What happens if you intentionally release nitrogen from shocks??
Discussion in 'Suspension' started by EdinCincinnati, Aug 17, 2021.
  1. Aug 17, 2021 at 5:22 PM
    EdinCincinnati
    EdinCincinnati [OP] Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Have ToyTec Boss 2.5 and after 30K miles they are still harsh with bumps. Just curious what would happen if I released some nitrogen.
  2. Aug 18, 2021 at 3:56 PM
    ohcaltexscar
    ohcaltexscar Out of Huckleberry Licorice…
    Chas
    El Paso, Texas
    2005 DCLB SR5 Prerunner
    IM4x4 2.5" NitroGas - Coopers
    No no no no no
    That is not the answer, the nitrogen is at a pre-determined pressure. If you let any out it’ll mess up the balance between the oil and piston and could cause problems like bottoming out too hard or perpetuate shock fading and cavitation. That will damage things in a bad way.
    Valving is where it’s at.
    The Toytec Boss 2.5 is rebuildable, so you can have the valving changed to solve your problem.
  3. Aug 18, 2021 at 4:11 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    The nitrogen is not what is causes the shock’s damping effect; the oil is. The nitrogen is there to prevent air bubbles from forming in the oil. The only way to adjust the damping is adjusting the valving.
    It doesn’t make sense to me that a shock would get stiffer with age. Your problem may be elsewhere.
    AccuTune Offroad likes this.
  4. Aug 18, 2021 at 4:12 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    thank you!! This is a perfect example of the value of TW and NOT making a costly mistake.
    Much appreciated!
  5. Aug 18, 2021 at 5:45 PM
    ohcaltexscar
    Chas
    El Paso, Texas
    No problem! My suspension choices bit me in the butt and I’m working to fix all that so I have been studying a lot. Makes me want to work in a suspension shop now :rofl:.
    On a side note, I grew up outside of Cincinnati. Miss the heck out of that area.
  6. Aug 18, 2021 at 5:51 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    I’m on the east side in Milford
    ohcaltexscar[QUOTED] likes this.
  7. Aug 18, 2021 at 7:28 PM
    ohcaltexscar
    Chas
    El Paso, Texas
    That’s a nice area. I was a bit farther away, outside Wilmington.
  8. Aug 19, 2021 at 8:05 AM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    It's very common to think adjusting nitrogen pressure will soften up the ride, so you're not alone on that one. Glad TW was able to help you out
