What do you know about Subarus? Reliable?
Discussion in 'Off-Topic Discussion' started by CNEDEER, Apr 16, 2012.
  1. Apr 16, 2012 at 7:29 PM
    CNEDEER
    CNEDEER [OP] If ya ain't first, your last!
    2015 DC TRD OR 4x4
    So I am looking to get a cheap, awd drive car, and the Subaru seems to fit the bill. Vehicle is a 2005 Subaru Legacy with 114k on the clock. Guy is asking $6000 for it.
    Haven't checked it out yet, plan on doing so Wednesday. Anybody familiar with this model year or anything similar? Are they known for any issues or problems? FYI, this is not the GT turbo model, I know those tend to have turbo issues. Its just a base one. Guy has service records for the vehicle, but says the timing belt and water pump have yet to be replaced. I thought if I did buy it I would just run it till the belt breaks, but I researched and found the subaru is an interference motor, so I probably should replace it soon.
    Anyways, your experience with subarus? Pros? Cons? And anything in between would be helpful
  2. Apr 16, 2012 at 7:32 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    they are great cars. we're on our second legacy now the first one had 110k and the only thing that needed to be fixed was the ABS computer and one CV shaft. Other than the computer just normal oil changes. Get the belt and water pump changed and run it for another 90k
  3. Apr 16, 2012 at 7:33 PM
    CNEDEER
    2015 DC TRD OR 4x4
    Sweet! Would you recommend most likely to change the belt right away given its past 100k miles, or maybe drive it for a while?
  4. Apr 16, 2012 at 7:35 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    KPT speaks highly of his subaru days. maybe PM him fo mo advice.
  5. Apr 16, 2012 at 7:35 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    They are pretty reliable. If you are looking for reliability stay away from any Subaru Turbo model.
    Subaru's require a ton more maintenance than our Toyota's. If you can find one that is documented to be maintained, it would be worth the extra money IMO.
  6. Apr 16, 2012 at 7:39 PM
    CNEDEER
    2015 DC TRD OR 4x4
    Yea, I originally was looking for a GT, but after all the issues I heard about the turbo, I figured I'd stay away.
  7. Apr 16, 2012 at 7:58 PM
    oldracer
    oldracer Well-Known Member
    We have had Subaru's for many, many years; reliability is excellent. But in saying that; you do need to do some preventive maintenance on high mileage ones.
    1. Change the timing belt; no big deal but get it done right, check that water pump while your at it.
    2. There is an issue with some head gaskets. Subaru, as most manufacturers buys gasket from various vendors. Some deteriorate, at high mileage; still not a big deal for a Subaru mechanic.
    3. The very old Subarus, in the late 70's and eighties had a coolant crossover pipe that would leak; I don't see that on the 90's and up.
    4. We never had an issue with any engine or driveline part on any Subaru.
    5. Did the previous owner, change oil regularly??? Subaru's are really strong runners; but they can't fix stupid. Someone who never changed oil.
    oldracer
  8. Apr 16, 2012 at 10:04 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    my dad has an 02 outback...and that thing has gone to shit since 110k. so many expensive repair bills, he wishes he sold the thing before he had almost $4k done on the motor, because the repair bills just keep comming.
  9. Apr 16, 2012 at 11:00 PM
    CNEDEER
    2015 DC TRD OR 4x4
    ^^What was the problem(s)
  10. Apr 16, 2012 at 11:08 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    The 02s have a known head gasket problem in 03 the part was revised and updated which solved the problem.
  11. Apr 16, 2012 at 11:12 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    my friends in total have had/owned 4 subies. With the exception of driver error, bullet proof cars imho.
  12. Apr 16, 2012 at 11:16 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    My husband had a Subaru Legacy 30th Anniversary edition (1999). We sold it to my father-in-law and they sold it to my husbands co-worker. That co-worker still drives it everyday and he absolutely loves it. I don't know anything about its 'history' - but I know it was taken care of from day one (we bought it new). It looked just like this:
  13. Apr 16, 2012 at 11:22 PM
    Beerrun
    Beerrun Well-Known Member
    Jon
    Spokane WA
    10 Sedan Sport LB
    Fog light rewire- debadge- front window tint- 5100's @ 1.75- Toytec 1.5 AAL- Avid sliders- 4x4 lighted switch- Sockmonkey decals- Truxedo low pro QT cover- Weather Techs- Back up light Mod. Diff. breather mod. OEM roof rack-Yakima bars. HomerTaco grill. Hella Black Magic Lts. WT vent visors.
    Had a 91 Legacy L wagon. Bought it with 178,000, retired air force kernel-fly fisherman. Free lifetime oil changes for him. Came with a stack of recites (oil changes every month) couple sets of struts, belts, tune up stuff and all the regular services. I sold it with 286,000, and didn't keep up as diligently with the oil changes. I put a battery in it, a radiator, (internally plugged) and a muffler. What a great car, and man do they go through the snow.
  14. Jun 7, 2012 at 9:03 AM
    misterdmac
    misterdmac Well-Known Member
    Doostin
    In or around the truck
    '97 2.7L DLX
    Did you end up pulling the trigger on one yet? I had a '99 Legacy Sedan that I was very sad to part with. Think it was the first time I cried in many years. But then my truck has been more than suitable as a replacement :)
  15. Jun 7, 2012 at 2:23 PM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    We've owned 7 of them - from a 1976 to my wife's current vehicle, a 2011 Outback wagon. They have all been reliable and from my perspective have not required any more maintenance than other quality made vehicles. When you include those owned by members of our extended family, we've owned almost 40 of them since 1969.
    Change the oil regularly and change the timing belt at 100k - other than that, routine maintenance parts like tires, brakes, wiper blades, etc have been all we've really had to do.
  16. Jun 7, 2012 at 4:38 PM
    Shooting Bull
    Shooting Bull Member
    Ohio
    12 SR5
    Bed Cap
    My wife drives a 97 Subaru Legacy 145,000 miles. Routine maintenance, the engine runs great. Very reliable. The only problem was a mysterious brake leak that was finally resolved.
  17. Jun 7, 2012 at 6:14 PM
    CNEDEER
    2015 DC TRD OR 4x4
    Funny this thread revived! I am actually in the process of trying to lease a subaru impreza!
    Also, was looking at a subaru legacy l, 140k miles, the guy wanted 4 grand for it. Its a 2002 or 2003. However, from the reviews I have read, those engines are notorious for head gasket repairs and oil leaks??? Anybody have any of those problems???
  18. Jun 7, 2012 at 6:31 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Imprezas are awesome. Even the base model handles so well!
    Because of the flat engine design, the head gasket is submerged in coolant all the time. If the previous owner replaced the coolant every three years with the correct coolant type and correct conditioner, then it's OK. Otherwise it's risky.
