What brands are good for Rotors and Pads
Discussion in '1st Gen. Tacomas (1995-2004)' started by scaliusmaximus, Dec 8, 2020.
  1. Dec 8, 2020 at 2:54 PM
    scaliusmaximus
    scaliusmaximus [OP] Well-Known Member
    pascal
    Los Angeles
    2001 Tacoma Prerunner XtraCab 3.4l
    none
    Need new pads and rotors but I'm on a budget.
    I was gonna Buy Akebono or Advics Pads off of rock auto.
    Also lost on Rotors. Torn between OEM, Bendix or Brembo etc.
    I'm not interested in Drilled or Slotted rotors.
    I would like to do the tundra brake swap as I keep warping rotors, but being on a budget I'm not sure if I can swing it.
  2. Dec 8, 2020 at 3:02 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    My Tundra swap cost about $500. You could do it cheaper if you buy calipers from the junkyard and rebuild them yourself.
    $175 - 13WL remanufactured calipers from NAPA auto parts Eclipse Semi-loaded (Part numbers: CAL SE3264 & CAL SE3263)
    $180 - StopTech Brake Rotors - Sport Slotted
    $87 - EBC Brakes - 7000 Greenstuff SUV Supreme pads
    And for the brake lines, I do not recommend buying stainless ones for a Tacoma. I did this and lucked out, but many others who tried mating the Tacoma brake lines to a Tundra caliper had leaking issues due to the difference in how the Tundra brakes are designed for the flared ends on hard lines, not the hardware on flexible braided Tacoma lines.
    Buy this kit from @turbodb
    https://adventuretaco.com/store/tacoma-to-tundra-hard-brake-line-kit/
    So, for no discounts, no saving money it would cost you about $560 this route.
    If you're thinking about the Tundra brake swap, just make it happen. I waited since I had the OEM brakes serviced when I bought my 2003 since I was headed out on a trip and the rotors were warped and pads were low. I tried waiting until they were worn out some but after getting the Tundra swap on I regretted not doing it immediately. I felt like I wasted $300+ to have a shop do that job when I could have just spent a little more and done it myself.
    turbodb likes this.
  3. Dec 8, 2020 at 3:58 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    From a pad perspective, OEM are really the best. If you're getting rotors as well, you're basically into the brake project for a lot of the cost of going to Tundra brakes...so you might as well do Tundras (since the parts are about the same cost).
    Here are the parts I recommend:
    • 2 Toyota Tundra OEM rotors (L/R: 43512-0C011) Note: Amazon is sometimes out of these, and the Bosch QuietCast line is another good (and cheaper) option (L/R: 50011223) - $100
    • 2 Remanufactured Tundra 13WL calipers from Napa (L: CAL SE3263) (R: CAL SE3264) or another parts store. Note: if they carry multiple lines, I recommend getting a line that has a lifetime warranty in case you ever need to replace a caliper. - $180
    • 1 set of Toyota Tundra OEM brake pads (L/R: 04465-35290) - $70
    • 1 set of Toyota Tundra OEM brake pad shims (L/R: 04945-35120) - $27
    • 1 Tacoma-to-Tundra Hard Brake Line Upgrade Kit - $120
    So, that's a total of $497 (plus tax I guess) for better braking. Full write up with pics here: https://adventuretaco.com/step-by-step-tundra-brake-upgrade-on-a-tacoma-or-4runner/
  4. Dec 8, 2020 at 4:31 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Napa rotors, factory pads and hardware kit
    Kiloyard, Ritchie and Wyoming09 like this.
  5. Dec 8, 2020 at 4:44 PM
    ElTaquitoJr
    ElTaquitoJr Well-Known Member
    01 Tacoma PreRunner 4 cyl
    When I was younger I remember having a pulse in my brakes. Every time it was the rotors warping under use.
    Ever since I did the tundra upgrade, I've not needed to replace or turn my rotors all while having solid brakes. I'd recommend saving if you need to in order to do the swap; it will save you $ in the long run.
  6. Dec 8, 2020 at 4:54 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    I find it hard to believe that new factory rotors and pads would have any warping issues. If it were me I'd be looking closely at other culprits that may be making the pads not release. Like rusty crusty hardware or bad calipers.
    scaliusmaximus[OP] and Bigal90 like this.
