What are your rpms at freeway speeds?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 6spd, Aug 24, 2023.
  1. Aug 24, 2023 at 6:34 AM
    6spd
    6spd [OP] Well-Known Member
    san diego
    2023 4x4
    Still stock here, but trying to compile some data for future mods. What are your rpms at freeway speeds and what mods have you done? With my cruise control set at 80mph, my 6MT is at 2600rpm
    1. 70 mph
    2. 80 mph
    3. Trans? (Auto or mt)
    4. Regeared?
    5. Tire size
  2. Aug 24, 2023 at 6:39 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    70 is probably 2500 RPM. 80 - 2700-3500, depending on wind/octane/grade/elevation/temperature/humidity
  3. Aug 24, 2023 at 6:41 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    With cruise set, you are actually around 77 mph, 80 would be more like 2800-2850 on a stock truck. But anyways, I'll play:
    1. 70 - 2850
    2. 80 - 3250
    3. Manual
    4. Yes, 5.29
    5. 255/75R17 (32.05")
    Previously 5.29 with stock tire:
    1. 70 - 3000
    2. 80 - 3400
    3. Same
    4. 5.29
    5. 265/65R17 (30.6 stock sport)
  4. Aug 24, 2023 at 7:00 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    1. 70MPH- 18-1900
    2. 80 MPH- 20-2200
    3. AT
    4. Stock
    5. Stock size but a little heavier than the stock tires.
    AT is geared differently than the MT so that's why my RPMs are lower.
    zoo truck and cwdog like this.
  5. Aug 24, 2023 at 7:59 AM
    cwdog
    cwdog Well-Known Member
    Asheville, NC
    2017 Tacoma Limited
    Meguiars Ultimate Wax, Rain-X, Dog Bed, Undercover Tonneau Tri-Fold, Debadged.
    Same.
    zoo truck and RedWings44[QUOTED] like this.
  6. Aug 24, 2023 at 8:04 AM
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    Yes, those who say it is over 200rpm must be using a manual or something, because it even clearly states in the manual that one should be running at 1600 rpm at 60mph. I run around 70 and my rpms then are at 1800. That is a big selling point, or at least it was, to me, because common sense dictates that if an engine rpms are running lower, it is less wear on the engine. My old 96 tacoma would run about 2400rpm at 70mph, and so, that means my 2019 tacoma engine is wearing at 25% less since it runs at 1800rpm at 70mph.
    cwdog and RedWings44 like this.
  7. Aug 24, 2023 at 10:06 AM
    099 Well-Known Member
    2022 White Tacoma Double Cab SR5
    Same with stock A31 Toyo tires
  8. Aug 24, 2023 at 10:29 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Engine rpm at a given speed is solely determined by transmission gear ratio, differential gear ratio, and tire diameter. Unless you are modifying one of those. nothing is going to change.
    You can look up the gear ratios in a number of places like this thread:
    https://www.tacomaworld.com/threads/the-5-29-mega-thread.557305/
    With a little math, you can answer your own question. Or you look for an online calculator like this one:
    https://spicerparts.com/calculators/transmission-ratio-rpm-calculator
    Chew likes this.
  9. Aug 24, 2023 at 11:35 AM
    kyle11863
    kyle11863 King of the BS
    Kyle
    Big Bear, CA
    1990 Toyota 4Runner SR5 V6 4x4
    Doug Thorley long tube headers and lots of mud
    If you're looking for a really good gear ratio calculator try grimmjeeper.com. Hardest part if figuring out what transmission you have (its on the door sticker) but it knows all the ratios for that.
    Its what I've been using to help people figure out what gear ratio they need for the regear group buy I'm running
  10. Aug 24, 2023 at 11:37 AM
    6spd
    san diego
    2023 4x4
    Been through the 5.29 thread, like finding a needle in a haystack. Just wanted to know real world numbers from others, since they may have different tire setups other than stock.
