What grease do you use in your UCA's?
Discussion in 'Suspension' started by TOTAL CHAOS, Feb 19, 2019.
  1. May 11, 2020 at 10:41 PM
    pandonsf
    pandonsf Well-Known Member
    Brandon
    Millbrae, CA
    2019 Tacoma TRD Off-Road
    I’m using nitro lubricants red lithium grease.
  2. May 12, 2020 at 6:35 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I've used Red Line, Lucas, and probably every other one available at Autozone. Could never tell the difference between one or another. Any grease is better than no grease.
  3. May 12, 2020 at 6:47 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Been using Lucas Red n Tacky for everything from Bushings, ball joints, U joints, and packing the LCA cams for all my customers and my own vehicles.
    Island Cruiser likes this.
  4. May 13, 2020 at 10:24 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Oh, and I forgot to add Tri Flow for the uniballs.
    lynyrd3 likes this.
  5. May 15, 2020 at 6:33 AM
    FLdub
    FLdub Well-Known Member
    SRQ FL
    2016 Black Tacoma TRD OR 4x4
    It worked great, haven't noticed any adverse effects.
  6. Jul 19, 2021 at 11:39 AM
    dubktrd
    dubktrd Well-Known Member
    Wichita Kansas
    Can we use moly grease?
  7. Jul 19, 2021 at 11:42 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Yes, if tou ask SPC what to use, they'll say moly Grey grease. I asked Icon what they recomend, they said if you're greasing em, any will do, but they default to the moly Grey grease as well. TC and camburg recommend super lube in their bushings, triflow for uniballs, and moly Grey grease for ball joints.
  8. Jul 19, 2021 at 12:18 PM
    dubktrd
    Wichita Kansas
    Thanks for the reply. Trying to get my grease guns set up just right. So one moly ,one lithium and call it good.
  9. Jul 19, 2021 at 1:44 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I guess it depends on which UCA's you have.
    OmahTako likes this.
  10. Jul 19, 2021 at 6:37 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    My spc uppers I use this blue synthetic grease on the ball joint no issues
    My total Choas lower arms I use super lube on the bushings and dry PTFE spray on the uniballs.
    dubktrd likes this.
  11. Jul 21, 2021 at 3:07 PM
    Traction
    Traction Well-Known Member
    WA
    2020 TRDOR
    Red n’ Tacky is what I use.
  12. Jul 21, 2021 at 3:17 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Whatever is in the grease gun.
    Traction likes this.
  13. Mar 12, 2022 at 9:40 AM
    Lando883
    Lando883 Well-Known Member
    Lando
    SoCal
    2021 Tacoma TRD OR
    Do you have to lift the truck to grease Bushing?
  14. Mar 12, 2022 at 9:44 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’m not sure which bushing you are referring to nor if you are asking if you need to lift the truck to access the zerk or to grease it properly, but my guess is no.
    Lando883[QUOTED] likes this.
  15. Mar 12, 2022 at 10:03 AM
    #35
    Lando883
    Lando
    SoCal
    2021 Tacoma TRD OR
    Asking if I need to lift the truck in order to grease the UCA bushings via the zerk fittings. I saw Total chaos recommends loosing the through bolt so not sure if can grease not lifted.
  16. Mar 12, 2022 at 11:30 AM
    #36
    LDS 77
    LDS 77 Well-Known Member
    2016 OR
    I didn’t lift mine when I greased my TC UCAs. I just loosened the through bolt like they recommended. I didn’t take my tires off either.
  17. Mar 12, 2022 at 11:35 AM
    #37
    Lando883
    Lando
    SoCal
    2021 Tacoma TRD OR
    Thanks, this is helpful! Going to give it a try tomorrow. My UCAs keep making a 'tank' sound at low speeds.
  18. Mar 12, 2022 at 11:47 AM
    #38
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    Prothane per Bilstein.
  19. Mar 12, 2022 at 12:46 PM
    #39
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Sta-lube extreme pressure Moly-Graph for Delta Joints/ Super Lube multi purpose synthetic for urethane pivots...
    dubktrd likes this.
  20. Mar 23, 2022 at 7:03 PM
    #40
    AwArD
    AwArD Well-Known Member
    2012 Tacoma Trail Teams TRD sport Double Cab V6 4.0
    Icon Rxt rear leaf option 2 Elka 2.5 DC Reservoir Front/Rear with 600lbs/14inch coil JBA Offroad STD high caster UCA Whiteline LCA inner bushing Mevotech TTX LCA Ball joint Woodward U-Joints Intermidate steering shaft mod Uni filter mod TRD Cat-Back Exhaust Timbren Active Off-Road Bumpstops Front/Rear Overland Torque Tune (OTT) by Yotatune Amsoil signature engine/transmission Amsoil SEVERE GEAR 80W-90 Front/rear diff and T-case Tacoma bed mat Weathertech mat front and rear cabin Summer BFG Ko2 265/65r17 E rated / Fuel Rebel 6 Bronze wheels Winter Nokian Hakkapeliitta 10 studded, 265/65r17 / oem Toyota wheels
    I use Mobilgrease XHP 462 Moly for all the suspension part. It cost me 3.95$ CAD a tube, a box of 10 last a long time. 3% moly and perform very well with water/salt and harsh mining environment. For the price it's a no brainer.
