What does this "torque propeller bolt" mean?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IanGB, Sep 4, 2022.
  1. Sep 4, 2022 at 2:00 PM
    IanGB
    IanGB [OP] Member
    Ian
    2015 Off Road
    I am looking at the scheduled maintenance on my 15 Tacoma and "re-torque propeller shaft bolt is mentioned." What does this mean? I can't seem to find a description of the procedure. Does it refer to the small bolts on the u-joints? But it says bolt, not bolts.
    I searched the TW Forum and only find greasing the shaft, not torquing the bolt.
    Can anyone steer me, please?
    Ian
  2. Sep 4, 2022 at 2:06 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
  3. Sep 4, 2022 at 2:09 PM
    IanGB
    IanGB [OP] Member
    Ian
    2015 Off Road
    Thanks Will, I don't know how I missed that. It is exactly what I need. I appreciate it.
    Ian
    DG92071 and zero4 like this.
  4. Sep 4, 2022 at 2:12 PM
    DG92071
    DG92071 Well-Known Member
  5. Sep 4, 2022 at 5:05 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I have to be honest here and say, I nor anyone I know personally, have ever checked those bolts.
    And people on the internet don’t qualify as people I know personally.
    Ths only time I’ve checked them, is when I’ve put them back in? :confused:
    And then, I usually apply LocTite. So I don’t really think about it after that.
    I’m not saying you shouldn’t, as it’s a good idea.
    12TRDTacoma and po35042 like this.
  6. Sep 5, 2022 at 12:58 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    I would think if you have to check these bolts, something is wrong at the factory.
  7. Sep 5, 2022 at 1:02 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm going to level with everyone and just be brutally honest here. I don't check the torque on the driveshaft bolts post install and I damn sure don't Loctite shit.
    I've been doing this for over 20 years now and if there was ever going to be an issue it would had happened a long time ago.
    6 gearT444E and TnShooter like this.
  8. Sep 5, 2022 at 1:05 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I put the blue loctite on them but I it’s more for peace of mind. As long as all four are clamped down they won’t be coming off, hell the yolk on mine has to be beat with a sledge to get it to dislodge from the pinion flange even after all the bolts are removed.
    DG92071, 12TRDTacoma and TnShooter like this.
  9. Sep 5, 2022 at 6:45 PM
    IanGB
    IanGB [OP] Member
    Ian
    2015 Off Road
    It is odd that it uses the singular "bolt" not "bolts." I was expecting a huge nut and bolt somewhere.
    DG92071 likes this.
  10. Sep 5, 2022 at 6:49 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I’m guessing whoever wrote that part of the manual never did the task either :rofl:
    DG92071 likes this.
  11. Sep 5, 2022 at 7:03 PM
    TnShooter
    Deogee
    STOCK
    I figure, if the bolt(s) are still there, they must be tight.
    Wait, am I doing this right? :rofl:
  12. Sep 5, 2022 at 8:56 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    That stuff is just put there for legal protection. They don't expect anyone to actually check.
    If dragged into court over a driveshaft related lawsuit, toyota can point to their manual and say "we specified right here it should be checked your honor, we're clearly not at fault here"
    I also don't recheck shit or use locktite. Usually these days I'm using more antiseize to keep threads healthy, not gluing them together
    Raylo and TnShooter like this.