  11. Aug 24, 2023 at 11:43 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Been proven the AT is easier on these engines valve train when at lower rpm, plus better fuel economy.
    Phlogiston likes this.
  12. Aug 24, 2023 at 1:15 PM
    6spd
    san diego
    2023 4x4
    Ultimately, I'd like a 6mt Tacoma owner to chime in with 5.29s and 285/75r17s with what their rpms are at 80mph.
    Did the grimm jeeper website check, thanks for that, kyle
    kyle11863 likes this.
  13. Aug 24, 2023 at 1:37 PM
    kyle11863
    Kyle
    Big Bear, CA
    No problem! were you able to figure it out and get the answer you wanted on there?
  14. Aug 24, 2023 at 1:49 PM
    6spd
    san diego
    2023 4x4
    I think it got me a ballpark figure, roughly 2700rpm at 80mph with 285/75r17s.
    Looking promising, after I pay off this truck
  15. Aug 24, 2023 at 1:53 PM
    kyle11863
    Kyle
    Big Bear, CA
    Sounds about right. I'm jealous of all you 6 speed guys, My truck is screaming with 4.88's and 33's at 80. If I had that one extra gear it would probably drive so nice.
    Keep an eye out. I run Socal.Toyotas on Instagram and we have a partnership going on with Premier West Gears for regearing. Running our second group buy with them right now, probably won't be our last one either. Since you're in San Diego it wouldn't be too far of a drive for you to go to their shop when the time comes, save yourself a few bucks
    6spd[QUOTED][OP] likes this.
  16. Aug 24, 2023 at 2:05 PM
    gudujarlson
    Minnesota
    You don’t need to read the entire thread. The gear ratios are in the 2nd post. There’s no reason to get “real world numbers” as they are easily calculated to a decent level of precision.
    An even easier thing to do, since you already know you have 2600 rpm at 80 mph, is take the ratio of the two tire sizes and multiple it by 2600. For example, 31/33 * 2600 = 2400. Plug in more precise numbers for a more precise answer.
    To calculate the effect of new diff gears is just as simple, for example, 5.29 / 4.3 * 2600 = 3200.
    If you want to calculate the effect of both, just combine them. For example, 31 / 33 * 5.29 / 4.3 * 2600 = 3000.
    Easy peasy.
    The only source of error here is the actual circumference of each tire. Asking people for their “real world numbers” is introducing this error as well as error in measuring one’s speed. For example, Different sized tires mess with the speed reported by the speedometer. If they haven’t recalibrated their speedometer or are using a different method of measuring their speed, they are giving you inaccurate data.
  17. Nov 25, 2023 at 5:01 PM
    JagSlingerT
    JagSlingerT Member
    Tyler
    2014 Black Tacoma TRD Baja
    I just bought my 2014 automatic, and I noticed that it feels like it needs another gear. Its's running 265/70r16 tires, and 3000rpm at 70mph. I doubt it's been regeared. I hope there isn't a tranny problem.... thoughts?
  18. Nov 25, 2023 at 5:27 PM
    BLtheP
    Plano, TX
    Sounds like it’s either regeared or not going into 5th. Stock auto 2nd gen revs more like 2000-2200 at highway speed with the stock 3.73s. If it’s going into 5th then you either have a bad gauge cluster or you are regeared.
  19. Nov 25, 2023 at 5:38 PM
    JagSlingerT
    JagSlingerT Member
    Tyler
    Thanks. That's what I was afraid of. I think the gauges are fine, the speedometer is dead on. It feels like it isn't going into 5th... I guess I'll have it checked out.
  20. Nov 25, 2023 at 5:48 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Maybe go to an industrial park or take an lightly used highway exit, where you can downshift and count,,,,without impeding traffic behind you, to be safe.
    I don’t know about the 2nd gen, but 3rds are easy and cheap enough to buy a Bluetooth OBDII reader and phone app, one of the bazillion features is gear count.
