  1. Jul 13, 2019 at 10:04 AM
    HumanityForPresident01
    HumanityForPresident01 Let 'er eat
    Trevor
    2006 Dark Blue Tacoma V6 SR5 EXT Cab TRD Off Road
    2.5" rancho 9000xl lift with UCA's, custom rock sliders, custom rear tube bumper, road armor front bumper, k&n air intake, winch, lights etc.
    I started out with the goal of chasing a noise i hear turning lock to lock in 4wd...
    When i took my wheels off and the usual suspects were all tight i figured run it until it talks louder or something breaks.
    I then moved on to an abs light, i had a feeling i knew what one it was and tried a week ago to get it out with no sucess. Today i gave her hell and pulled it in half. I had to drill the remaining part out and heat up a screw to get it all out. It came right out with the screw and immediately i knew why it wasnt working - it was covered in grease. I think it must have been wheel bearing grease possibly tie rod grease that ran down onto the knuckle.
    So after looking into the abs hole with a flashlight, i knew i had to take it all apart to get the grease out of there... And in doing so i noticed my axle nut was finger tight - i hope that was the cause of my 4wd noise!
    I cleaned the splines with brakleen and put a tint bit of new grease on them and put it back together.
    Then i decided to stop stepping on this old s10 bed mat everyday and cut it to fit my ned. It was in my 97 s10, then a 01 ranger, then an 07 tacoma now my 06 tacoma.
    What a life for a bed mat!
    20190713_095427.jpg 20190713_095459.jpg 20190713_095443.jpg 20190713_095509.jpg 20190713_112911.jpg
  2. Jul 13, 2019 at 10:05 AM
    Trevor
    312$ if you buy the sensor from a stealership.
  3. Jul 13, 2019 at 10:57 AM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    One of my wheel speed sensors got destroyed when a wheel bearing went bad. I took a gamble and replaced it with a non OEM Amazon part. 25$ for both fronts. This was 2 years ago, and the part is still working fine.
  4. Jul 13, 2019 at 11:01 AM
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    Ordered the Prinsu rack finally.
    wmg, GlennHaggis and Z7Xtreme like this.
  5. Jul 13, 2019 at 11:08 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Since overlanding is all about RTTs and I need to know how many maxtraxs to stack under my tires, I got some levels for the rear roof rack:
    Got more beef from BAMF:
    And now my crossbrace is complete:
  6. Jul 13, 2019 at 11:20 AM
    steveo27
    Pittsburgh
    It showed up today
    If you slide the seat forward all the way, then slide it 8 clicks back, that’s the forward limit it’ll slide.
  7. Jul 13, 2019 at 11:42 AM
    SteelCooked
    SteelCooked Well-Known Member
    13 AC Sport Black
    I like your knob :thumbsup:
    Is that boot nice and flush?
  8. Jul 13, 2019 at 11:49 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    BAMF HD bumper frame plates and a dash cam.
  9. Jul 13, 2019 at 11:49 AM
    Trevor
    Right theres no way I'm buying one for 300 bucks. Oreileys is trying to charge me 200 something... Im going to order one online. These people round hurr are LOCO.
  10. Jul 13, 2019 at 11:51 AM
    Trevor
    How easy was it to get your old shift knob off? And how does it come of? R or L threads?
  11. Jul 13, 2019 at 12:01 PM
    Levalexi
    Levalexi Well-Known Member
    Southern Maine
    07 Tacoma access cab 4x4 2.7l
    Just buy a new gas door, drill the rivets out, and bolt the new door on. That's what I did. In the event I decide to color match the door, instead of leaving it black
  12. Jul 13, 2019 at 12:06 PM
    steveo27
    Pittsburgh
    It’s the oem boot. Just added a small rubber washer to the top to make it look more finished
    Give the Amazon ones a try, super easy to return if they don’t work.
    Spins right off. Normal threads.
  13. Jul 13, 2019 at 1:46 PM
    miguelinfest
    miguelinfest Well-Known Member
    2013 Toyota Tacoma
    What leveling kit and spacers did you use?
  14. Jul 13, 2019 at 1:49 PM
    Trouble_The_Tacoma
    Conrad
    Make or buy?
  15. Jul 13, 2019 at 1:53 PM
    1rooster
    1rooster TACOMA31750
    Georgia
    2007 Tundra crewmax
    5100's ALL WAY AROUND, 885X COILS, DRIVER SIDE LEAN SPACER, ICON PROGRESSIVE AAL W/O OVERLOAD, 265/75/16 KENDA KLEVER M/T. 1 1/4 SPIDERTRAC WHEEL SPACERS, GEN 1 TRD COLD AIR INTAKE, STOCK MUFFLER WITH CHOPPED TURNDOWN, 5% TINT OVER FACTORY, DEBADGED, TOYOTA RUBBER BED MAT, WEATHERTECH MATS,UWS TOOLBOX, UNDERCOVER SE, LOCKER MOD, REAR BUMPER, PIONEER DOUBLE DIN WITH PARKING BREAK OVER RIDE, CUSTOM OIL CATCH CAN, FULL LED INTERIOR, ARB BUMPER REPLACEMENT. COVERKING SEAT COVERS. MORIMOTO H1 MINI COVERSION WITH MINI GATLIN GUN SHROUDS AND 5000K MORIMOTO BULBS. TRAILER PLUG RELOCTED TO BUMPER. 20 INCH LED LIGHTBAR MOUNTED BEHIND CUSTOM PAINTED GRILL. STUBBY ATNENNA
  16. Jul 13, 2019 at 1:53 PM
    Trouble_The_Tacoma
    Conrad
    You should just open up an alignment shop at this point...
  17. Jul 13, 2019 at 1:55 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  18. Jul 13, 2019 at 2:03 PM
    FishTacoTruck
    FishTacoTruck Well-Known Member
    2012 Tacoma TRD Off-Road Spruce Mica
    Nah. I already have a green truck from Toyota. With the 4.0.
    HarrisonHopper likes this.
  19. Jul 13, 2019 at 2:11 PM
    Trevor
    I need my own alignmemt rack!
  20. Jul 13, 2019 at 2:51 PM
    cedarpangolin
    cedarpangolin So country I bleed cedar sap.
    Christian
    2015 Tacoma Access Cab 4x4 2.7L
    1.5" wheel spacers, 2.5 front and 1" rear leveling kit, AFE Dry drop in filter, Thrush Glasspack Cherry Bomb exhaust, Falken Wildpeak AT3W tires Soon to be: bully aluminum side steps, plastidip emblems
    miguelinfest[QUOTED] likes this.
