What grease for suspension bushings?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GIANTSteps, Mar 28, 2017.
  1. Mar 28, 2017 at 7:57 AM
    GIANTSteps
    GIANTSteps [OP] Well-Known Member
    Brandon
    Reno
    2017 Tacoma TRD Off Road Access Cab
    Added SnugTop cap and KO2's
    Are the bushings on the TRD OR rubber or poly? Tryna figure out which kind of grease to buy.
  2. Mar 28, 2017 at 8:00 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    Which bushings? All rubber to my knowlege and not easy to grease. You talking about uca bushings? The radiator support bushings are known to fail and cause an annoying squeak but nothing grease can fix
  3. Mar 28, 2017 at 8:11 AM
    Storman
    Storman Fukitol abuser
    South Western PA
    2017 SR AC 4x4 AT AC UP ->LONG BED<-
    Whole bunch of shit! $$$
    Soap....
  4. Mar 28, 2017 at 8:43 AM
    GIANTSteps
    Brandon
    Reno
    Sorry, should have been more specific: UCA and/or sway bar bushings.
    My suspension is squeaking/chirping like crazy - almost constantly actually. Just started yesterday. Figured it may just be dirt in the leaf springs so gave it a good power rinse. That stopped the chirp for maybe 5 miles then it came back this morning. It sounds like a family of baby birds.
    Hard to tell if it's coming from the front or back. I'm familiar with the leaf springs making noise - sounds more like a mattress spring. This is like birds chirping so I'm thinking maybe bushings? Maybe U-bolts? Figured I'd use some WD-40 on the leaf springs and contact points with the U-bolts, but was going to either get some silicone or lithium grease for the bushings, depending on the material.
    It's not a chirping fuel pump; I know what those sound like.
    Thx.
  5. Mar 28, 2017 at 10:10 AM
    Storman
    South Western PA
    Are your Leaf U bolts torqued to specs?
  6. Mar 28, 2017 at 10:13 AM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    I used white lithium grease with a straw on the can to inject the grease into my rear leaf bushings, worked for me they are rubber bushings OEM
    Sharky50 likes this.
  7. Mar 28, 2017 at 10:15 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Same I use Lucas Oil White Lithium Grease
  8. Mar 28, 2017 at 10:20 AM
    GIANTSteps
    Brandon
    Reno
    I don't have a torque wrench, but they felt tight. I have my 5k service coming up and will have them check. I think this could well be the problem.
    Garcia. That's what I'll do for now.
  9. Mar 28, 2017 at 10:22 AM
    Storman
    South Western PA
    When I checked mine, 7 out of 8 were good.
    Get a torque wrench brother, you will be glad you did. I have a craftsman, works good enough for me.
  10. Mar 28, 2017 at 10:23 AM
    Storman
    South Western PA
    I hope you are right, thats an easy fix.
  11. Mar 28, 2017 at 10:43 AM
    GIANTSteps
    Brandon
    Reno
    I will do this
  12. Mar 28, 2017 at 10:44 AM
    Storman
    South Western PA
    :thumbsup:
  13. Mar 28, 2017 at 12:08 PM
    GIANTSteps
    Brandon
    Reno
    Quick question - U-bolt nut size: 19mm?
  14. Mar 28, 2017 at 12:12 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Sounds right
  15. Mar 28, 2017 at 12:23 PM
    Storman
    South Western PA
    Yes , 19mm , 52 ft lb. Torque
  16. Mar 28, 2017 at 12:24 PM
    smitty99
    Scottsdale
    I think I torqued mine to 72ft/lbs or 74.... oops
  17. Mar 28, 2017 at 12:27 PM
    Storman
    South Western PA
    Meh....I think I probably went over 52 myself...., maybe more, aint gonna hurt them, over 52 ft lbs is all I was worried about. 1 out of 8 was loose, gave an extra 1/2 thread to be sure, hahaha.
  18. Mar 28, 2017 at 12:27 PM
    Skorfab
    Skorfab Well-Known Member
    Adam
    1984 Toyota Pickup Truggy
    6.5" All Pro Lift, Hysteer, Got Propane Conversion Kit, 37x12.50x16.5 Trailworth Fab Recentered Hummer Rims
    Wrong. 3/4" ;)
    Any grease that isn't petroleum based, white lithium as others suggested. Just be consisted and don't mix greases.
  19. Mar 28, 2017 at 12:30 PM
    Storman
    South Western PA
  20. Mar 28, 2017 at 1:51 PM
    GIANTSteps
    Brandon
    Reno
    So...
    Just torqued to 52 ft-lbs (U-bolts were loose), so that's good. Also got some white lithium spray grease and applied to the contact points on my leaf springs, as well as all the bushings that were easily-enough within reach without pulling out my jack.
    The birds went away for a couple miles and are back. Think I'll jack up each side and grease again. Actually - clean off all the dirt, let dry, then jack then grease. Hope that's a more lasting solution.
