What are the symptoms of a bad caster?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sblspawn, Nov 19, 2018.
  1. Nov 19, 2018 at 3:09 PM
    sblspawn
    sblspawn [OP] Well-Known Member
  2. Nov 19, 2018 at 3:11 PM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Really light, darting steering that follows the grooves in the road.
  3. Nov 19, 2018 at 3:17 PM
    sblspawn
    So, it is not possible that a bad caster can causes steering wheel vibrations or that the steering wheel shakes over a bump?
  4. Nov 19, 2018 at 7:42 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    If the bump is hit off center than it can add to the wheel jerking that direction. It doesn’t really create steering wheel vibrations. That’s usually bad tires, wheel balancing or loose/wore out front end steering components. Can you be more specific on your problem?
    sblspawn[QUOTED][OP] likes this.
  5. Nov 19, 2018 at 7:46 PM
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    My caster is 5.4 or something, can't find a place that understands what camber bolts are... anyway, bump steer is the thing you maybe talking about.
    sblspawn[OP] likes this.
  6. Nov 19, 2018 at 7:53 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    My understanding is that Caster influences how easily (or not) steering inputs can be made.
    Steering wheel vibrations will come from improper wheel/tire balance, wheels that don't center right (non-hubcentric wheels on a hubcentric vehicle for example), use of the wrong type of lug nuts, etc.
    sblspawn[OP] and jross20 like this.
  7. Nov 20, 2018 at 3:37 AM
    sblspawn
    And what should be a good Caster number for a lifted Tacoma? Let's say with a 4" Lift. I know that Toe and Camber should be as close as possible to 0, but what about Caster?
  8. Nov 20, 2018 at 3:49 AM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    I think 3* is what most guys run with lift and bigger tires
    Is 4" Just a suspension lift
    I didn't think u could get a taco that high unless u did a bracket trip or body lift
  9. Nov 20, 2018 at 4:10 AM
    sblspawn
    I got a Prerunner. :)
    Alexely999 likes this.
  10. Nov 20, 2018 at 5:11 AM
    tacofish
    N NJ
    14 ext cab 4x4
    OOOOOHHHHHHH
    I guess i should have read your sig
  11. Nov 20, 2018 at 5:31 AM
    jross20
    Georgia
    I'll have to try to explain that to the alignment guys... I wish I could just do it myself because I actually know how. Obviously though there's no machine that's like available to rent or something.
  12. Nov 20, 2018 at 6:44 AM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    You can do it yourself with basic tools. Look in the suspension section for the write up on doing it yourself.
  13. Nov 20, 2018 at 6:50 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I did it myself for the first time a few months ago. Very tedious the first time, and no one to blame but yourself haha.
  14. Nov 20, 2018 at 6:58 AM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
  15. Nov 20, 2018 at 10:13 AM
    jross20
    Georgia
  16. Nov 20, 2018 at 11:42 AM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    Yes. I wanted:
    4.5 caster
    Toe 0
    Camber 0
    The shop put it on the rack and I had:
    4.4 caster
    .4 toe
    .1 camber
    b_r_o likes this.
  17. Nov 20, 2018 at 11:47 AM
    jross20
    Georgia
    That's nuts dude, you're a god haha. I see your caster is still high like mine... my wheels hit the sway bar so I am trying to resolve that.
    MolonLabeTaco[QUOTED] likes this.
  18. Nov 20, 2018 at 12:54 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    I removed the sway bar & noticed no difference on road.
    jross20[QUOTED] likes this.
  19. Nov 20, 2018 at 3:41 PM
    jross20
    Georgia
    I'm debating it. But still I would like my Caster fixed haha
  20. Nov 20, 2018 at 5:17 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    What do you want your caster at? I now have 4.4 & 3.9, to compensate for the angle of the road. I’m happy with these numbers. Factory numbers are too low when you lift and have bigger tires. The further away your tire size is from factory, the further away (higher) your caster needs to be from factory. With 33’s, most like it between 3.5-4.5 degrees. I’m assuming you have SPC UCA’s?
