What are the best current replacement headlight housings?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wanderlust Bus, Aug 7, 2023.
  1. Aug 7, 2023 at 2:13 PM
    Wanderlust Bus
    Wanderlust Bus [OP] Well-Known Member
    Small Lake City
    2002 TRD Off Road
    What are ya'll using now days for replacement headlight housings? I've bought cheap ones from Rock Auto before and they were good for a couple years. Now I have to replace them again. Is the TYC brand at Rock Auto any good? I'm not looking for fancy aftermarket upgrades other than possibly an LED bulb but I'll probably just stick close to stock.
    Oh, forgot to mention that I have to remove my ARB bumper, winch, and fog lights so that a shop can replace a leaky A/C O ring. While it's off, I want to replace the housings. Since they take so much more work to access now, I want to replace with something that's gonna last.
    BatteredTaco likes this.
  2. Aug 7, 2023 at 2:19 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I got the TYC certified ones. They are only a year old, so no info on the longevity. :notsure:
    The LED replacements are nice, but they blind oncoming traffic if the housing is not specifically designed for LEDs.
    BatteredTaco and Morden like this.
  3. Aug 7, 2023 at 7:31 PM
    jimtoyota
    jimtoyota Well-Known Member
    Jim
    Maryland
    2004 Tacoma; 2018 4Runner
    I also am using the TYC certified headlights. They have been on the truck for ~3 years and so far no issues. Lenses are still in great shape.
    BatteredTaco and 426563 like this.
  4. Aug 7, 2023 at 9:34 PM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    I have TYC housings on mine. I've had the truck for almost two years and no idea when they were installed. Holding up fine. Definitely suggest the @crashnburn80 headlight upgrade to go along with a housing replacement. Worth the money for sure.
    BatteredTaco and Digiratus like this.
  5. Aug 7, 2023 at 10:20 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    OEM is the way to go. From there if you want significant boosts in output follow the headlight upgrade below (which also works for 2nd Gen). LEDs are actually a downgrade, they are not focused reducing light projection distance which increases foreground light making them seem brighter while also often scattering light blinding other drivers also making them seem brighter while projecting light significantly less far. No knowledgeable lighting expert will recommend PnP LEDs, performance halogens will be superior in halogen assemblies.
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-h4-not-led-or-hid.398066/
    BatteredTaco, btu44, grntruck and 2 others like this.
  6. Aug 8, 2023 at 8:08 AM
    Wanderlust Bus
    Small Lake City
    2002 TRD Off Road
    Thanks for posting that. I had read it a couple years ago and then totally forgot about it. I briefly read through it again and I should definitely do that while I have the bumper off. However, I need it fast. I'm getting married in 14 days and we're driving across the country and camping for our honeymoon so it needs to be done before then. Guess I better get it all ordered asap!
  7. Aug 8, 2023 at 2:59 PM
    jimtoyota
    Jim
    Maryland
    Congrats!!
  8. Aug 8, 2023 at 8:29 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I too have the TYC, for about 6 years now I'd guess. The thing that kinda sucks is the lensing is poor, so they tend to scatter light like having hi-beams on all the time (still better than completely yellowed out OEMs though). Beyond that, the UV protective coating has started to peel off, despite facing a shaded garage door for that entire time, but overall they've held up well. I'll probably buy a new pair if I ever do a retrofit
  9. Aug 11, 2023 at 6:12 PM
    Rockie mountain TRD
    Rockie mountain TRD New Member
    Elevation 9052'
    2004 TRD
    Grey wire mod.
    I went off the deep end and got OEM housings. I know I could replace them 5 times for what they cost , ( 187.21 ea. ) but I like a good light pattern since I live in the Rockies , and what the hell , the OEM housings went 19 years.
  10. Aug 23, 2023 at 2:46 PM
    jimtoyota
    Jim
    Maryland
    You can't go wrong with that. OEM is the best choice!
    Shamal likes this.
  11. Aug 24, 2023 at 8:11 AM
    Wanderlust Bus
    Small Lake City
    2002 TRD Off Road
    Just finished up the Ultimate Headlight Upgrade with the CAPA Certified TYC housings last night. HUGE difference.
