What does the "max 150 psi" mean on a tire inflator?
Discussion in 'General Automotive' started by dpak, May 25, 2011.
  1. May 25, 2011 at 8:00 PM
    dpak
    dpak [OP] Well-Known Member
    Richmond, VA
    09 4x4 TRD Offroad DCSB
    Toytec/Eibach coils w/ 5100's set at 0, Toytec 2.0 Aluma Rear Shocks, Toytec Boss Leaf Springs, TRD Catback Exhaust, SCS F-5 Matte Gray Wheels, Elusive Elements Mesh Grill
    I'm completely new on using tire inflators. So what does the manufacturer mean when it says "150 psi"? Can I only use up to 150 psi and then it will turn off? If so, then when can I start using it again?
  2. May 25, 2011 at 8:02 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    That means it will explode if you go over 150psi
  3. May 25, 2011 at 8:17 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  4. May 26, 2011 at 5:20 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
  5. May 26, 2011 at 7:53 AM
    dpak
    Richmond, VA
    Thanks for all the cute comments. One guy tries to be funny and the rest tries to follow.
    Can someone explain the max 150 psi thing? Is it the total of all tires cannot exceed 150 psi or just one tire?
  6. May 26, 2011 at 8:08 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You seem to have misunderstood what psi is.
    It's a measure of pressure "Pounds per Square Inch" not volume.
    The rating is the maximum pressure that fitting can hold.
    Not to worry, car and truck tires are fully inflated at much lower pressures.
  7. May 26, 2011 at 8:21 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    it could also mean the compressor is only strong enough to reach 150psi. especially if its a cheap cigarette outlet inflator...
  8. May 26, 2011 at 8:28 AM
    meeestirg
    meeestirg Well-Known Member
    Vance County, NC
    total of one tire cannot exceed 150psi.
    150psi is where your tire becomes an over inflated balloon (thats what they mean by your tire becomes a bomb). the walls stiffen up, you will go faster, you will probably get better gas mileage, but braking won't be so safe. our door jams say to keep the PSI at 29. the dealer ship set mine to 35psi so i guess 29-35 is safe. a cold tire is a tire that hasn't been driven with tires get warm when used and the air inside expands so you wouldn't have a true psi reading so check it in the morning right before your drive.
  9. May 26, 2011 at 8:30 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    :p
  10. May 26, 2011 at 8:33 AM
    Yoytoda
    Roland
    completely stock
    actually, the tire pressure cannot exceed 50psi. Even my Load E range tires have a max pressure rating of 80PSI.
  11. May 26, 2011 at 8:34 AM
    rcbs204
    I was being serious man!
    Your tires say on the side what the max PSI is, Maybe you should seek a ASE certified mechanic to help you with this highly volatile situation.
    That is sarcasm by the way. :D
    Max means just that, Maximum.
    –noun 1. the greatest quantity or amount possible, assignable, allowable, etc.
    2. the highest amount, value, or degree attained or recorded.
    3. an upper limit allowed or allowable by law or regulation.
  12. May 26, 2011 at 8:40 AM
    rcbs204
    ^^^This
  13. May 26, 2011 at 8:48 AM
    meeestirg
    Vance County, NC
    yeah you're right, mine says max psi is 44psi do not exceed. i wonder where he's getting 150 psi.
  14. May 26, 2011 at 8:50 AM
    Yoytoda
    Roland
    completely stock
    where have you ever seen a 150psi spec for a passenger car tire???
    the pressure on the door is set by the factory for optimal driving and handling on stock tires. if you go over that psi you are fine, as long as you dont exceed the tires cold pressure limit. If I only had 29psi in my load e tires it would be all over the road. Way too soft. you need to use good judgment and/or do a chalk test.
    regardless, this is about the "inflater" or better known as "air compressor" max rating of 150PSI. which means it only has the strength to inflate anything up to 150PSI.
  15. May 26, 2011 at 11:40 AM
    dpak
    Richmond, VA
    I'm referring to the tire inflator stating 150 psi max and Yoytoda answered the question. Thank you Yoytoda.
    Thanks to all those who tried to help. Even though my question was answered, this has to be the most worthless section on TW.
  16. May 26, 2011 at 11:43 AM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    Welcome!!!
  17. Oct 15, 2011 at 1:15 PM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    oh snaps, someone got sand in their snatch. stupid response on dumbass vague question. with 100s of inflators, you think there is one answer as to what might happen??? one might go boom, one can melt, one can let you time travel. youre the person that warning labels are meant for.
    burgershot likes this.
  18. Oct 15, 2011 at 6:30 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
