What are the hidden costs to adding a winch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toywoodsguy82, Aug 7, 2019.
  1. Aug 7, 2019 at 9:07 AM
    Toywoodsguy82
    Toywoodsguy82 [OP] Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    I’m hoping the ones that have installed a winch and enlighten me on the hidden costs of installing one. TW let’s talk this thru
  2. Aug 7, 2019 at 9:19 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    You might want to consider adding:
    “to adding a winch”
    to your thread title so people know what you’re asking.
  3. Aug 7, 2019 at 9:22 AM
    Toywoodsguy82
    Patrick
    Oregon
    Done
  4. Aug 7, 2019 at 9:25 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Hidden costs as in money costs or like the cons of adding a winch?
  5. Aug 7, 2019 at 9:27 AM
    Toywoodsguy82
    Patrick
    Oregon
    Hidden costs other then the cost of the winch... IE electrical upgrade
  6. Aug 7, 2019 at 9:27 AM
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    You'll probably want an upgraded alternator to go with a winch; they can draw over 300A on hard pulls.
    ColoradoTJ and whatstcp like this.
  7. Aug 7, 2019 at 9:27 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    When I added my ARB bumper.....it was a no brainer.....
    winch ready.......Smittybilt 9500# steel rope.......$268
    but then.....changed front coils......$200.......extra 195#
    So I figure my total cost was bumper & foggers.....$1180
    Winch......$268......Labor was $200 IIRC to my mechanic bud.....
    Coils & labor.....$400......buy once/cry once......right ?
    Toywoodsguy82[OP] likes this.
  8. Aug 7, 2019 at 9:29 AM
    Toywoodsguy82
    Patrick
    Oregon
    Thank you for this already have a winch ready bumper so I got that step done
    Armed in Utah[QUOTED] likes this.
  9. Aug 7, 2019 at 9:37 AM
    geekhouse23
    Upgraded front springs for the weight, gusseted bumper support brackets, and I plan to upgrade to a dual battery system with an override to draw power from both at once for winching.
    Cannot speak to the alternator comment. I have never heard of that.
    smw62891 and HappyGilmore like this.
  10. Aug 7, 2019 at 9:44 AM
    Michaelo
    Michaelo Well-Known Member
    Michael
    PNW
    2014 Regular Cab 4x4 5 Speed
    Tree savers, snatch blocks, shackles? I have been researching this myself. Depending on the brands the extra recovery stuff can get expensive too unless you already have them.
    Gunshot-6A and SR-71A like this.
  11. Aug 7, 2019 at 9:46 AM
    Toywoodsguy82
    Patrick
    Oregon
    I have some of the recovery stuff already
  12. Aug 7, 2019 at 9:47 AM
    Toywoodsguy82
    Patrick
    Oregon
    the big three is a must with a new alternator correct?
  13. Aug 7, 2019 at 9:47 AM
    geekhouse23
    When your life depends on it, you don't want to skimp on recovery gear. Cost is higher, but it's proven and will get you and your rig home.
    Gunshot-6A and Clearwater Bill like this.
  14. Aug 7, 2019 at 9:51 AM
    computeruser6
    Dirk
    Escondido
    Lead acid storage batteries cannot be fully discharged without permanent damage (cell reversal) and voltage would drop as the battery is discharged. The battery would have to supply any surges but a bigger alternator will allow you to pull longer and recharge the battery faster.
  15. Aug 7, 2019 at 9:57 AM
    computeruser6
    Dirk
    Escondido
    Yes, you'll want upgraded cabling as well but that part isn't too expensive.
    Gunshot-6A likes this.
  16. Aug 7, 2019 at 9:57 AM
    Toywoodsguy82
    Patrick
    Oregon
    Right but it’s a “hidden cost” in my mind
  17. Aug 7, 2019 at 9:59 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Bare minimum, some recovery gear that might be used when winching as well as good technique. Gloves (if you got steel wire), D-rings and soft shackles, tree saver, snatch block, and extension line (in that order probably). Brands such as Smittybilt that make a good product without breaking the bank.
    Otherwise Id say the biggest cost is a better battery. A step above that would be dual batteries that you can override and tie together when winching
    I dont think a bigger alternator is really worth it. Most winches in the 9.5k lbs class that we would use on these trucks probably pull anywhere from the mid 300 to mid 400 amp range when under full rated load. No alternator will put out that much, the rest will have to come from the battery. The alternator will replenish as the truck runs after winching.
    Gunshot-6A and geekhouse23 like this.
  18. Aug 7, 2019 at 10:01 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Not sure about the alternator. Most trucks, mine included have a tow package which includes a better alternator. A more powerful battery might not be a bad idea. My F150 is 6 years old on the factory battery. I just installed a winch and will replace the battery before winter and go with the biggest one that will fit under the hood. I know some guys run dual batteries but most people do just fine without doing anything special electrically.
    I was able to use a hidden mount on my Ford which eliminated the need for heavy bumpers. I paid $200 for the mount, $300 for the Smittybilt 9500 lb winch. My winch and mount combined is only 120 lbs. If I'd gone with synthetic rope it would have been less than 100. I can't tell any difference and don't feel the need to upgrade the suspension. On a lighter Tacoma, especially with a heavy winch and bumper hanging out in front maybe so.
    I plan to add a 2nd winch for the Tacoma in the future. I'll go with the same winch and synthetic rope to keep weight down and mount it in a receiver mount. It will only be stored in the bed and mounted when needed, probably only from the rear. I MIGHT add a 2nd receiver mount for the front, but doubt it.
    I already have straps and shackles. If I go with the rear receiver hitch I'll have to run some longer cables to make it reach the battery.
    doublethebass and geekhouse23 like this.
  19. Aug 7, 2019 at 10:06 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    upgrading the alternator is pointless, spend your money on a dual battery setup or just a bigger battery.
  20. Aug 7, 2019 at 10:09 AM
    computeruser6
    Dirk
    Escondido
    The "tow-package" alternator for the Tacoma gives you 130A which is not much more than what you get otherwise. There aren't too many alternators that put out more than 300A but it will still allow you to maintain a higher voltage for longer than a 70Ah battery would. The voltage of a lead acid battery drops significantly when heavily loaded and should not be brought below 50% of a full charge unless you want to risk cell damage. I guess that I'll just have to agree to disagree with those who state a higher output alternator is useless but a battery with a few more Ah of capacity is worth the money.