    I really like not having daytime running lights anymore. Pulling into a campsite at night and being able to actually turn the lights off and not blind people is gonna be really nice.
    Shamal and ztwatson like this.
  12. Aug 24, 2023 at 10:06 AM
    redneck_adjacent
    redneck_adjacent Well-Known Member
    Bellevue, WA
    1997 Tacoma 2.7L 4x4 W59 MT
    5 PSI supercharger 3" lift Bilstein 5100 shocks Old Man Emu springs General Spring leaf springs with 2" blocks and extended shackles 31" Firestone Destination XT tires LCE header and catback exhaust HPS CAI Tundra S13WE front brakes KC HiLites flood, ditch, fog, and backup lights Eaton Bussmann relay/fuse panel with custom power tray All Pro bumpers, sliders, and skid plates
    Hi --
    I replaced my headlights with the JW Speaker 8910 Evolution 2. They are indeed expensive but you get what you pay for.
    When I researched headlights, I realized that most threads were akin to tire threads in that everyone had an opinion which boiled down to a) brand favorite, or b) justifying a purchase. I wanted practical advice. It dawned on me that truckers were probably the best source of truth available to me. Knowing that many CDL's feature headlight housing identical to 1995-1997 Tacoma's, I knew that I would stumble on some good information. Resoundingly, the 8910 Evolution 2 came up time and again. It took two months to receive mine in the mail, which was no doubt frustrating. More, they were very expensive (almost $800). But I could not be happier with my purchase.
  13. Nov 11, 2023 at 2:45 PM
    Shamal
    Shamal Active Member
    BC
    SR5 4X4
    Can I buy OEM's in the US for $187 ? Where do I look for those ?
    They are $350 C in Canada
  14. Nov 20, 2023 at 11:20 AM
    edloooo
    edloooo Member
    Ed
    Phoenix, AZ
    2001 Tacoma
    Maybe not the best, but I picked up a set of Eagle Eyes replacement housings on ebay about two years ago. They look exactly the same as factory and fit great, although I'm not sure they are actually OEM spec. They came as a complete assembly (including the bulb and gasket around the bulb pin connector). I paid about $60 for the pair, free shipping. They fit in perfectly and been working great for about two years. Lenses are still clean and clear.
  15. Jan 14, 2024 at 12:07 PM
    BatteredTaco
    BatteredTaco Well-Known Member
    J Lo
    SoCal
    02 3rz stick 4wd ext
    JDM 3rz@300k Yota1 cylhead@400k ARB-OME 880/5100s
    The housings are $187.21 each? What are people buying at 500$ each?
  16. Jan 14, 2024 at 12:52 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    3rd Gen OEM LED headlights. 1st Gen lights do not cost anywhere near that.
    BatteredTaco[QUOTED] likes this.
  17. Jan 14, 2024 at 1:40 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    I used cheap black Amazon ones on all my Toyota’s they last for about a year, then the IV coating chips off and they instantly yellow. Than you pick up the $20 3M headlight restore kit, bring them back to new, and then plastic wax them twice a year and they hold up great.
    Not the same light quality as OEM, but give the truck a different look.
    The Tacoma ones are holding up great.
    The Tundra ones not so well, but they cleaned up nice.
    Before
    After
  18. Jan 14, 2024 at 5:45 PM
    BatteredTaco
    J Lo
    SoCal
    I bought TYC headlights, did not install, before I headed up the pass on interstate 80 going over Sierra Nevada. Is there any difference between the cheaper TYC and the certified TYC.? O'Reilly guy said no and I needed to purchase something. But they're just in the box in case I need them. My OEMs are 20 something years old And there are avalanche warnings going up to West side of the mountain. The box said made in Taiwan. I'm cool with Taiwan
  19. Jan 14, 2024 at 8:21 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    CAPA certified means that a part has been certified as similar enough to an OE part that it can be used as a replacement in an insurance claim repair.
    The CAPA certified housings are generally assumed to be of higher quality, or at least of more consistent quality (ie closer to OE spec) than the regular TYC, but I don't know if anyone has actually put the two side-by-side to compare. It could just be that we're all paying extra for a sticker.
    Whatever housing you install, make sure to align them after install. Alignment is as important as the quality of the housing: https://www.danielsternlighting.com/tech/aim/aim.html
