What does a tire out of balance sound like?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12taco, Mar 2, 2016.
  1. Mar 2, 2016 at 6:35 PM
    12taco
    12taco [OP] Cement to be
    Hunter
    Chattanooga, TN
    2018 Double Cab TRD Off-Road 4x4 Cement
    LED turns, brake, & reverse lights
    I'm hearing a humming/vibration sound coming from the right front and a vibration in the truck not rubbing I've checked very thoroughly to see if it was running and its not
  2. Mar 2, 2016 at 6:41 PM
    Htnswches
    Htnswches Well-Known Member
    E
    Lost Angels
    2006 Precummer Tacoma
    310,000 and counting
    I don't think I've ever heard a sound from wheels being unbalanced. Usually it just vibrates or moves the steering wheels..... Maybe your rotors are warped from over-tightening or bad rotors. If it's audible, I'd check the bearings while the wheels is off, check for play or unusual sounds.
    12TRDTacoma likes this.
  3. Mar 2, 2016 at 6:43 PM
    EFinChop
    EFinChop Member
    Jack the truck up and spin the wheel. Usually if it's bad bearing you can feel it in the spring. Kind of weird but it works.
  4. Mar 2, 2016 at 6:43 PM
    12taco
    Hunter
    Chattanooga, TN
    Been check and I am gettin a vibration in the floor board it's not like a bearing sound I had one got bad on another truck and heard it buys just sounds like it's out of balance
  5. Mar 2, 2016 at 6:44 PM
    12taco
    Hunter
    Chattanooga, TN
    Could it be a bearing at 50k though?
  6. Mar 2, 2016 at 6:45 PM
    12taco
    Hunter
    Chattanooga, TN
    And I kinda thought I heard a wheel weight sling
  7. Mar 2, 2016 at 6:45 PM
    Htnswches
    E
    Lost Angels
    Not likely @ 50k but parts fail.
  8. Mar 2, 2016 at 7:05 PM
    12taco
    Hunter
    Chattanooga, TN
    It really vibrates noticeably between 40-50 and quits below 10-15
  9. Mar 2, 2016 at 7:13 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Most likely a balance issue, as these suspensions in stock configuration are very light so if the tires are not road force balanced, you will likely feel it.
    Make sure your wheel bearing's are checked and nothing else odd may be going on with your suspension before you do anything though.
  10. Mar 2, 2016 at 7:19 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    whawhawhawhawhawha
    Bluegrass Taco, rngr and 12taco[OP] like this.
  11. Mar 2, 2016 at 7:21 PM
    12taco
    Hunter
    Chattanooga, TN
    No it's more of a whawwhawwhawwhawwahwwhaw
  12. Mar 2, 2016 at 7:23 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    I was going to say WooWooWooWoo, but that works too.
  13. Mar 2, 2016 at 7:26 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Shieet I was thinking more of a wootoowootoowootoo, but hey whatever helps you guys sleep better at night!
  14. Mar 2, 2016 at 7:28 PM
    NikoVee
    NikoVee you're a towel
    Niko
    Santa Cruz, CA
    '08 PreRunner V6 SR5
    6" Fabtech Kit, Bilstein 5100's, Total Chaos UCA
    I just replaced my drivers side bearing at just under 60k. there was about 3/4" of play when the mechanic rocked the wheel back and forth. given, Ive got a 6" lift so that may or may not contribute to the accelerated wear..
  15. Mar 2, 2016 at 7:29 PM
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    My money is on balancing/misalignment. I'd also be double checking all my lugs were tight.
    Bring it in, get them to print off a sheet with your camber, caster, toe, etc. Could be out of whack.
  16. Mar 2, 2016 at 7:30 PM
    12taco
    Hunter
    Chattanooga, TN
    Dad is gonna take it for me and let me borrow his truck since I don't have much vacation time and get them to check the balance now these are 285/75/16 BFG KOs which I've heard are hard to balance and the guy is gonna check the bearing again because he checks them on every car as the tires are put on crossing my fingers that's the problem
  17. Mar 2, 2016 at 7:32 PM
    NikoVee
    Niko
    Santa Cruz, CA
    if it is the bearing lemme know what you end up paying to get it replaced, got a pretty good feelin I was reamed on this one
  18. Mar 2, 2016 at 7:33 PM
    12taco
    Hunter
    Chattanooga, TN
    Just had it aligned (Firestone) about an hour ago and the guy heard it and said it was the tread but only road in the truck up to about 20 mph after I had drove off and heard it couldn't hear it before cause of the tire rubbing the control arms be cause of the bad alignment
  19. Mar 2, 2016 at 7:33 PM
    oldstick
    oldstick Medicare Member
    GA
    Sounds like out of balance to me. Kinda like a washing machine, no problem with an unbalanced load in the wash cycle but when it goes to spin/dry you will notice it.
  20. Mar 2, 2016 at 7:34 PM
    12taco
    Hunter
    Chattanooga, TN
    Thank y'all so much for the advice and help
