What brand of synthetic motor oil, oil filter, air filter & special tools are you guys using
Discussion in '3rd Gen. Tacomas (2016-2023)' started by brkncly, Apr 13, 2021.
  1. Apr 13, 2021 at 12:14 PM
    brkncly
    brkncly [OP] Well-Known Member
    2017 White Tacoma TRD Offroad
    So since this will my 1st oil change since I've owned it (2017 TRD OR DC LB w/ 66,500 miles)
    Any particular brand of synthetic motor oil or weight that is better than the other? Same question for the oil, oil filter and air filter? Any special kind of socket for the oil filter etc, if so which one should I buy. Are the more expensive brands really worth it, willing to spend the extra money if it's really worth it. Goal is to keep this truck and try get the most out of with proper maintenance. Thanks in advance!
  2. Apr 13, 2021 at 12:19 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Mobil one synthetic and Toyota filter for me. OEM filter for me is the best.
  3. Apr 13, 2021 at 12:24 PM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    I was told that it doesn't matter what oil you use because 0w-20 guarantees it's synthetic. You can run the cheapest 0w-20 and change it every 5k miles instead of 10k miles. 10k is for ideal driving scenarios. If you idle, tow, put stuff on your roof, stop and go traffic at all, it puts you into severe use case, and the maintenance manual says 5k miles.
    If you plan on using the cartridge stock system, then run OE filter should be fine.
    I use spin-on adapter because it's easier I don't have to mess with o-rings and all.
    usmc2msu likes this.
  4. Apr 13, 2021 at 12:27 PM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    I use same as above. Catch the oil on sale or get the rebate then it becomes cheap. Costco oil is an alternative if you want consistent bargain oil, yes it’s good oil. I buy the Toyota filters 90915-YZZD3 online by the case and they become less expensive. This topic has been beat to death and if you do a search you’ll find way more info than you can imagine. You’ll find a lot of bullshit too.
    barf and Junkhead like this.
  5. Apr 13, 2021 at 12:30 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    Just go to Toyota Parts Counter and buy you supplies.
    It's Cheap
    And It's Guarantied.
    BOZOJUICE and RustyGreen like this.
  6. Apr 13, 2021 at 12:34 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Pennzoil ultra platinum with OEM filter every 5k.
    But really any 0w-20 will be perfectly fine, whatever makes you sleep better at night.
    Grossomotto likes this.
  7. Apr 13, 2021 at 12:34 PM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    Wally world oil and toyota filter. To change the filter i just stick an extension in the little drain thing and unscrew it like a regular filter.
  8. Apr 13, 2021 at 12:42 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I’m confused. So you don’t take the drain bolt out and don’t change the small o ring? Just unscrew the whole cartridge? Or I just can’t read properly.
  9. Apr 13, 2021 at 12:45 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    shakerhood and Junkhead[QUOTED] like this.
  10. Apr 13, 2021 at 12:48 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Grossomotto[QUOTED] likes this.
  11. Apr 13, 2021 at 12:49 PM
    Grossomotto
    2017 4WDV6LB6MT
    You can just unscrew the whole filter housing, it's a bit messy.
    But, if it doesn't look like the end of a Tarantino movie, you're not having fun.
    usmc2msu and RustyGreen like this.
  12. Apr 13, 2021 at 12:58 PM
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
  13. Apr 13, 2021 at 12:59 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Whatever oil and tools the shop that changes my oil has lol.
    StayinStock and Junkhead like this.
  14. Apr 13, 2021 at 1:28 PM
    Provist
    Provist Well-Known Member
    2020-TRD-OR-4X4-AT-DCSB-QS
  15. Apr 13, 2021 at 1:39 PM
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
  16. Apr 13, 2021 at 3:05 PM
    waltuo
    waltuo Well-Known Member
    Toyotas
    That fumoto is interesting. I like the 133 as the drain hole points straight down.
  17. Apr 13, 2021 at 3:57 PM
    2020TacomaGuy
    2020TacomaGuy Well-Known Member
    2020 4x4 DCSB SR5
    Pennzoil Ultra Platinum 0W-20
    Motivx filter wrench, drain hose, and funnel.
    Toyota OEM filter.
    Toyota OEM crush washer
  18. Apr 13, 2021 at 4:02 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I usually just buy Mobil 1 and do the rebate making it inexpensive, Toyota Filter and the MotivX Funnel
    Junkhead likes this.
  19. Apr 13, 2021 at 4:05 PM
    SD Quicksand
    SD Quicksand Well-Known Member
    Alex
    San Diego, CA.
    2017 Tacoma TRD Off Road 4x4 Access Cab Quicksand
  20. Apr 13, 2021 at 4:36 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Toyota oil and filter, easy to get, good quality and fairly priced.
    BTW: I have read that the Toyota branded oil has a robust Toyota specific additive package, no aftermarket product shares this package -- engineers determine the specifications, trust the engineers.
    zoo truck likes this.
