What Door Sill Protectors?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FordTrax, Sep 10, 2022.
  1. Sep 10, 2022 at 8:48 PM
    FordTrax
    FordTrax [OP] Active Member
    How many of you have installed the door sill protectors?
    It seems like there are no metal or plastic ones. All the ones I see are the thin adhesive "tape" style that you apply to the door sill. Are these worth doing? Do they hold up?
    Any you recommend or any you don't recommend?
  2. Sep 10, 2022 at 9:00 PM
    PoolFixer
    PoolFixer Well-Known Member
    22 MGM AC SR5 V6 2WD
    OEM TRD headlights, bed lights
    I recently installed the OEM Toyota ones for my new Taco and I can recommend them. They are essentially thick vinyl plastic stickers but they will definitely protect the paint from getting scuffed and scratched.
  3. Sep 10, 2022 at 9:01 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I have the OE Toyota ones and like them, they've held up just fine for 12 years.
  4. Sep 10, 2022 at 9:57 PM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    OEM sill protectors here also. Happy with them, hold up very well.
  5. Sep 11, 2022 at 5:56 AM
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
    OEM sill protectors - port installed so didn't have a choice. however, they are installed on all four door sills and look and seem pretty good.
    nighthawk custom likes this.
  6. Sep 11, 2022 at 6:02 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I had them on my 2nd gen. Took them off when they totaled my truck and put them on my 3rd gen.
  7. Sep 11, 2022 at 6:03 AM
    cgolf
    cgolf Well-Known Member
    2020 Tacoma TRD Off Road
    None
    My 2020 has them. They look great and definitely make a difference.
    zoo truck likes this.
  8. Sep 11, 2022 at 6:08 AM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
  9. Sep 11, 2022 at 6:18 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    I have TufSkinz:
    https://www.tufskinz.com/collections/tacoma-2016/products/door-sills-toyota-tacoma
  10. Sep 11, 2022 at 8:43 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I ordered my truck with them when it was built. whether the factory plant installed them, or dealer, the toyota ones are decent. I'd recommend them also.
    PoolFixer[QUOTED] likes this.
  11. Sep 11, 2022 at 9:04 AM
    Greene368
    Greene368 Well-Known Member
    Metro Atlanta, GA
    2021 Toyota Tacoma TRD Sport 4X4 Predator, Black
    Ditto for the Toyota OEM protectors. If you look long enough and compare prices between dealerships, you can get them pretty cheap...
    stftaco and TexasWhiteIce like this.
  12. Sep 11, 2022 at 12:28 PM
    099 Well-Known Member
    2022 White Tacoma Double Cab SR5
    That was one of the first things I did. I also bought the Tacoma lettering decals for the front sill protector and the Toyota emblem for the rear sill protector. Looks good and holds up fine. If you don't kihe them, take them off.
