What drop do I need on my hitch? 3" lift on my truck.
Discussion in 'Towing' started by Ken b, May 10, 2014.
  1. May 10, 2014 at 5:53 PM
    Ken b
    Ken b [OP] Well-Known Member
    Ken
    Surprise, Az
    14 offroad 4x4
    ARE shell, bedrug, TRD wheels
    So my 2014 tacoma will be getting a 3" lift and my tires are 265-75-16. How much drop do i need on my hitch?
    Im guessing someone else is already towing with a similar set up. I know it will depend on the trailer too but looking for an average for just general towing.
  2. May 10, 2014 at 6:00 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    So... if you know it depends on the trailer, then you should know that asking what is 'generally' working for others may not work for you and the trailer you'll be towing. The tongue height of the trailer you'll be towing will dictate the amount of drop you need.
  3. May 10, 2014 at 6:02 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    It depends.
    Different trailers require differing ball heights. You can always buy an adjustable hitch - for lighter loads that would be ideal.
    Most loads you want a nice even "level" sit to the trailer. Some trailers may be alright leaning downwards a little more in the front. What you don't want is the trailer leaning up in the front. That will be dangerous.
    I have a 3" lift and for my tent trailer I use a 7" drop hitch with 2" ball. But for my Yakima boat trailer I only need a 3-4" drop hitch.
    But everyone is going to have a slightly different towing and lift setup.
  4. May 10, 2014 at 6:50 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I hate to disagree, but you're completely wrong. Trailer should never be nose down. Level or slightly nose up only! Nose down will cause the trailer to want to whip.
  5. May 10, 2014 at 7:06 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
  6. May 10, 2014 at 7:08 PM
    Pugga
    Massachusetts
    I'd disagree with you whole heartedly. Trailer should be level or slightly nose down. Nose up can cause the trailer to 'wag'.
  7. May 10, 2014 at 7:22 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    The trailer I'm currently using to move sits slightly nose up when im towing it....hasn't caused any problems yet
  8. May 10, 2014 at 7:24 PM
    Pugga
    Massachusetts
    Every trailer is different. How it's loaded plays a large role in how the trailer behaves also.
  9. May 10, 2014 at 7:26 PM
    Sje1124
    Sean
    Louisiana
    Just a few
    Yeah...I'm about to upload a pic but it had all of my house hold goods in there strapped down
  10. May 10, 2014 at 7:28 PM
    Sje1124
    Sean
    Louisiana
    Just a few
    As you see it wasn't too bad....but had a heavy load in there
  11. May 10, 2014 at 7:30 PM
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Grab an adjustable hitch, throw 2000lbs on a flatbed trailer and try it each way...You will find that nose down responds in the least desirable manner
  12. May 10, 2014 at 11:45 PM
    PattonT
    PattonT Well-Known Member
    2013 2.7l prerunner
    Level or nose down is preferred, a trailer sitting an inch nose up may not matter though.
    Most people with a 3" lift and 32" tires have a ~4" drop dependant on the trailer.
  13. May 12, 2014 at 10:05 AM
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Did some googling and must admit, it appears I'm completely wrong.:eek:.
    Level is best, but apparently nose slightly down is better than up. I've been towing my flat bed quad trailer for years and have found the slightly nose up responds better with my setup. The few times it was nose down it wanted to "wag" so I will continue with level or slightly up. BUT...
    Zyler64 likes this.
  14. May 12, 2014 at 10:09 AM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    wow someone who can admit their mistakes, am I still on Tacomaworld?? :confused: good on you :thumbsup:
    Kevinpd325, ndcmack and Zyler64 like this.
  15. May 13, 2014 at 4:06 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    My experience has been that level or close to is ok.
    BUT the bigger issue is enough tongue weight to stop the wagging. Shift the load forward if at all possible. For most trailers, except boats, tongue weight should be 10-15% of total trailer plus load - 500 # trailer + 750# 4-wheeler should have at least 125 # tongue weight. Most boats with axle way toward the back (due to weight of motor) generally do fine with 8-10%.
  16. May 13, 2014 at 5:04 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I've heard it mentioned when loading you want a 55/45 (or 60/40) weight ratio in front of the wheels. yes or no?
    and like someone said there has to be enough on the tongue to keep it from wanting to "tip up" causing problems
  17. May 14, 2014 at 7:12 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    I am running stock TRD O/R tires and oddly enough I have to use a straight hitch to have my snowmobile and boat trailer to be level. My '04 I used a 2" drop for almost everything. Not easy to find a zero rise/drop hitch. Had to buy one with a solid mounted ball on one side and a recovery hook on the other but it works perfect.
  18. May 14, 2014 at 7:24 AM
    Pugga
    Massachusetts
    I try to load at least 60% of the load in front of the trailer's tires. If it's a light load, I'll put it all in front of the tires.
  19. May 14, 2014 at 7:32 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    guess you not the only one towing wrong. we have a 7’x12' tandem axle trailer rated for 3k pounds no trailer brakes. every time i have had it nose down it wags/whips sways what every you want to call it. level and nose slightly high(like 2” or so higher than level) it never sways or anything. have had more than one load in with nose low(atvs and rhino dirt and other stuff) no matter what it tows better with the nose higher instead of lower maybe it’s just our trailer but i’ll never let it be low again if i can help it.
    i have a 2” drop hitch flipped over for a rise hitch(and yes it is one that can be flipped, i know not all hitches can be flipped)
  20. May 14, 2014 at 8:09 AM
    medic2230
    Murph
    Bama! Roll Tide
    ^^^This
    My enclosed trailer needs a big drop (like 10"). Most other ones I use a 6" drop. My 16' flatbed tandem uses a 2-3" drop. I'm running 285's though. Best thing is to get the trailer and see what it needs.
