somethingwidataco
    Will
    Washington State
    Damn that's actually Genius..... why have i never thought of this. I always just drill a hole through a water bottle and zip tie it to the drain hole
  10. Jan 22, 2020 at 9:29 AM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road
    Nice work! What size sub did you install? Also, are you able to put your rear seats back up?
  11. Jan 22, 2020 at 9:30 AM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    Put holes in my camper shell!!
    Rhino tracks going on after work. Got the prep done during lunch.
    GonzoQuick, Tacoma-Jack, DocD and 6 others like this.
  12. Jan 22, 2020 at 9:33 AM
    Bonnie’s Squeeze
    Bonnie’s Squeeze Well-Known Member
    Ross
    Bluffton, SC
    2015 Tacoma TRD Sport DCSB
    Volant CAI, TRD Exhaust, Throttle Body Expansion with vortex, too many others to mention.
  13. Jan 22, 2020 at 9:40 AM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    at least 4 i would say.
  14. Jan 22, 2020 at 9:50 AM
    Zac of all trades
    Zac
    fwpfab.com
    yeah i think that its going to be just fine! They do have some nice brushless motor ones now though. But they are around $240.
    Yeah just make sure you have enough room! Its got 1/4",3/8" & 1/2" drive in both shallow and deep sockets
    Yup. I dont think its a sale, im pretty sure its the price to get them out of the store...
    I really need to pick up some socket organizers now. Of see if i can have someone 3D print some for me.
    DarthPow[QUOTED] likes this.
  15. Jan 22, 2020 at 10:01 AM
    Voltron4x4
    Voltron4x4 Well-Known Member
    Denver, Colorado
    2014 Black Trail Limo
    This and that...
    https://www.amazon.com/NOCO-GENIUS5-Fully-Automatic-Temperature-Compensation/dp/B07W8KJH44
    Realized my starts were getting a tad slow. Using the OBD Fusion app, battery is resting at 11.6v. Figure I save some money and bring this battery back. Ill be using this charger for a camper setup later on too.
    EdinCincinnati likes this.
  16. Jan 22, 2020 at 10:39 AM
    NC4x4ohsix
    NC4x4ohsix New Member
    Jamie
    2006 Tacoma Access cab SR5 V6
    Picked up some Bosch quiet cast rotors today. Noticed that they do not the screw holes to help remove rotor. Anyone have any 2nd gen experience with this brand?
  17. Jan 22, 2020 at 10:49 AM
    oni06
    oni06 Well-Known Member
    :burnrubber::burnrubber::burnrubber::burnrubber:
    Welcome to the club.
    TACOLUVRKMOD[QUOTED] likes this.
  18. Jan 22, 2020 at 10:49 AM
    scocar
    scocar hypotenoper
    You posted a video that shows you cutting him off. And you're an LEO? And butthurt?
    interdasting.
    Missed opportunity to brake check him while you're at it. :rolleyes:
    DG92071 and elricfate[QUOTED] like this.
  19. Jan 22, 2020 at 11:12 AM
    Rod03
    Rod03 Well-Known Member
    14 DCSB OR 300k+ Miles DD
    22 T4R OR, 12 TX Pro, 21 Taco Skewp!, 02 Taco OR (All Sold)
    Score a Centurion Topper already paint to match my truck. It was installed on a Taco the exact same year and color as mine, it was for sale at a user car lot. Sometimes it doesn't hurt to ask and here we are now. Great find since that is the only other truck i have seen in town that is Nautical Blue. Dang color was only available for 2 years, 12 and 13. The skewp hood and rear bumper i had to buy from the dealer and get them paint since i couldn't find them used. 6.jpg 4.jpg 5.jpg
  20. Jan 22, 2020 at 11:59 AM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    I am on my second set of those rotors. OEM's lasted till 126k but then were pulsing under load or heavy braking for quite a while so they really should have been replaced sooner. Then switched to Bosch for 42k with fresh OE pads. Then at 168k went with Bosch again when I replaced brake pads for fresh OE pads again. Currently at 196k so only 28k on the latest ones so far. I only replaced the first set of Bosch rotors because they were cheap and easy enough to change and thought I'd get longer life out of the pads. Not sure why but the OE pads seemed to wear faster on Bosch rotors since I only got 42k miles out of them. Maybe I did not bed them properly but I followed the internet instructions and they seemed smooth throughout their life. So not really sure if improper install by me or the combo of Bosch rotors and OE pads.
    Kolter45, GonzoQuick and Rick_Taco like this.