  7. Dec 8, 2020 at 6:23 PM
    mattvivsound
    mattvivsound Well-Known Member
    Southern MD
    '01 Tacoma TRD, 4x4, V6
    If you don't want to upgrade to the Tundra brakes, Powerstop makes a great full replacement kit for $240. Go with either: KC1233A or KC1233A36
    I've used the PowerStop kits a few times and they've always done very well.
    Satchmo and RyanDCLB like this.
  8. Dec 8, 2020 at 8:00 PM
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Tundra brake upgrade, prob my favorite upgrade / mod to the trunk to be honest.
  9. Dec 8, 2020 at 8:21 PM
    Roneyj
    Roneyj Well-Known Member
    Chandler, AZ
    06 Tacoma/05 4Runner
    Wow you guys make me feel like a cheap SOB. I buy brake pads / rotors from Rock Auto. Only replace rotors when absolutely necessary. Have only replaced the rotors once and the pads a couple of times. Have over 225k miles. Guess what.... still stops every time I push the pedal.
  10. Dec 8, 2020 at 8:24 PM
    frenchee
    Oceanside CA Area
    LOL!
    Depends on the rig brother. As soon as I added the larger tires, some armor, my camper shell, blaaaaaaablaaaaaa, the stock brakes lasted like 7k miles.
    I'm a conservative braker too, I try to predict traffic slow down and coast etc. Just cant handle any additional weight. Burn right through em. Thast why I liked the tundra upgrade.
    If you dont need it , no reason to upgrade tho
  11. Dec 8, 2020 at 9:21 PM
    scaliusmaximus
    pascal
    Los Angeles
    none
    I’m just daily driving my truck In Los Angeles. No off-roading but lots of stop and go traffic. So not sure if I need the tundra brake upgrade. Just running 265/70/16 tires on it.
    Maybe I’m driving too aggressive?
  12. Dec 8, 2020 at 9:23 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    I'd say you'll be fine without them functionality wise if it's just a DD; then it just comes down to whether it makes sense to do them anyway given the cost you're paying already. Only you can decide that, really.
  13. Dec 8, 2020 at 10:15 PM
    scaliusmaximus
    pascal
    Los Angeles
    none
    In that case does everyone still suggest OEM rotors and pads?
    Or is it alright if I use something cheaper like akebono pads ($27 on rock auto right now)
  14. Dec 8, 2020 at 10:31 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
  15. Dec 8, 2020 at 10:36 PM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    I replaced my rotors calipers and pads and long story short I was given the calipers for a 2002 4Runner with VSC which take a 320mm rotor. I didn't know or notice till I went to check my pads and saw something fishy. The rotors are totally perfect aside from being the wrong diameter. Basically I was using about 2/3 of the pads. So rather than replace the calipers again I bought 320mm and new pads. Problem solved, except that I had essentially lightly used rotors that I don't need. I still have them in the garage waiting for a guy like you.
    FWIW I always go OEM when possible. Pads from Toyota are pretty cheap. Unless you're really stretching your dimes I'd do that.
    Edit: I have over 240k miles and 16 years of DD my truck. I've never warped a set of rotors. And I drive like I still have my WS6 Trans Am when I was 24. I have however decided to cheap out on brake best drums. They were out of round from the factory and caused a serious pulsing problem. That was the first and last time I went with aftermarket.
    You'll be fine for DD with stock brakes. Mr Frenchee there has slapped on about 12 tons in the waistline and needs the capacity however... :)
    tacotoe likes this.
  16. Dec 9, 2020 at 2:04 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Napa Ultra Premium brake parts line Because the Girl that delivers is so worth looking at.
    Toyota if I am getting more parts I just add to the order.
    How ever it plays out.
    I sit down and look at prices when I pay the invoices
  17. Dec 9, 2020 at 5:00 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Or Oreillys. Both are fine.
    I have Akebono pads with Brembo Blank rotors on mine.
    Taco critter likes this.
  18. Dec 9, 2020 at 3:30 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    TW has a firm no politics rule.
    Talk of governors, election, etc. all fall into politics. I've cleaned up this thread once. Please don't make me be the bad guy
    turbodb and Taco critter like this.
  19. Dec 9, 2020 at 3:41 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    How the hell did a brake pad thread turn into politics?
    :rofl:
    Wyoming09 likes this.
  20. Dec 9, 2020 at 3:44 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Fuck if I know. I guess some people just can't help discussing their political feelings no matter what the topic.
