What company makes the best rear brake shoes?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, Jun 5, 2018.
  1. Jun 5, 2018 at 6:42 PM
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    So I love EBC green stuff brakes for my front brake pads and my truck stops just fine,
    But what is a high performance brake shoe for the rear that’s an upgrade from stock shoes that’s you guys might suggest?
  2. Jun 5, 2018 at 6:48 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    Results may differ, but it will be a cold day in hell before I ever use another aftermarket rear brake shoe. The Centric shoes I tried to use last year would bind, drag and cause all kinds of assaches. I installed genuine Toyota shoes and no problems.
    I found out later that the e-brake lever pin bosses that are pressed into the shoe were pressed in bent. Nothing but the finest quality control from Centric
  3. Jun 5, 2018 at 6:55 PM
    Itchyfeet
    I have this strange feeling that a lot of parts house shit like Centric is stamped in the same factory. I can't imagine it being cost effective for multiple suppliers to each have jigs to build this stuff
  4. Jun 6, 2018 at 12:08 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I have had good luck With the Napa Ultra Premium Line of Brake Products .
    It all depends on your driving style .
  5. Jun 6, 2018 at 6:12 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    :thumbsup:
  6. Jun 6, 2018 at 6:20 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    AISIN
  7. Jun 6, 2018 at 8:15 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I'm still running the original OEM shoes on my ~130k mile '04 doublecab. Rear brakes on pickup trucks hardly see any use unless you constantly have the bed loaded down with heavy gear.
    Your mileage may vary, but I honestly wouldn't throw a bunch of money at your rear brakes with "high performance" shoes...
  8. Jun 6, 2018 at 10:56 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    To each there own every time my truck gets used 95% of the time between 800 to 1000 or more pounds
  9. Jun 6, 2018 at 2:10 PM
    jbrandt
    Justin
    So you'd be one of the ones who constantly has the bed loaded with heavy gear that I referred to...
  10. Jun 6, 2018 at 2:36 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I mean... people are getting like 250k out of OEM brake shoes.. why not just get those?
    Running Board Man likes this.
  11. Jun 6, 2018 at 3:20 PM
    jbrandt
    Justin
    I think that has more to do with the fact that rear drums in an unloaded pickup truck hardly get used at all, vs. the brand...
  12. Jun 6, 2018 at 3:32 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    true that... not sure why you'd need "performance rear brakes" when you could make the ass end lock up just by fred-flinstoning it.
  13. Jun 6, 2018 at 4:53 PM
    1997tacomav6
    Denver
    Haha, well this is my issue, I can lock up my front wheels if needed Pretty easy, but not the rear.
    Believe this, I have original rear pads still at 565,000 miles and even had the dealer check them out
    to make sure they are working correctly which they are so the dealer says.
    But REALLY if the pads are still good at 565,000 I would say something is wrong and maybe need different shoes.
    So hopefully that there were some stickier type pads out there
    The fronts on the other hand I go through every 65,000
  14. Jun 6, 2018 at 5:10 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I'm on my original rear but 4th set of fronts at 159k (lots of hills and Stop'n'Go traffic). so your rear shoes are kind of on par
  15. Jun 6, 2018 at 5:15 PM
    1997tacomav6
    Denver
    Do the rears lock up?
  16. Jun 6, 2018 at 5:18 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Perhaps your BPV is faulty or not adjusted due to lift
  17. Jun 6, 2018 at 5:31 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    if I slam the brakes, yeah, but the e-brake hold no problem
    I only towed occasionally, and the bed is mostly empty now, shell off in summer
  18. Jun 6, 2018 at 6:22 PM
    1997tacomav6
    Denver
    So you can lock up the rear brakes with the Ebrake???
    If that’s so, what shoes do you have?
    Cuz there’s NO WAY I can
  19. Jun 6, 2018 at 7:35 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    still factory shoes, never changed them.
  20. Jun 6, 2018 at 7:42 PM
    1997tacomav6
    Denver
    Maybe mine are hardered over the years or miles, I think I will just get new OEM ones and turn the drums then
    Jcyr likes this.
