  1. Apr 16, 2025 at 10:43 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Chasing down a weird overheating issue (it's happened twice after hard mountain pass driving). So far I've done a coolant flush, replaced the thermostat and radiator cap.
    Today I did the clutch fan.
    Also cleaned the fan blades, lots of dirt build up.
    We shall see how this helps, if not, next up is radiator, water pump and radiator hoses
  2. Apr 16, 2025 at 10:59 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    get the rad loose I've helped friends chase overheating issues, and thrown parts like you have, only to remove the AC condenser from the mount, and found like a bunch of cotton wood fluf or other random stuff behind it pinned to the radiator causing a blockage. washed that all clear and back to normal. might be worth a look
  3. Apr 16, 2025 at 11:10 AM
    Greenpants
    Greenpants Well-Known Member
    Massachusetts
    2009 4x4 Tacoma 4 banger
    The tailgate mod
    102 K , did my Cat flange back exhaust today. Everything was solid except the flange. Not bad for a 16 year old Taco.
  4. Apr 16, 2025 at 11:19 AM
    Dibblit
    Dibblit Eh?
    Paul
    Fort McMurray
    11 Tacoma
    OME suspension ARB OBA ARB locker
    IMG_2712.jpg Test fitting 35s to see how much cutting needs to be done.
  5. Apr 16, 2025 at 11:39 AM
    Peter603Taco
    Peter603Taco Well-Known Member
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    Was FCT072 the AISIN part # for the fan clutch? Pink ones are the 4.0 w/ tow package I believe? Was looking on Rockauto the other day for myself and didn't see two different options and want to make sure I get the heavier duty tow package one.
  6. Apr 16, 2025 at 12:31 PM
    20somethingwidataco
    Will
    Washington State
    I should have while it was all apart. I did a pretty good inspection and couldn't see much build up. But if the fan was an indication of anything, it definitely has some.
    Although the new clutch fan was definitely worth it. Noticeable increase of air flow
    Kolter45 likes this.
  7. Apr 16, 2025 at 12:32 PM
    20somethingwidataco
    Will
    Washington State
    Peter603Taco[QUOTED] likes this.
  8. Apr 16, 2025 at 12:51 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Finally flushed out the hinges on my gas flap. Doesn't scrape nearly as bad anymore!
    Also oil change.
  9. Apr 16, 2025 at 1:09 PM
    Peter603Taco
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    Thanks! On my list for later this spring/summer around 200k with the water pump and thermostat.
  10. Apr 16, 2025 at 2:00 PM
    20somethingwidataco
    Will
    Washington State
    I wish I did my water pump when I did the coolant flush. Definitely worth it doing it all together
  11. Apr 16, 2025 at 7:15 PM
    jawmes
    jawmes Well-Known Member
    James
    Kauai, Hawaii
    2007 Tacoma 4x4 PreRunner
    Steering feels pretty damn heavy actually. Isn’t stock caster supposed to be 2 degrees?
  12. Apr 16, 2025 at 7:17 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    happened over the weekend.. 2014 Sport, stress free miles. LUV my truck
  13. Apr 17, 2025 at 7:25 AM
    ChumpChange
    ChumpChange Active Member
    Kyle
    Stock '06, 4x4 V6, access cab
    Fit test of my new wheels, everything looks good. Plenty of clearance, knew there would be but didn't want to find out the hard way. 16 hole OE-style steelies, black.
    Drooled over the tires in the garage again. Excited to get them on the truck and out of my way in the shop. Hopefully by May I'll get that wrapped up.
    Checked and greased the driveshaft u-joints. Seems they were replaced not long before I got the truck, they still look nearly new. Carrier bearing has seen better days though, so I'll get one of those on order...
    Oh, and slapped a new sticker on the back window. Gotta have a little stupid fun, right?
    drewnali and NmapFE like this.
  14. Apr 17, 2025 at 8:33 AM
    ToyoNSuby1
    ToyoNSuby1 Member
    Added a new set of wheels and tires, couldn't be happier! 20250416_193218.jpg 20250416_193235.jpg
  15. Apr 17, 2025 at 9:11 AM
    loyaltothetaco
    loyaltothetaco It's part ATV, part SUV, and certified by the DMV
    Adam
    Bay Area
    Radiant Red 2006 DCSB SR5
    2.5" OME lift, Fox 2.5 coil overs, all pro expo leafs, ubolt flip kit w/ upgraded bump stops, 1.25" wheel spacers, 16" Bronze KMC Impact OL wheels, 295/75/r16 Nitto grapplers, beige Softopper, Brute force front bumper w/smittybilt winch, RCI rear bumper, caliraised rock sliders, TRD IFS skid plate custom swingout tailgate w/spare tire mount, TC bed stiffeners, Magnum force CAI, KC spotlights, tacomabeast headlights, rear seat molle panel odds and ends, hi lift, MESO interior lights, and a fuck load of patches… more planned for later.
    I’m biased towards red but good lookin truck :thumbsup:
  16. Apr 17, 2025 at 11:37 AM
    20somethingwidataco
    Will
    Washington State
    Today was upgrade day! Swapped out my dual ss3 ditch lights for some ss5s (thanks for the inspo @TegoTaco ) from @memario1214 . Gave my old ss3 pro SAEs to my girlfriend ( I drive her car a lot and the lighting is atrocious).
    Next up, when I have a spare 2k, is 5 ss5s to replace my rigid bar
  17. Apr 17, 2025 at 2:24 PM
    Dibblit
    Dibblit Eh?
    Paul
    Fort McMurray
    11 Tacoma
    found some cancer, looks like fibreglass fenders will be in the near future.
    Kolter45, NmapFE, ProStar197 and 3 others like this.
  18. Apr 17, 2025 at 4:48 PM
    Dibblit
    Dibblit Eh?
    Paul
    Fort McMurray
    11 Tacoma
  19. Apr 17, 2025 at 4:51 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    I hate the look of a blocky rack on a cab so I got the cheapest most expensive racks they make to haul my kayak.
    Kolter45, drewnali, NmapFE and 5 others like this.
  20. Apr 17, 2025 at 5:16 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    Bad ass!
    Let’s see that 240z! :hearteyes:
