What causes the fuel gauge to occilate up and down while driving?
Discussion in '1st Gen. Tacomas (1995-2004)' started by WhiteTaco98, Sep 14, 2018.
  1. Sep 14, 2018 at 7:30 AM
    WhiteTaco98
    WhiteTaco98 [OP] Well-Known Member
    98 SR5 4x4
    Not sure why it is doing that but am guessing the sensor is flaking out.
  2. Sep 14, 2018 at 8:37 AM
    Tlrtucker
    Tlrtucker Well-Known Member
    2000 Tacoma TRD
    I'm guessing you're guess is probably the correct guess, but it's called a fuel sending unit, not a sensor.
  3. Sep 14, 2018 at 8:48 AM
    tony2018
    tony2018 Well-Known Member
    driving on unusual terrain...
  4. Sep 14, 2018 at 1:54 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I will say you have wires rubbed that make contact now and then.
    They are not shorting just causing the needle to bounce
    Sending units tend not to fail quite like that but it is also possible
  5. Sep 14, 2018 at 3:24 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Going up or down a hill or turning sharply will cause it to vary because the fuel level by the sender float will change. The cluster gauge is also dependent on the voltage because it uses solenoids (electric magnets) to set the needle position, so if your alternator is varying the voltage a lot it might affect it, or if you are pulling a lot of current on the same wires that lead to the cluster. A bad or weak ground might affect it too.
  6. Sep 14, 2018 at 6:24 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    OP, how much variance are we talking about here? As @DrZ said, it will fluctuate on hills and turns. Mine can vary about as wide as the needle is, so not much.
  7. Sep 14, 2018 at 6:44 PM
    UtahTacoma02
    UtahTacoma02 Well-Known Member
    Dave
    SLC
    02 Tacoma Double cab TRD Limited
    ARB front bumper, Old Man Emu suspension, on board air compressor, on board hot water converter, cb radio, safari snorkel, warn 8K lb. winch, AP rock slidders/rear bumper, gray wire mod
    When im more than half full my needle will fluctuate from full to empty. But after it gets closer to half tank or 1/4 tank the needle will read accurate up until im out of gas. Curious if my sending unit is bad.
  8. Sep 15, 2018 at 3:47 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    My truck does something similar
